MODEL PATRIOT
Case
316L Stainless Steel (Bead Blasted or DLC/PVD black coating)
Dial
Matte Black with C3 SuperLuminova
Movement
Swiss V-24
Self-winding mechanism with ball bearing rotor
Stop second device
INCABLOC shock absorber
28.800 vibrations per hour, 4 Hz I 25 Jewels
Crystal
Domed Sapphire
3mm thick
Single underside AR (anti Reflective) coating
Size
20mm lug end
42mm Diameter
13mm Thickness
Hex Screw lug pins
