Omega
Has thanked: 44733 times
Re: Omega
Βασιλη πολυ ενδιαφερον το λινκ
και πολυ ομορφη η αφιερωση στο ρολοι του Προεδρου Νιξον
Re: Omega
αλλα και αυτο το Omega marine σκιζει
Re: Omega
και η Ω ανεβαζει τιμες παιδια το ειδα απο επισημο αντιπροσωπο στο WUS... απο 1η Ιουλιου... :(
Re: Omega
αρχισαν τα οργανα ... ποσοστο αυξησης Μαριε ??
Re: Omega
δεν διαβασα για ποσοστο Κωστα αλλα λογικα κοντα στο 10%... :?
Re: Omega
N E W M o d e l – Omega Seamaster Planet Ocean 600 Meters SKYFALL
Limited Edition of 5,007 Pieces
In SKYFALL, to be released in autumn of 2012, James Bond will take to the screen for the 23rd time with Daniel Craig again assuming the role of the world’s favourite secret agent. And once again, 007 will wear an OMEGA Seamaster
Like every Planet Ocean, the new watch is ready for underwater adventure. Equipped with a unidirectional rotating diving bezel and a helium escape valve, the watch is water resistant 60 bar / 600 metres / 2000 feet.
The watch has a 42mm brushed and polished stainless steel case and a matching patented screw-and-pin bracelet whose divers’ clasp is engraved with “007”. The rotating diving bezel is distinguished by its matt black ceramic ring with a chromium nitride diving scale.
The applied indexes on the matt structured black dial are coated with white Super-LumiNova emitting a blue light as are the polished, facetted rhodium-plated hands. The exception is the minute hand which emits a green light, as does the dot on the diving bezel. This feature makes it easy for divers to keep track of their time at a glance. At the 7 o’clock position is a 007 logo and at 3 o’clock, there is a date window.
The Seamaster Planet Ocean 600M SKYFALL Limited Edition is powered by OMEGA's exclusive new Co-Axial calibre 8507. SKYFALL 007 is on its rotor in black-varnished engraving. The movement is visible through sapphire crystal in the brushed screw-in caseback.
Along with OMEGA’s industry-changing Co-Axial technology, the watch is equipped with an "Si14" silicon balance spring. The combination is so stable and reliable that the Planet Ocean comes with a full four-year warranty.
The Seamaster Planet Ocean 600M SKYFALL wristwatch is being delivered in a special presentation box.
http://forums.timezone.com/index.php?t= ... sg_6179434
Has thanked: 330 times
Re: Omega
Δημοσίευση από lovefist2001 »
Το ειδα το καινουργιο 007 !!
Κουκλι ειναι αλλα ξεφυγαν στις τιμες !!!!
:gf: :gf: :gf:
Σταυρος
Re: Omega
εστω και καθυστερημενα τωρα που το βλεπω ειναι απιθανο το νεο 007 Omega ...ωραιος στοχος :rose
n_wildgirl
Been thanked: 79 times
Re: Omega
Δημοσίευση από n_wildgirl »
5007 κομμάτια...ΤΡΟΜΕΡΟ! :BB:
Τόσο ωραίο ρολογάκι, χάθηκε ο κόσμος να βάλουν από κάτω ένα ωραίο KTM; Τι είναι αυτός ο ξεβαμμένος κουβάς; :o
Νεφέλη
Re: Omega
ειναι το στυλ Νεφελη.... :BB: :BB:
