Magrette
Magrette
Magrette Timepiece is a boutique watch company based in Auckland (City of Sails), New Zealand.
We aspire to bring the personal touch into all the timepieces we create. We only produce restricted batches at a time so we can focus on creating quality product for our customers.
ωραία ρολογάκια και σχετικά φτηνά
http://magrette.com/
- historic specialist
- Has thanked: 128 times
- Been thanked: 478 times
Re: Magrette
Ειδικά το Regattare!!
και το Regattare Bronze δεν είναι κακό....
Mε Μiyota βέβαια, αλλά δεν είναι απαραίτητα κακό αυτό. Το "κακό" είναι τα μόλις 50μ. στεγανότητας. Και οι τιμές τους επίσης ενδιαφέρουσες....
Re: Magrette
Ανονιμο-πανεριζουν αρκετα!Δεν ειναι κακα...
- ppana
- Τοποθεσία: Αθήνα
- Has thanked: 5371 times
- Been thanked: 3154 times
Re: Magrette
Για τα δέκα χρονιά τους βγάζουν το Moana Pacific με κάσα από τιτάνιο
Moana Pacific Professional Kara
The Moana Pacific Professional Kara is Magrette’s latest premium dive watch and celebrates the brand’s 10-year anniversary. Kara (prounounced “cah-rah”) is Maori for “flag” and references the use of New Zealand blue, red and white as the color palette. Blue also represents the surrounding waters of the Tasman Sea and Pacific Ocean. The association with the national flag and colors underscores the deep pride Magrette takes in being a New Zealand watch brand.
This watch introduces a Grade 5 titanium case (noted for its superior tensile strength and surface hardness) for the first time in Magrette’s dive collection. In addition to titanium’s exceptional corrosion resistance and high strength–to–weight ratio the Kara is built for the toughest aquatic environments with a water resistance rating of 500M, large screw-down crown with safety alert collar, scratch resistant sapphire crystal, and engraved ceramic bezel insert. The Moana Pacific Professional Kara is powered by the automatic Caliber STP1-11 from Swiss Technology Production SA .This movement along with a new custom winding rotor is visible through a sapphire caseback, another first in the Moana Pacific Pro legacy.
Movement: Swiss Made Caliber STP1-11 automatic movement with hacking seconds, 28800bph, manual winding, Incabloc shock absorption and Nivaflex NM mainspring
Case dimensions: 44mm excluding the crown, 53mm lug-to-lug, 15.3mm tall, 24mm lug width
Case finish: Brushed Titanium grade 5 (brushed) with stainless steel case back
Bezel: Ceramic (matte finish), engraved and fully lumed
Crown: Screw down crown with red safety alert collar
Crystal: Sapphire (double domed), AR coating
Dial, Hands & Bezel: Super Luminova BGW9 (blue in color)
Water-resistance: 500m/1650ft Water resistance. Viton gasket used on case back.
Strap: All new blue FKM rubber integrated strap with logo, name and customized deployant buckle
This is all packaged together in our new signature travel case (outside of case blue, inside grey).
- Has thanked: 44739 times
- Been thanked: 10067 times
Re: Magrette
μπραβο Παναγιωτη που μας θυμισες αυτη την καλη εταιρεια ... εχει ομορφα και φθηνα κομματια ... αξιζει να την ξαναβαλουμε στο ματι
- gkblues
- Τοποθεσία: ΑΓΡΙΝΙΟ
- Has thanked: 1753 times
- Been thanked: 4558 times
- ppana
- Τοποθεσία: Αθήνα
Re: Magrette
Εγώ το παρήγγειλα από Forasec, βγαίνει λίγο πιο ακριβό αλλά γλιτώνεις το άγχος του τελωνείου.
http://webshop.forasec.com/webstore/mag ... -kara.html" onclick="window.open(this.href);return false;
