escapements
warover
Τοποθεσία: Χανια~Ηρακλειο
Been thanked: 35 times
escapements
Δημοσίευση από warover »
These users thanked the author warover for the post:
Gkaravo-1987 (Πέμ Αύγ 21, 2025 8:13 pm)
Re: escapements
Βαζω δυο ωραια και επιμορφωτικα βιντεακια..... ;)
[youtube][/youtube]
[youtube][/youtube]
Re: escapements
Εδω βαζω μια περιληψη του τι ειναι escapement και οποιος θελει να διαβασει ολο το αρθο ειναι στο λινκ απο κατω.... ;)
In mechanical watches and clocks, an escapement is a device that (1) transfers energy to the timekeeping element and (2) enables counting the number of oscillations of the timekeeping element. It is the source of the "ticking" sound in watches and clocks.
An escapement transfers energy to the clock's timekeeping element (usually a pendulum or balance wheel) to make up the energy lost during a cycle. Without the energy transfer, the oscillation would cease. The escapement may take the energy from a coiled spring (e.g., in a wristwatch) or a suspended weight (e.g., in a cuckoo or grandfather clock). The escapement also permits each cycle of the timekeeping element to be counted. During each cycle, the escapement permits a gear train to advance or "escape" slightly. The periodic advancement results in moving the timepiece's hands forward at a steady rate.
With each swing of the pendulum, one of its arms releases one tooth of a gear, making it change from a "locked" state to a "drive" state for a short period that ends when another tooth on the gear strikes the opposite arm of the pendulum, which locks the gear again. It is this periodic release of energy and rapid stopping that makes a clock "tick;" it is the sound of the gear train suddenly stopping when the escapement locks again.
http://en.wikipedia.org/wiki/Escapement
dimRHO
Has thanked: 129 times
Been thanked: 368 times
Re: escapements
Δημοσίευση από dimRHO »
Chronergy Escapement της Rolex
http://www.rolex.com/watches/baselworld ... -3255.html" onclick="window.open(this.href);return false;
Megalos (Δευ Απρ 06, 2015 11:25 pm)
dimRHO
Re: escapements
Girard Perregaux Constant escapement, μιας και η Rolex δεν ήταν διατεθειμένη να το βγάλει στην αγορά...
http://www.hodinkee.com/blog/in-depth-t ... -explained" onclick="window.open(this.href);return false;
Megalos (Πέμ Ιουν 18, 2015 11:20 pm)
Been thanked: 9994 times
Re: escapements
Πολυ ενδιαφέρουσα εφεύρεση και δουλεια της Girard Perregaux :sh:
dimRHO
Re: escapements
Megalos έγραψε:Πολυ ενδιαφέρουσα εφεύρεση και δουλεια της Girard Perregaux :sh:
κρίμα που δεν έχει τους φανατικούς θαυμαστές που θα τις άξιζαν, ενώ έχουν άλλες όπως η πανιέρη.
Re: escapements
Όντως δεν έχει πολλούς γιραρντιστι lol
VC222
Has thanked: 18 times
Been thanked: 326 times
Re: escapements
Δημοσίευση από VC222 »
Οι πιο ωραίοι τεχνίτες κάνουν μετατροπές μόνοι τους. . .πως λέμε να ελαφρύνουμε τη μπιέλα να μην έχει αδράνεια...
Megalos (Σάβ Ιούλ 09, 2016 10:49 pm)
Re: escapements
VC222 έγραψε:Οι πιο ωραίοι τεχνίτες κάνουν μετατροπές μόνοι τους. . .πως λέμε να ελαφρύνουμε τη μπιέλα να μην έχει αδράνεια...
για πες μας λιγο περισσοτερα για εμας τους μη τεχνικα γνωριζοντες :sleepy:
