GRAND SEIKO
- Has thanked: 44252 times
- Been thanked: 9937 times
Re: GRAND SEIKO
θα κυκλοφορησουν 140 κομματια , πλατινα , τιμη 60.000 ευρω και φανταστικος μηχανισμος με 80 ωρες λειτουργιας
Re: GRAND SEIKO
και αλλα νεα Grand Seiko ...
Grand Seiko Elegance GMT “24 Seasons” Collection
ειτε αυτοματα Hi Beat ειτε spring drive ειναι πανεμορφα ολα τους
Re: GRAND SEIKO
τα ρολογια αυτα θα κυκλοφορησουν τον Σεπτεμβριο φετος και τιμη 6.800 ευρω ... not bad
- Been thanked: 5277 times
Re: GRAND SEIKO
Πολύ ωραία και τα 2. Το πρώτο πιο ιδιαίτερο, το 2ο πιο κλασσικό. Το 1ο μου αρέσει καλύτερα. Ακολουθούν μια συγκεκριμένη σχεδιαστική γραμμή της GS, πολύ ωραία, αλλά όχι την πιο αγαπημένη μου σε GS dress.
- pugman
- Τοποθεσία: Αθήνα
- Has thanked: 1906 times
- Been thanked: 1824 times
Re: GRAND SEIKO
INTRODUCING: The Grand Seiko SLGH005 brings the 9SA5 to standard production in steel
Whenever I hear a new Grand Seiko is being released, I get all giddy inside. Like a child hoping to find a Nintendo Switch under the tree on Christmas morning, Grand Seiko novelties are highly anticipated by fans worldwide – and fortunately they never disappoint. We recently covered the 60th anniversary limited edition Grand Seiko SLGH003, celebrating the introduction of the new hi-tech 9SA5 caliber into a stainless-steel watch. It made this latest innovation more accessible to the masses than the previous precious metal SLGH002. The new Grand Seiko SLGH005 not only introduces yet another reference in stainless steel, but also marks the first time the caliber has been used in an ongoing production model – with a gorgeous “white birch” dial to make the offering that much more tempting.
The white textured dial is inspired by the white birch trees surrounding Studio Shizukuishi. The pattern is applied via a press pattern stamp, with tons of pressure applied to the dial base – similar to how the Snowflake and Mt. Iwate dials are fabricated. According to Grand Seiko, “Studio Shizukuishi, where all Grand Seiko mechanical watches are made, is surrounded by woodland areas boasting nearly 1000 wild-grown trees. These forested areas are maintained and preserved by the people of Shizukuishi, with the manufacturer itself also taking part in the region’s sustainability, nature, and the local community. It is only fitting then that nature continues to influence the designs of Grand Seiko’s creations”.
With the dial now white, versus the blue found in the SLGH003, instead of the ceremonious red hand found on the 60th anniversary watches here we have a hand-blued central seconds hand. To provide better contrast against the dial, the hands are now mirror polished which means that when light hits them straight on they will go darker against the bright dial. The hour hand is the same broader hand we saw on the SLGH003, with a sort of frosted line of texture that symmetrically splits the hand. The faceted mirror polished hour indices are channelled to give them each a great amount of depth to their design. The minutes track is stepped, radially indicated via the inner bezel. In this instance, the black on white date disc at 3 o’clock matches the dial – resulting in little break to the dial visual.
The stainless-steel case is the same design found on the SLGH003. Sized at 40mm in diameter and 11.7mm thick (including its boxed sapphire crystal), and 47mm lug-to-lug, the SLGH005 is one of the more slender timepieces from Grand Seiko and its compact lug-to-lug makes it the perfect size for a large spectrum of wrists. The bezel utilizes a flat satin brushed ring around the sapphire crystal that breaks into a mirror polished slope down towards the caseband and lugs. As a Series 9 design, the case utilises many satin-brushed surfaces with adjacent narrower distortion-free mirror polishes to provide aesthetic contrast and play with ‘light’ and ‘shadow’. While it by no means inelegant, Grand Seiko worked to make this design very sporty as well – and its screw-down crown and 100 metre water resistance further reflect that fact. With more brushed surfaces, over the course of daily wear it will better hide the scratches it may incur over time.
The bracelet is a broader 22mm format of the familiar five-piece link design that tapers down to 20mm as you reach the folding clasp. Like the SLGH003, the front of the bracelet is entirely satin brushed. Only the outer bevels of the shoulder links, and sides their sides, have received a mirror polish. This reiterates the sportier nature of the timepiece. Unlike the SLGH003, however, the Grand Seiko medallion on the clasp is rendered in stainless steel instead of contrasting gold. Being a stainless-steel watch, the links are secured by removable screws – so for those who are not the biggest fans of the pin and collar system you can let out a sigh of relief.
The caliber 9SA5 represents the pinnacle of 9 series caliber designs, a completely new design from the ground up that incorporates an entirely new dual-impulse escapement designed in-house. The twin barrel movement has 80 hours of power reserve, a hi-beat frequency of 36,000 vph, a new free-sprung balance, and new Grand Seiko overcoil hairspring distinct to the brand and perfected through over 80,000 simulations.
The culmination of the watch reflects what Grand Seiko has now distinguished as their Series 9 design. What is Series 9? According to Grand Seiko, “The Series 9 name echoes the number 9, which is used in the naming of all modern Grand Seiko calibers. The number 9 in Japanese is pronounced kyu, which is represented by the kanji symbol 九. Another kanji symbol 究極 — also pronounced kyu — translates to ‘the ultimate.’ This representation of the ultimate, along with 9 being the highest possible single digit number, signifies Grand Seiko calibers and this new series as being the ultimate in precision, legibility, durability, and beauty. These are the ideals behind Grand Seiko’s watchmaking philosophy.”
Grand Seiko SLGH005 pricing and availability:
The Grand Seiko Hi-Beat 36000 9SA5 Series 9 “White Birch” SLGH005 will be available starting this March and will be an ongoing addition to the Grand Seiko line up. The price will be $9,100 USD / $13,600 AUD, and will be available at Grand Seiko Authorized Dealers (Master Shops and Salons), Boutiques, and the GS9 Club Shop for members only.
https://timeandtidewatches.com/introduc ... and-seiko/" onclick="window.open(this.href);return false;
Re: GRAND SEIKO
Πανέμορφο και hi beat, που πολύ θα ήθελα να πάρω κάποια στιγμή, αλλά δεν το βλέπω σύντομα.
Re: GRAND SEIKO
ωραιοτατο Αντωνη μου κομματι της Grand Seiko ... το εχω ηδη αναφερει παλαιοτερα , οτι θα κυκλοφορησει τον Μαρτιο
- pugman
- Τοποθεσία: Αθήνα
Re: GRAND SEIKO
Αντωνη μου εξαιρετικο το βιντεο και το νεο Grand Seiko .... και αμφισβητηση των πρωτειων του snow flake .... πολλες σκεψεις δημιουργει το βιντεο αυτοpugman έγραψε:http://www.youtube.com/watch?v=uO6Cf9CTQTw
CkwatchV4
- Has thanked: 10 times
- Been thanked: 62 times
Re: GRAND SEIKO
Καλημέρα σε όλους το τελευταίο διάστημα με τη βοήθεια εφαρμογής που χρησιμοποιεί NTP time servers μετράω την χρονομετρία κάποιων ρολογιών μου. (Automic clock and watch accuracy tool with NTP time -- Android) όποιος ενδιαφέρεται για την εφαρμογή. Ήθελα να μοιραστώ μαζί σας τα πρώτα αποτελέσματα για το 5R65-0AC0 seiko Spring Drive s/n 5000219 μου. Αν και τυπικά δεν είναι grand seiko ουσιαστικά είναι καθώς είναι το πρώτο εμπορικά διαθέσιμο spring drive μοντέλο της εταιρείας αγορασμένο πριν από μια δεκαπενταετία περίπου αμέσως μετά την παρουσίαση του μηχανισμού στη Βασιλεία όπου είχε κερδίσει και το μεγάλο έπαθλο καλύτερου μηχανισμού ανεξαρτήτως κατηγορίας τιμής. Το ρολόι λοιπόν μετά από δεκαπέντε περίπου χρόνια κατοχής και με ένα σέρβις στο ιστορικό του πριν από δέκα έτη (στην Ιαπωνία από τους τεχνίτες της Grand Seiko) με δέκα ημέρες στο καρπό (το έβγαζα βράδυ και στο μπάνιο μόνο) έχει χρονομετρία +3,45 " / ημέρα. Αρκετά εντυπωσιακό θεωρώ δεδομένου και της παλαιότητας καθώς και το ότι κανονικά πρέπει να σταλεί εκ νέου για service λόγω χρόνων. Είναι το αγαπημένο μου ρολόι και αυτό που αν έπρεπε να κρατήσω μόνο ένα θα κράταγα.
