Sinn
Re: Sinn
α γιατι ειδα τις τιμες στο λινκ και ηταν καλουτσικες και λεω μπλεξαμε παλι... ;)
desmo16
Been thanked: 80 times
Re: Sinn
Δημοσίευση από desmo16 »
103 St
Re: Sinn
ελα Αλεξ σταματα και μου αρεσει.... :rose
desmo16
Re: Sinn
marios_ch έγραψε:ελα Αλεξ σταματα και μου αρεσει.... :rose
:rap:
Been thanked: 10071 times
Re: Sinn
Αλεξανδρε μην σταματας ... θα τον κανεις να το παρει τελικα lol
Re: Sinn
πως σας φαινεται αυτο το μοντελο της Sinn ..903 κωδικος
Navitimer ιδιο ειναι :smile:
Re: Sinn
Τι σου κανει η οικονομικη κατασταση.
Η αντιγραφη παει συνεφο. Που λεφτα για σχεδιασμο νεων μοντελων. Βρε ουστ.
Re: Sinn
Sinn U212 SDR
By TLex Introducing the Sinn U212 SDR, A limited edition of 212 units, the U212 was tested and based on European diving equipment standards and was certified by Germanischer Lloyd, Hamburg. It's case is made of high-strength seawater-resistant German submarine steel with TEGIMENT Technology which allows it to be especially scratch-resistant.
Its black bezel with 'Black Hard Coating' is based on the same TEGIMENT technologies as its case. Its sapphire crystal boasts 'Ar-Dehumidifying Technology', which allows it to remain fog free. There's a small 'ar' logo on the dial at 9 o'clock. The watch has been tested to function reliably from –45 °C up to +80°C. Further features include: captive diver's bezel with minute ratcheting, crown at 4 o'clock to prevent pressure on the back of the hand, and water-resistance up to 1000 meters diving depth or 100bar.
From SINN The diving watch U212 is a professional mission timer which uses genuine German submarine steel, a material with extreme seawater-resistance and the highest level of non-magnetic properties. In the movement itself, functional reliability between -45 °C and +80 °C is ensured by the SINN special oil 66-228. And that's not all: with the captive diver's bezel, this diving watch is well-equipped to measure the duration of a dive accurately.
Fogging of the dial poses a safety risk when diving. To prevent this, we use EDR seals. This material, with its extreme chemical resistance and only a quarter of the gas permeability of conventional seals, prevents moisture from diffusing into the diving watch. The scratch-resistance sapphire crystal glass withstands even the highest pressures. The case is equipped with the Ar-Dehumidifying Technology.
http://oceanictime.blogspot.com/2012/07 ... 2-sdr.html
noel
Has thanked: 12 times
Been thanked: 63 times
Re: Sinn
Δημοσίευση από noel »
Megalos έγραψε:Image
aris911 έγραψε:Τι σου κανει η οικονομικη κατασταση.
Δεν πρόκειται για αντιγραφή φίλε Άρη.
Sinn's flight computer, the 903, was introduced after Sinn bought the rights to use the dial lay-out of Breitlings 806 and 809 Navitimer watches. This was a result of Breitling's bankruptcy in 1979. Unlike the Ollech & Wajs Aviation which was essentially a rebadged Breitling, Sinn used a different watch movement, the handwound Lemania 1873 which is the same movement the Omega Speedmaster used. This was chosen to match the "tri-compax" lay-out of the dial that Sinn now owned the rights to. A "tri-compax" chronograph has subdials at 3, 6, and 9 o'clock. Later, Sinn added automatic versions of the 903 using the Valjoux 7750 movement.
http://sliderulewatches.yvod.com/historyswiss1.html
nicolasg
Re: Sinn
Νικο αν καταλαβα απο τα λιγα αγγλικα η SINN αγορασε τα δικαιωματα παραγωγης απο την BRELTING (πραγμα που δεν ηξερα) Αλλα το μοντελο αυτο απο μακρυα φωναζη BRELTING. Μηπως θα ηταν καλυτερα τα λεφτα που εδωσε για αυτη την αγορα να τα δωση σε σχεδιαστες να της βγαλουν κανα ΝΕΟ ΔΙΚΟ ΤΗΣ ΣΧΕΔΙΟ και οχι να χρησιμοποιη αλλων.
