Chronoswiss
GeorgeD
Been thanked: 10 times
Chronoswiss
Δημοσίευση από GeorgeD »
ανοιγω νέο θέμα γιατί δεν βρήκα υπάρχον για την Chronoswiss
chronoswiss repetition a quarts
http://www.ch-na.com/pdf/1641R-A.pdf
Re: Chronoswiss
Θυμάμαι και στην εκθεση η εταιρεία αυτή είχε να επιδείξει ωραία κομμάτια..............
όπως πχ αυτά τα δύο......
Re: Chronoswiss
Γιωργο πολυ καλα εκανες με αυτο το θεμα και την εταιρεια ...ευγε
το κυριωτερο ομως ειναι το κομματι της που μας ανεφερες .. repetition ..πολυ ενδιαφερουσα complication
Μια φωτο κιολας για να το βλεπουμε το ρολοι
Re: Chronoswiss
CHRONOSWISS - Sold!
The Family-owned Munich-based company has been sold to a Swiss investor family from outside the watch industry.
WORLDTEMPUS - 30 January 2012
Elizabeth Doerr
Twenty-nine years ago, German master watchmaker Gerd-Rüdiger Lang founded Chronoswiss. The reasons for the ex-Heuer employee’s actions were simple: he was just about out of a job in the quartz crisis and he simply couldn’t believe that the era of mechanical watches had come to an end.
Renaissance
Lang is often rightfully heralded as one of the major proponents of the renaissance of the mechanical watch in the modern era. His beautifully proportioned timepieces featuring perfect, traditional details powered by purchased mechanical movements only destined to become ever more interesting as time passed stuck a chord among consumers. Chronoswiss became an insider tip visible on the wrists of many well-dressed men and mechanical watch connoisseurs alike the world over.
Turbulent years
Recent years following the building of Lang’s own factory on the outskirts of Munich have not been kind to Chronoswiss for a number of reasons – not least among them the recent economic crisis –and business has faltered. Lang, now 69 years old, officially retired last year. His daughter Natalie, also a watchmaker, who many had hoped would take over the family business that was her father’s lifework, did not.
Takeover
Lang has come to an agreement with a Swiss entrepreneur family for the 100-percent takeover of Chronoswiss. The entire factory in Karlsfeld and 100 percent of its employees will be taken over as is. Chronoswiss’s Swiss subsidiary Chronosa in Nidau had already been dissolved over the previous year.
However, it is planned that Chronoswiss’s headquarters will be moved to Switzerland thanks to its new owners, who also plan to only make mechanical watches – completely in Chronoswiss’s 29-year tradition.
http://www.worldtempus.com/en/news/top- ... wiss-sold/
elbetos R21
Re: Chronoswiss
Δημοσίευση από elbetos R21 »
πολυ ομορφα κομματια!!!!
σε τι ευρος τιμων κυμαινονται τα κομματια της εταιρειας??
Re: Chronoswiss
Εξαγοραστηκε και η Chronoswiss
Re: Chronoswiss
stavros_ch έγραψε:Εξαγοραστηκε και η Chronoswiss
για να ειμαι ειλικρινης αυτο το ειχε αναφερει ο Στηκας προ διετιας ... αργησε λιγο
αλλα τελικα επιβεβαιωθηκε :rose
VC222
Has thanked: 18 times
Been thanked: 326 times
Re: Chronoswiss
Δημοσίευση από VC222 »
elbetos R21 έγραψε:πολυ ομορφα κομματια!!!!
κλασσικό design και τιμές στο μεσαίο πεδίο λίγο πάνω από Omega...
Re: Chronoswiss
N E W M o d e l – Chronoswiss Kairos Automatic
Ref. CH2841R – 18kt Rose Gold and Ref. CH2843 – Stailess Steel
The case, in gold or steel, is comprised of 21 parts and measures 40mm x 8.5mm. It is polished, screw-down fluted bezel with complete threading and anti-reflective coating on one side of the sapphire crystal, screw-down, polished case back with full thread and anti-reflective coating on one side of the sapphire crystal, Oignon-style crown (solid crown in case material), screw-mounted strap lugs with patented Autobloc system. It is water resistant to 30 meters.
Movement is the Swiss automatic Chronoswiss caliber C281 with 21 jewels, 28,800 vph and a power reserve of 42 hours. It features a Glucydur balanace, a Nivarox flat hairspring, Incabloc shock protection and fine adjustement can be done via an eccentric cam. It also features a skeletonized and rhodium-plated rotor with Côtes de Genève finish, ball bearing, polished pallet lever, escape wheel and screws, plates with perlage, bridges with sunburst pattern and Perlage finishing.
The dial is solid sterling silver, hand-guilloched.
Thanks.
http://forums.timezone.com/index.php?t= ... sg_6111874
Re: Chronoswiss
N E W M o d e l – Chronoswiss Pacific Automatic
The case, in stainless steel, is comprised of 25 parts and measures 40mm x 11.2mm. It has a sapphire crystal and display back, and is water resistant to 100 meters.
Dials can be had in blue, black or brown, with a rose gold bezel or a steel bezel.
http://forums.timezone.com/index.php?t= ... sg_6111897
