DAMASKO
DAMASKO
Επιτελους και η νεα inhouse calibre Α35 της Damasko με τα πρωτα μοντελα που την φορανε,DK-10 & DK-11!
Ειναι 42mm με display back για να φαινεται ο νεος πρωτοποριακος manufacture μηχανισμος.
Το 90% των εξαρτηματων oλοκληρου του ρολογιου ειναι φτιαγμενα απο την Damasko.
Λιανικη τιμη του μοντελου στα 2.990 ευρω.
-Πληροφοριες απο την Damasko για τη νεα καλιμπρα:
The properties of the EPS® material alone do not suffice to solve the phenomenon of asymmetric development of a flat spiral spring. For this reason, our team of researchers looked for a method and found one in a new type of end curve design, which could be realised within the oscillatory level of the spring. This is shown in an obvious thickening at the outer end, which forces the EPS® spring into a concentric development, as a result of which the transient and dying out oscillation occurs symmetrically to the centre of the spring on all sides of the oscillatory level. This ideal form of thickening was registered as a patent.
The EPS® spring is manufactured in one piece, which means that is has an integrated collet for fixation to the balance staff, and at the outer end it is “clipped” into the stud in a very precisely defined area. The minute clamping jaws of this stud are designed resilient, so that the clip-on point of the spring can still be corrected by pulling or pushing the spring through the stud. This new type of stud design was registered as a patent.
On conventional springs, the inner end is affixed to the collet by soldering, welding or clamping. This causes a structural modification of the spring material at the fixation points due to squeezing or heating, which on the other hand requires additional adjustment works.
With our EPS® spring, we have created an oscillating mechanism that provides multiple decisive advantages: the EPS® spring oscillates ideally concentric. It is designed for isochronism independently of the temperature, of the position of the movement and of magnetic fields.
EPS® springs with uniformly identical quality:
As in the case of the silicon escape wheel, the EPS® spring is produced in a DRIE (deep reactive ion etching) process, which is described in more detail at a later stage. The material has a uniformly fault-free polycrystalline structure and can be machined with tolerances in the micrometer range. Accordingly, all EPS® springs are of uniformly consistent and extremely high quality, which is transferred onto to the accuracy of the movements fitted with these.
The EPS® spring is the result of the consistent innovative policy of our manufacture. With this development, Damasko is amongst the leaders in innovation and at the same time sets decisive accents in order to furnish its novelties with an exclusiveness that is typical to the brand using significant distinguishing features. Also in the case of the EPS® spring, it is the objective of this innovative philosophy to increase the accuracy and stability of mechanical watches, as well as raise the durability and sustainable value of Damasko watches.
Damasko will still carry out numerous tests before this new EPS® spring can be integrated in wider serial production.
EPS® spring by Damasko at a glance
* Produced by deep reactive ion etching (DRIE) method and registered as a patent
* Concentric development that improves isochronism on the basis of a geometry that is registered as a patent
* Anti-magnetic
* Temperature compensation due to material properties
* Contrary to conventional springs, no thermal or mechanical impairment at fixation points
* Insensitivity to minor shocks
* Reduced sensitivity to centrifugal and gravitational forces, as the EPS® is three times lighter than conventional springs
* No impairment of movement rate due to recurrent minor shocks in daily use
* Complies with NIHS standards for coincidental standardised shocks
Re: DAMASKO
Φενετε πολυ ωραια και ποιοτικη δουλεια Θοδωρη....... :good: .....
....Ειναι εταιρια που μου αρεσει αρκετα...
....Κατι λεγαμε για και τα ''γερμανικα'' εχθες....αλλα οχι για τετοια τιμη.. :(
Re: DAMASKO
Ωραίο και πολυ ποιοτικο φαινεται! Αλλα απο τιμή..... αστα... :?
Re: DAMASKO
Θα συμφωνησω με τον Αντωνη..!
Πολυ ωραια και ποιοτικα, αλλα ακριβουτσικα..
Re: DAMASKO
Ειναι ακριβο παιδια,πραγματι!
Αυτο ειναι το τιμημα των in house! ;)
Marine master
Has thanked: 27 times
Been thanked: 78 times
Re: DAMASKO
Ναι είναι ακριβό με απόλυτες τιμές, όμως για σκεφτείτε πόσο κοστίζουν άλλα όχι in-house, αλλά modified μοντέλα μεγάλων οίκων;
Οίκων που πωλούν εκατοντάδες τεμάχια ανά έτος, αυτοί αν πουλάνε 40-50 το χρόνο και καλά θα λένε.
Δυστυχώς έτσι είναι με τα in-house.
Για το λόγο αυτό θα πρέπει να πληρώνουμε σεικόσημο και ετόσημο, γιατί μας έδωσαν καλό και σε λογική τιμή αυτόματο ρολόι....
(στο πίσω μέρος παιδιά το καπάκι γράφει "ατσάλι 60 HRC". Αυτό το ατσάλι είναι τόσο σκληρό που δεν χαράζεται με απολύτως τίποτα παρά μόνο με διαμάντι! Τόσο σκληρό είναι σχεδόν και το ζαφείρι!)
Κώστας
:robo:
mantilas
Been thanked: 2 times
Re: DAMASKO
Δημοσίευση από mantilas »
Μπραβο στη damasko μεγαλο βημα που αλλες αυτοκρατοριες του χωρου δεν τολμουν με τιποτα.Αν ηταν πιο φτηνο θα το χτυπουσα μονο και μονο για να στηριξω τετοιες προσπαθειες και για τη μοναδικοτητα του ρολογιου.Κι αυτη η μαγκια με το ατσαλι αξιζει.
Re: DAMASKO
Φίλε Θοδωρή τέτοια ανεβάζεις και μου βγαίνει η πίεση............ :cheer:
Πραγματικά ωραίο ποστ και προσεγμένο..........
Η Damasko τώρα έχει κάνει μεγάλο βήμα και σημαντικό για μένα....
πολύ καλή σαν δουλειά με ωραίο σύνολο και αν λάβουμε υπόψην παιδιά ότι είναι 90% inhouse δεν είναι και πολλά έτσι???????? :?
ωραίο φινίρισμα στις μηχανές επίσης...... :good:
Το πρώτο κομμάτι είναι κόλαση............ x:
militaire/vintage specialist
Been thanked: 105 times
Re: DAMASKO
Δημοσίευση από Blackbird »
Αν σκεφτούμε πως μιλάμε για τουλάχιστον δύο χρόνια σχεδιασμού, έρευνας, εξέλιξης και δοκιμών. Νέου εξοπλισμού, επιπλέον προσωπικού, συνεργασίας με πανεπιστήμιο, πληρωμής διεθνών πατεντών κι όλα αυτά σε γερμανικές τιμές, μάλλον αξίζει τα λεφτά του.
Εικόνα Εικόνα
Re: DAMASKO
Ο Κόνραντ ετοιμάζει και καταδυτικό.
Εικόνα Εικόνα
