ETA2824 vs ETA2892
ETA2824 vs ETA2892
H 2892 ειναι λεπτοτερη μηχανη και ειναι η επιλογη των πιο ακριβων κατασκευαστων.
Λαμβανωντας υπ'οψιν οτι οι πιο πολλες μαρκες αγοραζουν standard ή elabore ΕΤΑ2824 χωρις να τις τροποποιουνε,καταλαβαινουμε οτι ευκολα η 2892 εχει πλεονεκτημα στον τομεα της ακριβειας.Στην chronometre εκδοση ομως της 2824 το πλεονεκτημα παυει να υφισταται.
Επισης υπαρχουν στην Κινα εργοστασια με αδεια της ΕΤΑ που φτιαχνουν 2824/2836,ενω η 2892 λεγεται οτι φτιαχνεται μονο Ελβετια.
Στον αντιποδα η 2824 θεωρειται πιο ''σκυλι'' μηχανη γι αυτο και θα τη βρει καποιος σε military/divers ρολογια κατα κοορον.
-The 2824 and 2892 can be ordered in different grades of quality: Standard, Elabore, Top, Chronometer
-The differences in grades can range from quality of materials used to level of testing and regulation
-Most 2824 movements you find will be of the lowest grade as they were the most widely produced. Even in lowest grade, it’s still a very good movement.
-The lowest grade of 2892 utilizes better shock protection and better finishing and materials than the lowest grade of 2824.
-Unless specifically stated by the watch maker what grade of movement is used, assume lowest.
-At the top grades, some people consider the 2824 to be more robust albeit at the expense of being thicker. Some designs, especially today with “turnip” sized watches can accommodate for this 1mm thickness (significant) difference.
-It’s sometimes mistakenly implied that the 2892-A2 is a significantly newer design than the 2824, both trace their roots far back. The 2892 from Eterna and the 2824 from back when ETA used to be part of Eterna.
-At top levels, both can be made equally accurate
http://www.asthewatchturns.com/?page_id=112
http://www.chronometrie.com/eta2824/eta2824.html
http://www.chronometrie.com/eta2892/eta2892.html
- StefMac
- JLC specialist
- Has thanked: 102 times
- Been thanked: 81 times
Re: ETA2824 vs ETA2892
Ααα ωραίο θέμα φίλε άνοιξες !!!
Αλλά επιφυλάσσομαι για την απάντησή μου ...
Αναμενουμε φιλεStefMac έγραψε: Αλλά επιφυλάσσομαι για την απάντησή μου ...
giorgos mg
- Has thanked: 387 times
- Been thanked: 111 times
μπραβο φιλαρακι!!!
δηλαδη το Hamilton jazzmaster slim που εχω ποσταρει ειναι καλη επιλογη ετσι??
Αριστη ειναι φιλε!giorgos mg έγραψε: δηλαδη το Hamilton jazzmaster slim που εχω ποσταρει ειναι καλη επιλογη ετσι??
+1000marios_ch έγραψε:Το πινακάκι στο πρώτο λινκ είναι πολύ κατατοπιστικό.!!!
Αλλά και το τρίτο λινκ εξαιρετικά παρουσιασμένο......
