Divers watches
Argo982001
Has thanked: 642 times
Been thanked: 506 times
Re: Divers watches
Δημοσίευση από Argo982001 »
Απο τα πιο ομορφα σπορ ρολογια αν οχι ΤΟ πιο ομορφο!!!!!
Been thanked: 9997 times
Re: Divers watches
Argo982001 έγραψε:Απο τα πιο ομορφα σπορ ρολογια αν οχι ΤΟ πιο ομορφο!!!!!
+ 100 .. συμφωνω ... ποσο παει απο τιμη Βασιλη ?
Re: Divers watches
stavros_ch έγραψε:CHRIS BENZ Deep 1000M Auto SSI-EDITION
http://oceanictime.blogspot.com/2012/04 ... ition.html
Σταυρο ωραιοτατο αυτο ..ποσο παει ξερεις ?
Re: Divers watches
425 ευρω με την αποστολη Κωστα.
Re: Divers watches
stavros_ch έγραψε:425 ευρω με την αποστολη Κωστα.
καθολου ασχημα ... ευχαριστω
Re: Divers watches
ZIXEN Zulu & Zulu UTC
By TLex ZIXEN reveal their latest special project, the new Zulu UTC Automatic, and Zulu Diver Automatic. The exclusive in-house case design is a ZIXEN first, 42mm with a unique coin edge bezel design. The renderings shown here have been finalized, they are based on the research and input from a number of contributors, which include active armed forces personnel as well as WUS forum member.
The Zulu will have a comfortable foot print at 42mmx 49.5mm with total depth of just 13.0mm. The design philosophy behind the ZULU say Zixen '' has been purely, form and function for military application, as well as for the weekend worrier''. They wanted the ZULU to be visible, with a high level performance and precision, with an exceptional optical quality Sapphire crystal, extreme recoil resistance and down range effective in low-light visibility.
The ZULU houses a Swiss ETA caliber adjusted and regulated for accuracy. The design of the watch, a durable solid 316 marine grade Stainless steel with a three piece case constructions and a steel movement housing. It has a water-resistance to 30 ATM, or 300 meters / 1000ft. Further features include: a screw-down type crown, a 4mm coin-edge bezel design for effective grip and manipulation. The bezel is a 120-click type.
The UTC offers smooth independent setting of the time. It is available in variety of dial and hand combinations with a UTC 24 hour or 12 hour time only function. It will be supplied on premium NATO Ballistic nylon strap, or a ZIXEN high quality 4mm HD mesh bracelet. It comes with a Limited full two year warranty, backed by ZIXEN support and service. Initial production will be 100 units. Total production will be limited to just 300 pieces with a estimated delivery time in fall 2012.
Pleasase follow the ZIXEN logo below for further details, special pricing and pre-ordering instructions. Follow the ZIXEN Zulu on WUS . . .
http://oceanictime.blogspot.com/2012/04 ... u-utc.html
Re: Divers watches
Πολυ μαχιμο αυτο το Zixen!
Argo982001
Re: Divers watches
Απο τιμη Κωστα το ap diver εχω καιρο να κοιταξω αλλα νομιζω γυρω στα 13000....(μη λεω και λιγα)....
Re: Divers watches
Argo982001 έγραψε:Απο τιμη Κωστα το ap diver εχω καιρο να κοιταξω αλλα νομιζω γυρω στα 13000....(μη λεω και λιγα)....
ευχαριστω Βασιλη ... ωραιοτατο ειναι παντως
Re: Divers watches
HEXA K500 Prototype
By TLex This week I had the honor and privilege of being the first person outside of Hexa Watches to have the opportunity to spend some quality time with the Hexa K500 prototype watch. I have worn the watch solidly for the last few days and have grown quite fond of it.
However before sending the K500 to me Hexa carefully scrutinized it, highlighting anything that they felt could be improved upon or enhanced. Below is a list their revisions . . .
* The crown length will be extended by approximate 1mm to improve ease of use, this will allow the crown to protrude very slightly for a more comfortable grip when screwing-down.
* The Hour and Minute Hands will be painted in gray, as per the original renderings.
* The casebacks will be customized with art, which is yet to be revealed along with its serial number.
* The second hand will be beefed up a bit and will have a slightly larger lume area.
* The date window's angle will be corrected on the production models so that it is properly aligned with date wheel.
* The date wheel will be in black with white numbers.
* The lume will be of a higher quality for the production models.
* The bezel action will be made slightly tighter.
* Production models will have respectively matching crown finishes.
Now that we know what changes will be made for the production watches - what did I think of the prototype myself? The first thing that struck me about the K500 was its design, utilitarian and ever so slightly quirky. This watch will lend itself beautifully to either a bead-blasted or PVD finish.
You can tell that it has been designed from the ground up, it really is quite different from anything that I've come across. Yes, there are some gentle notes of the Sinn U models, but that's fine with me, who doesn't like block hands?!
It's quite difficult to pin the case design down really; it looks like two completely different watches depending on which side profile you're looking at.
The bezel is lovely and high, the bezel teeth are widely spaced to give a really chunky appearance. I found the bezel action very reasonable actually, but Hexa want to improve upon this so that it's even tighter. The bezel pip and markings are nice and crisp. I would like the markings even more if there was less of them though.
http://oceanictime.blogspot.com/2012/05 ... otype.html
