Louis Moinet
Been thanked: 10070 times
Louis Moinet
νομιζω οτι αυτη η εταιρεια κακως δεν αναφερθηκε στο φορουμ μας
ας την τοποθετησουμε λοιπον αρχιζοντας με ενα τελευταιο της δημιουργημα το Astralis
Re: Louis Moinet
και το φανταστικο πισω μερος του Astralis
Re: Louis Moinet
και τα τεχνικα στοιχεια αυτου του αριστουργηματος
ASTRALIS - TECHNICAL CHARACTERISTICS
EXTERIOR
Case Original design by Louis Moinet®
Composed of 50 different parts
Material 18-Kt Rose Gold 5N, polished and mat finish
Case diameter 46.50 mm
Case thickness 17.62 mm
Water-resistance 50 metres
Caseback Secured with 7 screws
Engraved with the individual number and Louis Moinet symbols
Crystals Two sapphire crystals with double-sided antiglare coating
Crown guard Patent pending
Split-second Activated thanks to a pusher located inside the crown
Split-second hand “Shooting star” design
Chronograph pushers “Wind rose” design
Dial “Côtes du Jura” ® design
Hand-engraved zone and facetted applied hour-markers
Hands “Gouttes de Rosée” design
Bracelet Louisiana alligator leather with crocodile lining, hand-sewn
Inter-horn width 24 mm
Buckle 18-Kt rose gold 5N & black titanium double folding clasp
Watch box Louis Moinet Book, with a hand-written warranty
Edition Exclusive Limited Edition of 12 watches
Reference LM 27.75.50
INTERIOR
Movement Louis Moinet Calibre LM27
Functions Astral Tourbillon
Split-second column-wheel Chronograph
24-hour Planetarium
Tourbillon carriage 1 turn/minute
Split-second mechanism Blued steel column-wheel with monobloc split-second clamps
Planetarium 1 rotation per day
Plate in aventurine
Exclusive meteorites
Moon Dhofar 459 (Moon Meteorite)
Mars Jiddat al Harasis 479 (Mars Meteorite)
Mercury Sahara 99555 (The oldest known rock in the solar system, possibly from Mercury)
Sun Itqiy (Mysterious asteroid formed near the Sun)
Finish Hand-engraved tourbillon bridge
Hand-engraved rattrapante bridge
Polished jewel sinks
Grained brass
Blued steel screws
Winding Hand-winding
Oscillations 21,600 vph (6 V/S, 6 vibrations per second)
Frequency 3 Hz
Lines 14 ½
Power reserve 48 hours
Jewels 31
Escapement Side lever
Oscillator CuBe, two arms
Moment of inertia : 10.5 mg/cm2
Lever angle : 52°
πηγη watchprosite
Re: Louis Moinet
παμε σε αλλα επιπεδα... :good:
Re: Louis Moinet
Φανταζομαι την τιμη του.... $0$$
Re: Louis Moinet
Bρε παιδιά συγγνώμη, αλλά αυτή τη φίρμα Louis Moinet με αυτό το λογότυπο των Βουρβώνων την θυμάμαι ότι την είχα δει στα duty shops του αεροδρομίου της Ζυρίχης το 2002 αν θυμάμαι καλά, αλλά δεν επρόκειτο για ΥΩ ρολόγια. Ήταν φθηνα quartz κυρίως ρολογια, όχι χειρός αλλά τσέπης ή traveler clocks με ξυπνητήρι, που αγοράζαμε για σουβενίρ. Μάλιστα είχα αγοράσει και εγώ ένα, για δώρο σε φιλικό πρόσωπο.
Κάνω τόσο πολύ λάθος?? :? :?
Re: Louis Moinet
Δεν τη γνώριζα. Ευχαριστώ για την ενημέρωση. Πολύ εντυπωσιακό ρολόι, αλλά φαντάζομαι σε επίπεδο που δε φαίνεται από εδώ που είμαι εγώ, αν κοιτάξω προς τα πάνω...
simon
Τοποθεσία: Zugi Cyprus
Has thanked: 3 times
Been thanked: 20 times
Re: Louis Moinet
Δημοσίευση από simon »
eisenberg έγραψε:Φανταζομαι την τιμη του.... $0$$$
Φιλε Θοδωρε ο ατσαλινος χρονογραφος του LOUIS MOINET τιμαται γυρω στα 15.000 ευρο. Το Tourbillon γυρω στα 230.000 ευρω. Κατασκευσαν και ενα και μοναδικο το Μαgistralis που ειναι Grande Complication και το δινουν ορισμενα site ως το τεταρτο πιο ακριβο ρολοι ολων τον εποχων Οταν το ειδα εμεινα εκθαμβος. Η τιμη του 680.000 ευρο. Δυστυχως δεν ξερω να το ποσταρω. Η κασα του να σκεφτεις αποτελειτε απο 123 κομματια. Φιλικα Σιμος.
Re: Louis Moinet
Ευχαριστουμε για τις πληροφοριες Κωστα και Σιμο!
Re: Louis Moinet
Σιμο ευχαριστουμε για τις πληροφοριες φιλε!
Αυτο ειναι το Magistralis που λες? :magn:
Εξωπραγματικο ρολοι :good:
