SIHH Γενευη 2014
Has thanked: 44688 times
Been thanked: 10050 times
SIHH Γενευη 2014
πλησιαζει και το φετεινο Διεθνες Σαλονι Υψιλης Ωρολογοποιιας της Γενευης ..20 Ιανουαριου αρχιζει
Ας βαλουμε τι καινουργιο θα παρουσιαστει ο καθενας μας απο οσα ξερει
αρχιζω με την Cartier
Rotonde de Cartier Astrocalendaire
Case: platinum
Diameter: 45 mm
Crown: beaded in platinum, set with a blue sapphire cabochon
Crystal: sapphire
Caseback: sapphire
Dial: silver-colored
Bezel: platinum
Hands: sword-shaped, blued-steel
Case thickness: 15.1 mm
Strap: black alligator-skin
Clasp: double adjustable folding buckle in 18k white gold
Water-resistance: 30 meters (100 feet)
Movement: Manufacture mechanical with automatic winding, Caliber 9459 MC, tourbillon and perpetual calendar with circular display, “Poinçon de Genève” certified timepiece
Casing-up diameter: 14 lignes (31.38 mm)
Total diameter: 32 mm
Thickness: 8.1 mm
Number of jewels: 51
Number of parts: 382
Balance: 21,600 vph
Power reserve: approx. 50 hours
Limited series of 100 numbered pieces.
Re: SIHH Γενευη 2014
συνεχιζω παλι με Cartier
Rotonde de Cartier Earth and Moon
Case: platinum
Diameter: 47 mm
Crystal: sapphire
Caseback: sapphire
Crown: beaded in platinum set with a blue sapphire cabochon
Dial: lapis lazuli with an 18K white-gold grid in the form of Roman numerals
Bezel: platinum
Hands: sword-shaped blued-steel
Case thickness: 16.65 mm
Movement: Manufacture mechanical with manual winding, Caliber 9440 MC, tourbillon, second time zone, moon-phase on demand
Casing-up diameter: 17¼ lignes (38.8 mm)
Total diameter: 40 mm
Thickness: 5.65 mm
Number of jewels: 40
Number of parts: 362
Balance: 21,600 vph
Power reserve: approx. 3 days
Limited series of 50 numbered pieces
μια αλλη σπουδαια εταιρεια η Audemars Piguet με το
Audemars Piguet’s Tradition Tourbillon Minute Repeater Chronograph
The hand-wound triple-complication movement, Audemars Piguet Caliber 2874, measures a stately 29.9 mm in diameter and is 7.65 mm thick. It is comprised of 504 components, 83 of which make up the one-minute tourbillon, visible through an aperture in the dial at 6 o’clock. Other parts of the movement, including the hammers of the minute-repeater striking mechanism, can be seen through the sapphire exhibition caseback. The chronograph mechanism is operated by a column-wheel system. The movement, whose balance oscillates at a frequency of 21,600 vph, carries a 48-hour power reserve. Audemars Piguet also takes great pride in the numerous hand-executed finishes on Caliber 2874, including beveling, recesses, sinks, and sandblasting. The bridges and mainplate, as well as other cut-out parts, are hand-finished. The repeater hammers are especially impressive under a loupe, with a fine mirror polish on the surface and painstakingly beveled edges featuring internal and external angles that can only be done by an artisan’s hand. All told, hundreds of hours are devoted to the movement’s finishing.
αυτο το Audemars Piguet παντως δεν με συγκινει με τιποτα
Concept GMT tourbillon
Vacheron Constantin
Malte tourbillon
Raplh Lauren Flying tourbillon
Greubel Forsey Platinum GMT
Ωραιος Κωστα!!
Καθε χρονο τα ιδια....τουρμπιγιον και κοντρα τουρμπιγιον...το τελευταιο πραγματικα ενδιαφερον ρολοι που θυμαμαι απο τους ελβετους τα τελευταια χρονια ειναι αυτο που κοσμει το φορουμ μας...
Θοδωρη μου δεν θα διαφωνησω ...ετσι ειναι πραγματι
να ομως και ενα απλο ρολοι που θα παρουσιασει η Mont Blanc ..της ταξεως των 4.000 ευρω , Star twin Moonphase
