Ποιό ξεχωρίσατε στην έκθεση???
Σκέφτηκα να κάνω ένα θέμα για να συζητήσουμε ποιό κομμάτι σας έκανε περισσότερη εντύπωση και ξεχωρίσατε στην έκθεση , ποιο σας έκανε αυτο το κλικ ώστε θα μπορούσε να είναι ο επόμενος στόχος...???
Στην συζήτηση μπορούν να λάβουν μέρος φυσικά και τα μέλη που δεν ήταν παρόντα καθώς με τις πάρα πολλές φώτο που ανεβάσαμε πιστευω είδατε τα πιο πολλά από τα ρολόγια που υπήρχαν και σχηματίσατε μια άποψη....!!!!
Αναμένω τις δικές επιλογές λοιπόν καθώς σε εμένα άρεσε πάρα πολύ το πιο κάτω κομμάτι.......
Εδώ ένα review........
To pay tribute to this momentous occasion and in recognition of the brand’s association with the Monte-Carlo Historic Rally, Girard-Perregaux presents their new Fly-Back Chronograph. Designed with racing enthusiasts in mind it is a true sports watch and thanks to the fly-back function the traditional sequence of operations: stop-reset-start has been replaced by a single press of the push-piece. As is to be expected the Monte Carlo 1973 is equipped with a tachymeter scale engraved on the bezel which allows the user to calculate the speed of a body in motion. How often you will actually use this function is a different matter entirely, however, it is a foregone conclusion that this is a prerequisite for any serious sports watch.
The design, of itself, is not anything particularly striking and one could be forgiven for mistaking it for one of the numerous variations of the Omega Speedmaster. However, it is the little touches that make this piece an instant classic. Keeping true to its heritage the piece features a sapphire “Box” crystal and the style of the tachymeter scale engraved on the bezel is reticent of timepieces from the beginning of the 1970s. The dial also features subtle blue highlights which draw the eye without making the watch look gaudy and distinguish it from the countless other chronographs on the market.
The piece is finished off with a timeless black alligator strap with a folding buckle which in my eyes further heightens its appeal as so many chronographs these days are fitted with rubber straps, thus precluding them from more formal occasions.
As a final touch the dial has been personalized with the inscription “Monte-Carlo 1973” and the case-back is engraved with the winners’ number plate, the names of the car and its drivers.
Girard-Perregaux has a long and rich association with the racing industry and this piece is no exception. Designed for the discerning, upmarket buyer this is a classic timepiece that is just slightly different from the myriad of other chronographs on the market. And with a limited production of just 250 numbered edition pieces you can be fairly certain you won’t be seeing too many of these on the wrists of others.
The Girard-Perregaux Fly-Back Chronograph “Monte-Carlo 1973”: a fitting tribute to a most exceptional of races.
Technical specifications:
Stainless steel case
Diameter: 40.00 mm
Sapphire crystal
Case-back secured by 7 screws
Water resistance: 30 meters
Girard-Perregaux movement GP0337A
Frequency: 28,800 vibrations/hour (4 Hz)
Jewels: 63
Power reserve: minimum 46 hours
Alligator strap with folding buckle
Limited and numbered edition of 250 pieces
Presented in a case decorated with the “Automobile Club de Monaco” symbol
i palios
Has thanked: 2034 times
Been thanked: 1117 times
Re: Ποιό ξεχωρίσατε στην έκθεση???
Δημοσίευση από i palios »
Μπραβο Μαριε αυτο το ρολοι εντυπωσιασε κι εμενα.
Αλλα και τα αλλα τηs perregaux ηταν για μενα πολυ ομορφα,γενικα ειχε πολυ ωραια παρουσια οπως πραγματικα
της αξιζει. $0$$ :magn:
Θυμάμαι που το συζητήσαμε Γιάννη ότι σου άρεσε και σένα..... ;)
Been thanked: 9936 times
Μαριε πολυ ωραια ιδεα .... με βαζεις σε σκεψη να επιλεξω ΤΟ ΡΟΛΟΙ που μου εκανε την μεγαλυτερη εντυπωση..
δωσε μου χρονο να το σκεφτω
proestak
Been thanked: 1 time
Δημοσίευση από proestak »
Το extreme lab2 της jlc.Παναλαφρο παρα το μεγεθος του και πολυ ανετο στον καρπο.Μια τεχνολογικη βομβα της εταιρειας.
Μάριε, εννοείς "ποιο ξεχωρίσαμε" που θα φορούσαμε εάν και εφόσον είχαμε τα χρήματα να το αγοράσουμε??
Γιατί αντιλαμβάνεσαι ότι υπήρχαν μοντέλα που όσο τεχνολογικά ανεβασμένα και αν ήταν, μπορεί να μη "φοριόντουσαν" x: :slap:
ή εάν "φοριόντουσαν" να ήταν τόσο ακριβά που δεν θα μπορούσες ποτέ να βάλεις στο χέρι σου..... $0$$$$
Π.χ. μου άρεσε πολύ αυτό http://www.girard-perregaux.com/collect ... e=1&id=215 αλλά μάλλον δεν θα έδινα τα 25.000 € (άντε -20% 20.000 με την έκπτωση)! x: x:
vaggol
Δημοσίευση από vaggol »
Εγώ ξεχώρισα το bi-axial tourbillon της GP!! Ήταν θεσπέσιο θέαμα να βλέπεις το tourbillon να γυρίζει στους 2 άξονες! Μόνο το gyrotourbillon που είχε φέρει πέρυσι η JLC μπορούσε να συγκριθεί μαζί του! Δυστυχώς δεν το είχανε φέρει φέτος! Μια εικόνα του αξιολογότατου κομματιού της GP:
[rimg]http://img528.imageshack.us/img528/4437/60678778df.jpg[/rimg]
Uploaded with ImageShack.us
Ρώτησα και για την τιμή και μου είπανε μία τιμή κοντά στα 360.000 ευρώ! Τ' αξίζει όμως!!! Πάντως τα gyrotourbillon 1 & 2 της JLC είναι λίγο πιο φθηνά! Λίγο κάτω από 300.000 ευρώ! Όνειρα, όνειρα, όνειρα!!!!!!!!!!!!!!!!!!!!!
Ευάγγελος
Δυστυχώς δεν ήμουν στην έκθεση. Από τις φώτο στο αντίστοιχο thread, θα έλεγα ότι, παρόλο που δε μου αρέσουν τα πολύπλοκα, με εντυπωσίασε η τελευταία φωτο του chronoswiss. Επίσης κάποια JLC ήταν απίστευτα, αλλά αυτά τα ήξερα ήδη.
Ωραίες οι απαντήσεις σας παιδιά και κομματάρες όλα.........!!!!!!!!!! :good:
Ηλία αρχικά ας βάλουμε τι ξεχωρίσαμε τώρα αν θα γίνει και στόχος καλώς.............. ;)
proestak έγραψε:Το extreme lab2 της jlc.Παναλαφρο παρα το μεγεθος του και πολυ ανετο στον καρπο.Μια τεχνολογικη βομβα της εταιρειας.
Δεν μπορω να μη συμφωνησω :cheer:
