40 χρονια omega moonwatch
- warover
- Τοποθεσία: Χανια~Ηρακλειο
- Been thanked: 35 times
Wikipedia, the free encyclopedia
Omega Speedmaster
Jump to: navigation, search
For other uses, see Operation Moonwatch.
The Omega Speedmaster, the legendary "Moonwatch", selected by NASA for all the Apollo missions.
The Omega Speedmaster Professional, otherwise known as the "Moonwatch", is a manual winding chronograph introduced in 1957 and made famous by its selection by NASA for the Apollo Program. The Omega Speedmaster was the first watch worn on the moon, as Buzz Aldrin wore his Speedmaster 145.012 fitted with the Omega 321 caliber on 20 July 1969. (Neil Armstrong left his Speedmaster inside the landing module "Eagle" during his famous first walk). It is the only watch flight-qualified for EVA use by NASA [1]. It is also the watch chosen for use in outer space by the Russian space agency NPO Energia
History
When the step-by-step procedures of the Project Gemini space-walks were first mapped out, NASA realized that they did not have an approved wristwatch for space travel. The normal procedure of soliciting bids for the design, manufacture and testing of special “Space Proof” wristwatches was a time consuming process. To save time, NASA sent two systems engineers into downtown Houston “incognito” to purchase several reputable “off-the-shelf” chronographs to be tested for possible use in space. A manual-winding watch was preferred to an automatic watch, as it was assumed that zero-gravity conditions would render the self-winding mechanism ineffective.
Back of the Omega Moonwatch.
Five different brands of chronographs were purchased and returned to NASA for testing. The Speedmaster passed NASA's numerous tests, which included exposure to extreme temperatures, vacuum, intense humidity, corrosion, shock, acceleration, pressure, vibration and noise, whereas the Rolex, Breitling, Bulova, Longines and Heuer, notably, all failed[2].
The tests were completed on March 1st, 1965. At the completion of the tests, three of the chronographs from different manufactures were still running, but only the Speedmaster had passed without any of the serious discrepancies encountered with the others. The Omega Speedmaster was adopted by NASA as the “Officially Certified Wristwatch For All Manned Space Missions.” At this point, Omega was completely unaware of these activities.
The Omega Speedmaster was re-certified in 1972 and in September 1978, for the Space Shuttle missions.
Today, all NASA-issued wristwatches are government property and must be turned in once the astronauts return to Earth. Astronauts are permitted to check out the watches before launch and take them home to familiarize themselves with the watch’s operation.[citation needed]
και ενα λινκ για το μοντελο που βγηκε για την συμπληρωση 40 χρονων
http://www.luxist.com/2009/04/26/omega- ... ary-limit/
Omega Speedmaster
History
- Has thanked: 27 times
- Been thanked: 105 times
Re: 40 χρονια omega moonwatch
Γι' αυτό έβαλες τον Ίρβιν, ήθελες ψυχανάλυση.
Πίναπ ή Μουν; Ίδου το ερώτημα.
Δεν αφήνετε τα 40 χρόνια Moonwatch;
Σε λίγες ημέρες έχουμε 25 χρόνια από το δράμα της Κύπρου...
Αλλά ξέχασα. Αυτή δεν "φορούσε" LEMANIA!!!
ΥΓ. Πάντως κανείς σας δεν σέβεται τα copyrights. Υπάρχουν και θέματα που κάποιοι τα έχουν "αγκαζάρει". Που πας ρε Καραμήτρο, στο χωράφι του άλλου; Δεν βλέπεις ότι γράφει "ΑΠΟΚΛΕΙΣΤΙΚΟ"; Μάθαμε τώρα όλοι, Moonwatch, Lemania, 861, αστροναύτες και δεν συμμαζεύεται...
ΥΓ2 Να μην μου κόψει να γράψω εγώ "ΑΠΟΚΛΕΙΣΤΙΚΟ" στο WOW, για το θέμα...
Γιατί τα 100 χρόνια ROLEX, που ήταν το 2008 και δεν τα πήραν είδηση περιοδικά και φόρουμ! Εγώ το έβγαλα τον Δεκέμβριο και ήταν σαν να είναι μυστικό...
Πάντως δεν είναι 40 χρονών το μουν αλλά προϋπήρχε της προσελήνωσης που αυτή γιορτάζει τα 40 της.
- Has thanked: 48 times
- Been thanked: 194 times
Νια διορθώσω όχι τον Κωστή, γιατί πιστεύω ότι εκ παραδρομής γράφτηκε το 25 χρόνια αλλά για τα άλλα παιδιά του φόρουμ ότι είναι 35 χρόνια και όχι 25 το δράμα της Κύπρου...!!!VIWOW έγραψε:Δεν αφήνετε τα 40 χρόνια Moonwatch;
- Has thanked: 44238 times
- Been thanked: 9937 times
Σωστος ο Δημητρης οσον αφορα το ρολοι αυτου καθ'ευατου
και ο Μαριος οσον αφορα την Κυπιρακη τραγωδια (Κωστη αδιαβαστο σε επιασε ο μικρος )
τελος λογω επετειου λοιπον της προσεληνωσης παρτε ενα καταπληκτικο λινκ
http://wechoosethemoon.org/#
Σωστος ο Νικοςwarover έγραψε:Δημητρη ναι μεν αλλα μονο 40 χρονια λεγετε moonwatch δεν λεμε 40 χρονια speedmaster 3570
