Perrelet
Re: Perrelet
Εδω ο κοσμος και καιγεται και το μ@υνι χτενιζεται...και μην μου πειτε οτι δεν παει η παροιμια για το συγκεκριμενο ρολοι...
Θα μας τρελανει τελειως η Perellet.
- Has thanked: 48 times
- Been thanked: 194 times
Re: Perrelet
PERRELET - Peripheral Double Rotor
The Double Rotor plays a new trick.
Press release
Perrelet’s Double Rotor specialty is now interpreted in an original new way, giving rise to a collection radiating a subtly structured and eminently contemporary style. The upper rotor takes the form of a ring rotating above the movement, around its periphery.
It appears behind hour-markers forming arches between the central dial and the upper bezel ring, creating a slightly plunging effect. The lower rotor also features a specific design, with an open-worked P for Perrelet along with a Côtes de Genève motif. The twin rotors work together to wind the new proprietary Caliber P-341, driving the hour, minute, seconds and date functions.
Such an original concept merited an original architecture, and the Peripheral Double Rotor becomes the signature of a dedicated collection distinguished by a cut-corner cushion-type case echoed by the crown. The fluted case middle tapers gently towards the back, thereby reducing its amplitude against the wrist. This refined construction highlights the three-level dial and its contrasting geometrical patterns: grid-work center, oblique fluted rotor and rectangular minute track.
For its launch, the Peripheral Double Rotor is being introduced with 42 mm-diameter cases in steel, DLC-coated steel or gold (18k), available with a several variety of lateral inserts and dial versions.
Technical specifications - Peripheral Double Rotor
Movement: Mechanical self-winding, new proprietary Caliber P-341 Double Rotor / A Perrelet exclusive.
Functions: Central hands indicating hour, minute and sec- onds, date at 6 o’clock.
Case: Steel, DLC-Coated steel or gold, diameter 42 mm, thickness 13.15 mm, anti-glare sapphire crystal (front & back).
Water resistance: 5 ATM
Strap: Black alligator strap, steel folding clasp.
http://www.worldtempus.com/en/news/top- ... ble-rotor/
Press release
Re: Perrelet
Δεν μου αρεσε ποτε κανενα κομματι αυτης της εταιρειας..
Και αυτο το διπλο ροτορα δεν μπορω να τον καταλαβω..
Re: Perrelet
PERRELET Turbine DIVER
By TLex Here's sneak peek of the new PERRELET Turbine DIVER. More to follow soon . . .
http://oceanictime.blogspot.com/2012/03 ... diver.html
Re: Perrelet
N E W M o d e l – Perrelet Turbine Diver
To explore the world’s fascinating seabeds, the Turbine watch adopts an original design that is as symbolic as it is functional. The rounded contours of the 11-blade upper rotor subtly evoke a submarine propeller.
Spinning freely above the SuperLuminova-coated surface, it creates the illusion of an entirely luminescent dial that naturally gains intensity at night or in the darkness prevailing at great depths. Dive times are measured by a rotating inner bezel ring on which the average 20-minute duration stands out clearly thanks to a play on colors and volumes. it is controlled by userfriendly crown at 10 o’clock equipped with a locking system. The Arabic numerals, the main hour-markers as well as the subtly black-rimmed hour and minutes hands are also coated in Superluminova, thus enabling them to stand out against the background when it is lit up by the effect of the turbine in motion.
The strong personality of the Turbine Diver is accentuated by a 47.5 mm-diameter case water-resistant to 300 meters and designed especially for this model. The fl uted caseband is distinguished by four “paws” straddling the bezel, and the integrated winding crown is offset at 4 o’clock symmetrically opposite its counterpart controlling the rotating bezel. The sapphire crystal set into the screw-in caseback provides an admirable view of the automatic P-331 movement developed on the basis of the new Manufacture-made Alternance 10 caliber with its Côtes de genève motif. The Turbine Diver line is being launched in monochrome (steel) or two-tone (steel/black DLCcoated steel) cases framing a variety of colorful dials.
The case, in stainless steel, measures 47.50 mm x 14.82 mm. It has an AR-coated sapphire crystal. Rubber strap with stainless steel pin buckle.
Mechanical self-winding, P-331 Double Rotor, a Perrelet exclusive. Functions Central hour, minute and seconds hands. Water resistance to 300 meters.
Thanks.
http://forums.timezone.com/index.php?t= ... sg_6106494
Thanks.
Re: Perrelet
Kαλα,αμα καταφερει ποτε να διαβασει κανεις αυτο το καντραν μεσα στο βυθο,τηλεφωνηστε μου
Re: Perrelet
+1000eisenberg έγραψε:Kαλα,αμα καταφερει ποτε να διαβασει κανεις αυτο το καντραν μεσα στο βυθο,τηλεφωνηστε μου
