HOW TO SPOT A FAKE ROLEX IN 9 SIMPLE WAYS
TheWatchBuddies
Been thanked: 752 times
1. Serial/Reference/Model Number
The easiest way to make sure that a second-hand Rolex watch is original is to refer to the reference number on the side of the case. This number on an authentic Rolex watch is marked in fine lines. The model number shines in the light like a diamond cut edge.
Counterfeiters often use lower-quality etching techniques or marking processes that result in faint or poorly defined numbers.
Most Rolex timepieces have serial numbers engraved at the 6 o’clock position on the rehaut (inner bezel ring). For Rolex watches made before 2005, the serial number is generally located between the bottom lugs. In these cases, you’d need to remove the band to inspect the serial number.
2. Rolex Movements
Rolex movements refer to the type of movement used in a Rolex watch, and it can help you spot a fake product.
Rolex is known for using high-quality self-winding mechanical movements in its timepieces. These movements are powered by the motion of the wearer’s wrist and don’t require a battery.
So, if a watch claims to be a Rolex but has a different type of movement, it is likely a fake. However, if you have any Oysterquartz Rolex model made in the 1960s or 1970s, this trick might not work as these watches come with quartz movements.
3. Ticking of the Second Hand
Paying close attention to the movement of the second hand can help you spot a fake watch. On an authentic Rolex, the second hand should move smoothly around the dial without any jerky movements visible to the naked eye or producing ticking noises.
This is because Rolex uses high-quality mechanical movements designed to run smoothly and quietly.
On a fake vs real Rolex, the movement of the second hand is less smooth and may also produce a ticking noise as it moves. This is often the result of a lower-quality movement that’s not as finely crafted as the movements used in authentic watches.
4. Dial Quality
When trying to spot a fake Rolex, you should pay attention to the details of the dial. On a genuine watch, the dial should be very carefully and precisely crafted, with consistent spacing and alignment of the hands, hour markers, and text.
The font used for the text should be crisp and clean, and the hour markers and hands should be evenly coated with luminous material.
In contrast, fake Rolexes often have poorly crafted dials with inconsistent spacing and alignment of the components. The font will be blurry or uneven, with poor quality or unevenly applied luminous material.
5. Materials and Weight
It’s important to consider the weight and materials of the watch. Authentic Rolex watches are made with precious metals, such as gold, stainless steel, and platinum.
As a result, they are generally quite heavy and feel solid on the wrist. Real Rolexes are weighted just right for their size and type, making them feel luxurious and high-quality.
On the other hand, fake Rolex watches are often made with lower-quality materials that are lighter in weight. They may feel cheap and flimsy and not have the same level of durability as a genuine one.
6. Cyclops Lens
The Cyclops lens is a small magnifying lens that is located on the crystal of some Rolex models. It’s designed to magnify the date display on the watch, making it easier to read.
On an authentic Rolex (with a Cyclops lens), the lens should be centered over the date display and free of distortion or imperfections. The magnification of the lens should also be consistent, with no visible blurring or distortion of the date numbers.
On the other hand, fake watches may have poorly crafted Cyclops lenses that are distorted, misaligned, or have inconsistent magnification.
7. Water Resistance
Original Rolex watches are built to be waterproof to various depths, while fake or counterfeit ones may not withstand a proper water pressure test.
It’s not recommended to perform this test on a watch if you are unsure of its authenticity, as it could potentially ruin it. If you believe you have a non-genuine timepiece, it is best to have it inspected by a professional.
8. Laser-Engraved Crown Logo
From 2201 onwards, Rolex began to roll out a miniscule laser-etched crown logo on the glass. It can be found on modern Rolex watches at the 6 o’clock position. This coronet logo is extremely difficult to replicate and is one of Rolex’s efforts to combat counterfeiting.
9. Box and Papers
Don’t be lulled into a false sense of security by what looks like a genuine vintage Rolex box and warranty. Be aware that there are many fake Rolex boxes and paper warranties out there. Also, many consumers didn’t keep the original boxes so a pre-loved Rolex that doesn’t have a box isn’t necessarily a fake.
Pre-owned Rolexes produced before 2006 came with a warranty including the serial number, date and place of purchase, and owner’s manual. Check that the warranty number on the papers matches the serial number engraved on the watch.
From 2006 onwards, Rolex started to use a plastic warranty card. It is electronically activated and contains the same details as the old paper version.
Final Words: How to Spot a Fake Rolex
Spotting a fake Rolex requires attention to detail and understanding the key characteristics and features of authentic Rolex timepieces.
Some key factors to consider are the serial number, movement mechanism, materials and weight, details of the dial, the water resistance, and the presence of the laser-etched crown logo.
It is always a good idea to buy these luxury watches from an authorized retailer or reputable dealer to ensure you get a genuine Rolex watch. A trusted seller will know the obvious signs of counterfeit Rolex watches and the small details that are likely to indicate that it’s a genuine timepiece.ΕικόναΕικόνα
Megalos (Σάβ Απρ 13, 2024 11:03 pm)
Has thanked: 3753 times
Been thanked: 2356 times
Re: HOW TO SPOT A FAKE ROLEX IN 9 SIMPLE WAYS
Σε πολύ υψηλής ποιότητας fake τα περισσότερα κριτήρια χάνονται
Την έχουν πατησει πάμπολλοι , ακομα και βαθείς γνώστες
Βέβαια σε απλες ρέπλικες όλα τα παραπάνω ισχύουν
Ενδιαφέρον σε πληροφορία αν και θα συμφωνήσω με τον προλαλήσαντα.
