A.Lange & Sohne
Has thanked: 1925 times
Been thanked: 1839 times
Re: A.Lange & Sohne
giannistissot (Κυρ Απρ 14, 2019 9:47 pm) • Megalos (Κυρ Απρ 14, 2019 10:35 pm)
Been thanked: 9997 times
Re: A.Lange & Sohne
καλα παιδια ... απιθανο ρολοι το Lange ... τελειο φινιρισμα και απιθανος μηχανισμος
ευχαριστουμε Αντωνη :cheer:
Re: A.Lange & Sohne
Introducing The A. Lange & Söhne Lange 1 Time Zone '25th Anniversary'
The distinctive travel watch gets a sleek blue-and-silver treatment.
Quick Take
This is the fifth watch in A. Lange & Söhne's 10-watch series of limited editions, celebrating the Lange 1's 25th anniversary. So far we've gotten one per month since SIHH in January, including the Lange 1, the Grande Lange 1 Moon Phase, the Little Lange 1, and the Lange 1 Tourbillon Perpetual Calendar. This piece sits somewhere between the unbelievably complicated Tourbillon Perpetual Calendar and the more sober time, date, and power reserve models, showing a second time zone on a small dial down around five o'clock. You can quick adjust the second time zone using the extra pusher set into the case band, with the city ring traversing the outer edge of the dial in sharp jumps.
As with the other 25th anniversary models, what makes this watch different from the main collection versions of the Lange 1 Time Zone is the use of a white gold case paired with a silvered dial, blue printed numerals, and blued steel hands. Finishing things off is some extra engraving on the movement that utilizes blue scroll patterns, and a "25" that recalls the outsize date display on the front. Only 25 numbered pieces are being made, and they're sure to go quickly.
Initial Thoughts
I must sound like a broken record at this point, but I really dig this aesthetic treatment for the Lange 1 25th anniversary models. It's distinctive, it nods to a collector-favorite model from the brand's past, and it doesn't scream "This is an anniversary watch!" at everyone who passes by. The Lange 1 Time Zone has been covered in-depth here on HODINKEE before, and it's one of the more polarizing Lange 1 variations out there. Personally, I'm a fan – I like travel watches in general, and I happen to think this unusual execution is both beautiful and easy to use. I also love the execution of the movement finishing here, with the extra bridges giving Lange's watchmakers even more surfaces to decorate. Something to note is that this is one of the larger Lange 1 models, coming in at 41.9mm across and 10.9mm thick, so you'll need a slightly larger wrist to rock it.
The Basics
Brand: A. Lange & Söhne
Model: Lange 1 Time Zone "25th Anniversary"
Reference Number: 116.066
Diameter: 41.9mm
Thickness: 10.9mm
Case Material: White gold
Dial Color: Solid silver with argenté finish
Indexes: Printed numerals
Lume: None
Strap/Bracelet: Blue alligator leather strap with white gold prong buckle
The Movement
Caliber: L031.1
Functions: Hours, minutes, seconds, second time zone with cities ring, day/night indicators for home time and travel time, outsize date, and power reserve indicator
Diameter: 34.1mm
Thickness: 6.7mm
Power Reserve: 72 hours
Winding: Manually wound
Frequency: 3 Hz (21,600 vph)
Jewels: 54 (4 in screwed gold chatons)
Pricing & Availability
Price: $52,800
Availability: Now
Limited Edition: 25 pieces
πηγή: https://www.hodinkee.com/articles/a-lan ... ntroducing" onclick="window.open(this.href);return false;
Megalos (Δευ Ιουν 10, 2019 10:14 pm)
Re: A.Lange & Sohne
καλα τελειο ρολοι αυτο το Lange .... αριστουργημα μηχανισμος .... και πραγματικα λιγα κομματια ...
ισως για αυτο και να αξιζει τα λεφτα που ζητανε :smile:
Re: A.Lange & Sohne
πολυ ομορφο η αναγραφη των 25 ετων στον μηχανισμο ετσι !!
giannistissot (Σάβ Ιούλ 13, 2019 11:26 pm)
Re: A.Lange & Sohne
Πολύ ωραίο!
Re: A.Lange & Sohne
πολυ ομορφο το νεο κομματι της A. Lange & Shone ...1815 annual calendar
ppana (Σάβ Αύγ 03, 2019 10:44 pm)
Re: A.Lange & Sohne
ομως ομορφοτερο ειναι το πισω μερος με τον εξαισιο μηχανισμο του
giannistissot (Σάβ Αύγ 03, 2019 9:38 pm) • ppana (Σάβ Αύγ 03, 2019 10:44 pm) • gep (Σάβ Αύγ 03, 2019 11:27 pm)
Re: A.Lange & Sohne
Πράγματι αγαπητέ Κώστα, έργο τέχνης, πολύ όμορφο και στις 2 όψεις!
Re: A.Lange & Sohne
Και νάτο το ατσάλινο ....
Megalos (Παρ Οκτ 25, 2019 10:03 pm) • ppana (Κυρ Οκτ 27, 2019 11:19 am)
