Rebellion
Been thanked: 10070 times
Rebellion
πως σας φαινεται αυτο το νεο μοντελο ..
με καντραν τρισδιαστατο .. και με οπτκο βαθος :magn:
Re: Rebellion
εδω μια αλλη φωτο του καντραν
και εδω το πισω μερος του open back
Re: Rebellion
Πολυ φουτουριστικο...! Αληθεια τη μηχανη εχει..? Απο τιμες γνωριζουμε κατι Κωστα...?
Re: Rebellion
Και μένα δεν μπορώ να πω ότι με ενθουσιάζει, είναι από αυτά τα καινούρια που δεν μου κάνουν πολύ αίσθηση.... :-)
Ισως αν μαθαίναμε παραπάνω πράματα.....
Re: Rebellion
REB-5 Tourbillon
With the REB-5, Rebellion Timepieces hauls that most noble and regal of horological mechanisms, the tourbillon, from its 18th century roots at high speed into the 21st century. Rebellion have now taken the tourbillon and made it their own!
In making a complete revolution every 60 seconds, Rebellion's one-minute tourbillon ensures high precision timekeeping and more - much more! Rotating a tourbillon cage each and every minute consumes considerable energy so the majority have a relatively short power reserve. However, Rebellion's REB-5 stands out from the crowd, both technically and aesthetically, by using twin mainspring barrels to provide a massive seven
days of power! It is an achievement perhaps less surprising on discovering that the movement was developed specifically for Rebellion by renowned Swiss master watchmaker Laurent Besse.
Technical specifications:
Case - Modular sandwich construction
Materials : available in red gold, pink gold and white gold Sapphire crystals : compound curves, bevelled edges, anti-reflection coating both faces, side of case, display back.
Dimensions : 46mm x 56,7mm x 19,6mm
Number of components : 45
Water resistance : 100 meters
Movement :
Calibre: REB-5, manual winding with tourbillon
Tourbillon: one-minute rotation
Power reserve : 7 days from two mainspring barrels
Balance frequency : 21'600 A/h (3Hz)
Number of jewels : 23
Dimensions : 38.25 mm x 36.7 mm
Finishing: galvanic black gold plates, gold plated wheels, blued and black gold screws, wolf-teeth barrels. Movements verified by in-house state-of-the-art testing laboratory
Re: Rebellion
REB-7 regulator
Developed to Rebellion's exacting specifications by master watchmaker Laurent Besse, the audacious REB-7 offers as much in the way of technical surprise as it does in the way of aggressive visual excitement.
Sapphire crystals: compound curves, bevelled edges, anti-reflection coating both faces, display back
Dimensions : 46mm X 56,7mm X 19,6mm
Movement :
Calibre : REB-7, automatic winding regulator movement
Power reserve : 42 hours
Balance frequency : 28'800 A/h (4Hz)
Dimensions : diameter 30 mm X 6 mm
Finishing: galvanic black gold plates, back gold date ring, gold plated wheels. Movements verified by in-house state-of-the-art testing laboratory
Strap - Natural rubber straps with double folding buckle matching case metal
VIWOW
Re: Rebellion
Δημοσίευση από VIWOW »
Το Predator είναι το πρώτο ρολόι που ανακοινώθηκε πριν ανοίξουν τις πορτες τους οι Εκθέσεις που έγιναν στη Γενεύη (συμμετείχε στο GTE και όχι στο Σαλόνι της Γενεύης, βέβαια), ενώ παράλληλα είναι το πρώτο ρολόι της εταιρεία που έχει στρογγυλή κάσα!
Το σχεδίασε ο Eric Giroud, ο οποίος έγινε γνωστός από το σχεδιασμό του Opus 9 για τον Harry Winston.
Η κάσα του είναι τύπου "σάντουιτς", ενώ το καντράν του είναι κατασκευασμένο σε 5 επίπεδα, επάνω σε ένα μοτίβο κυψέλης.
Η τιμή είναι κάτι παραπάνω από τζάμπα, θα μπορούσα αν σας ενδιαφέρει να τη βρω, αλλά έχω ένα προαίσθημα ότι μόλις την βρω δεν θα σας ενδιαφέρει, οπότε ας γλυτώσουμε και εγώ τον κόπο και εσείς την απογοήτευση...
Re: Rebellion
Αρκετά μεγάλο σε κάσα και σε 45 κομμάτια μόνον.... Χμμμμ.... :?
Ευχαριστούμε Κωστή για τις πληροφορίες....!!!!!!!
Re: Rebellion
Αστο καλυτερα Κωστη..δεν θελουμε να ξερουμε τιμη..! lol
Re: Rebellion
Μαριε το 45 κομματια αφορα το cage του tourbillon .. x:
