A.Lange Double split
Has thanked: 44234 times
Been thanked: 9932 times
Movement: Lange manufacture calibre L001.1, manually wound;crafted, assembled, and decorated almost entirely by hand to the highest Lange quality standards; precision adjusted in five positions; plates and bridges made of untreated cross-laminated German silver; balance cock engraved by hand;Number of parts: 465;Jewels: 40;Screwed gold chatons: 4;Escapement: Lever escapement;Balance: New, shock-proofed Glucydur balance with eccentric poising weights; proprietary top-quality balance spring with an attachment (balance spring clamp) for which a patent registration has been filed; frequency 21,600 semi-oscillations per hour; precision beat adjuster with whiplash spring;Power reserve: 38 hours when fully wound.
Functions: World’s first flyback chronograph with double rattrapante, controlled by classic column wheels; precisely jumping chrono minute counter and rattrapante minute counter; flyback function; disengagement mechanism; hours, minutes, small seconds with stop seconds; power-reserve indicator; cumulative and lap-time measurements between 1/6th of a second and 30 minutes, tachometer scale
Operating elements: Crown for winding the watch and setting the time; two push pieces for operating the chronograph; one push piece for operating the rattrapante.
Case: Diameter 43 mm, platinum
Glass and caseback: Sapphire crystal (hardness 9)
Dials: Solid silver, two-tiered, black
Hands: Yellow gold, rhodiumed gold, blued steel and rhodiumed steel
Straps: Hand-stitched crocodile straps with solid-platinum Lange prong buckle.
πηγη :Lange Uhren GmbH
Re: A.Lange Double split
εδω ο μηχανισμος μονος του για να τον θαυμασετε ...
επειδη ενας φιλος μου το ανεφερε για αγορα (96,000 εχει x:
και επειδη ειναι πρωτοποριακος χρονογραφος ας μας εξηγησουν ποιο απλοικα την
λειτουργια του Blackbird , eis
Καλά τι να πρωτοπεις όταν βλέπεις τέτοιυς μηχανισμούς..... έργο τέχνης είναι......
και τι δεν έχει πάνω παιδιά.....
ωραια η παρουσίαση του Κώστα..... ;)
Ειναι αριστουργημα.... :magn: .... τι αλλο να πω... :o ...
Megalos έγραψε: ...ας μας εξηγησουν ποιο απλοικα την
Κωστα,ο snapper το ειπε απλοικα,αλλα ετσι ακριβως ειναι!
snapper έγραψε:Ειναι αριστουργημα.... .... τι αλλο να πω.....
Απο τους πιο δυσκολους σε υλοποιηση μηχανισμους ever...
Αυτό το ρολόϊ άνετα το φοραγα ανάποδα!!!
Εδώ ταιριάζει το σλόγκαν "Φοριέται και στο δεξί...σαν κόσμημα" :rose
Πανεμορφο παιδια.. Οτι και να πουμε ειναι λιγο..
Το ρολοι ειναι σε αλλο επιπεδο!
Κωστα εχεις βαλθει να μας πεθανεις.....αυτο ειναι ΤΟ ρολοι....
vaggol
Δημοσίευση από vaggol »
Παιδιά μιλάμε για απίστευτο ρολόι! Πολλά μπράβο σε όποιον το αποκτήσει και γρήγορα να ποστάρει πολλές φωτογραφίες! Η τιμή του είναι πολύ υψηλή αλλά μιλάμε για ένα masterpiece της ΥΩ!!! Η ομορφιά του μπορεί να συγκριθεί μόνο με αυτή πινάκων ζωγραφικής πολύ μεγάλων ζωγράφων!
Ευάγγελος
Βαγγελη ανασερνεις ναρκωμενους ποθους ... πραγματικα ενα εργο τεχνης ...
