How To Use A Watch Bezel Slide Rule
If you've ever seen a watch with a slide rule bezel and haven't known how to use it, we have a little guide for you. As many of you know, watches with slide rule functions have 2 logarithmic scales (the outer of which turns) while outer scale is just like a tachymeter scale except that the numbers run in reverse. Both slide rule and tachymeter watches use log scales. Let's look a bit at a generic scale.
NOTE - the images shown are a bit rough as they are not photographs of an actual circular slide rule. This scale might not look like all slide rule bezels, but there are analog indicators on most slide rule bezels so that the same functions can be used.
The following examples show some common uses of a circular slide rule:
Calculating a 15% tip (I know, I'm cheap) - just the tip amount in this case:
The goal: Calculate 15% of $20.00.
Set the outer ring's "1.5" (for 15%) over the inner ring index ("1").
Find "2" (for $20.00) on the inner ring.
The outer ring shows "3" which is $3.00.
So a 15% tip for a $20 tab is $3.00
Calculating the total bill with a 15% tip (I'm still cheap):
The goal: Calculate the total bill with a 15% tip on top of $20.00.
Set the outer ring's "1.15" (115% = 15% plus the base of 100%) over the inner ring index ("1").
The outer ring shows "2.3" which is $23.00.
So a 15% tip plus the $20.00 tab is $23.00 all together.
Miles or MPH to Kilometers or KPH conversions:
The goal: Calculate a distance or speed in Kilometers where the distance or speed is known in Miles.
A Kilometer is roughly 0.621 of a mile.
Set the outer ring's "6.21" over the inner ring index ("1").
Find "200" (for 200) on the outer ring.
The inner ring shows "3.22" which is 322 kilometers.
Kilometers or KPH to Miles or MPH conversions:
The goal: Calculate a distance or speed in Miles where the distance or speed is known in Kilometers.
A Kilometer is still roughly 0.621 of a mile.
Set the outer ring's "6.21" over the inner ring index ("1"). No change from the previous example.
In this case, we will technically be doing division rather than multiplication (dividing 200 by 0.621). Subtracting log values is division whereas adding log values is multiplication.
Find "2" (for 200) on the inner ring.
The outer ring shows "1.24" which is 124 miles.
Fahrenheit to Celsius temperature conversion:
The goal: Calculate the Celsius temperature where the Fahrenheit value is known.
Celsius has 100 degrees between boiling (100) and freezing (0) while Fahrenheit has 180 degrees between boiling (212) and freezing (32). So 100/180 = 5/9. This is the fractional value (ratio) of a Fahrenheit to a Celsius degree. Each degree "F" is 5/9 of a degree "C". The actual temperature "F" also needs 32 added to it as freezing is 32 F.
This one is a bit advanced as it starts with 5 over 9 on the slide rule instead of the usual staring with the index ("1") beneath a factor.
Set the outer ring's "5" to be over the inner ring's "9".
Subtract 32 from the Fahrenheit temperature (not using the slide rule).
Find this subtraction value on the inner ring.
The outer ring show the temperature in Celsius.
For example:
Convert 70 F to Celsius:
70 - 32 = 38 (not using the slide rule).
Find 3.8 (for 38) on the inner ring.
The outer ring shows 2.11 which means 21.1 degrees C.
I hope these help you to use slide rule watches more effectively (like the Breitling Navitimer recently reviewed here).
http://www.ablogtoread.com/
These users thanked the author marios_ch for the post (total 2):
Megalos (Κυρ Ιούλ 22, 2012 9:53 pm) • Georges (Κυρ Ιούλ 22, 2012 10:29 pm)
Re: How To Use A Watch Bezel Slide Rule
Μαριε ευχαριστουμε/στω παρα πολυ ...
ενδιαφερον αρθρο για τις χρηση του Navitimer ... θελει παντως πολυ μελετη φιλε :gent:
ειναι και επικαιρο για σενα Κωστα... :cheer:
Argo982001
Has thanked: 642 times
Been thanked: 506 times
Δημοσίευση από Argo982001 »
Ευκολο ειναι Κωστα... ;)
Argo982001 έγραψε:Ευκολο ειναι Κωστα... ;)
+1
Πανευκολο ειναι και αρκετα πρακτικο ακομη και για μας τους μη ιπταμενους! :-)
Πάντα μπερδευόμουν και συνεχίζω να μπερδεύομαι.... :slap:
πάντως ευχαριστούμε Μάριε! :cheer:
n_wildgirl
Been thanked: 79 times
Δημοσίευση από n_wildgirl »
Μάριε υπέροχο το ποστ σου, αλλά έχω ένα πρόβλημα: τις οδηγίες για το slide rule τις εχω ξαναδιαβάσει άλλες 4-5 φορές σε άλλα φόρουμ και μετά την 10η γραμμή διαβάζω μόνο "μπλα μπλα μπλα μπλα μπλα" :robo: Δεν την παλεύω με τίποτα! :?
Νεφέλη
Πολυ ωραιο θεμα Μαριε.
Ευχαριστουμε.
Has thanked: 330 times
Δημοσίευση από lovefist2001 »
Ειναι λιγο μανουριτσα μεχρι να το μαθεις !!!!!!!!!
:good:
:BB:
Σταυρος
χαιρομαι που τελικα εκτος απο μενα Ηλιας , Νεφελη , Σταυρος εχουν καποιες δυσκολιες ....
που θα παει θα το καταφερουμε παντως :book:
