Audemars Piguet
Has thanked: 44733 times
Re: Audemars Piguet
ευχαριστω και τους δυο σας :sh:
μου φαινεται παρα πολυ ωραιο κομματι και με ενδιαφερουσα complication :rose
γιατι αραγε δεν το βλεπουμε συχνα ?
Re: Audemars Piguet
Megalos έγραψε:ευχαριστω και τους δυο σας :sh:
Κώστα άστο καλύτερα δεν κάνει ....
δεν πρέπει να ειναι πολύ καλό ... δεν έχω δει να κυκλοφορούν πολλά απ αυτά ..... :BB: :BB: :BB:
Re: Audemars Piguet
captain έγραψε:
haha haha
Been thanked: 12539 times
Re: Audemars Piguet
Introducing The Audemars Piguet Royal Oak Frosted Gold In 41mm (Finally)
Well, Audemars Piguet has done it again. Today I introduce to you the Royal Oak Frosted Gold in 41mm. If you are anything like me, I know you have been dreaming of this since my last Hands On with the 33mm and 37mm Royal Oak Frosted Gold in rose and white gold. Well, now the iconic manufacture has released a limited edition version of this sparkly number in 41mm for those of you looking for size and sizzle.
The Audemars Piguet Royal Oak Frosted Gold now comes in a 41mm white gold case.
The Royal Oak Frosted Gold was originally introduced at SIHH 2017. It is produced by a hammering technique utilized by Florentine jeweler, Carolina Bucci, that "frosts" the gold prior to assembly; the technique involves striking the gold surface repeatedly with a diamond-tipped tool, which leaves faceted impressions on the surface. It debuted in white and rose gold, in 33m and 37mm sized cases, with a quartz movement and the automatic caliber 3120, respectively. In addition to the smaller versions, we saw one larger version on the wrist of Audemars Piguet's CEO, Francois-Henry Bennahmias, which was clearly a prototype.
In addition to a larger case, the watch also has a blue tapisserie dial and automatic caliber 3120 movement.
Now the 41mm version can be yours. It comes in white gold only, and has a blue tapisserie dial. It's powered by the automatic caliber 3120 movement (same as the 37mm version). It is a limited edition with 200 pieces, so if you're feeling fancy, you had better act fast. This model is priced at $55,000; check out the Frosted Gold models, as well as a video from AP showing the actual process and case and bracelet assembly, at audemarspiguet.com.
πηγή: https://www.hodinkee.com/articles/audem ... ntroducing" onclick="window.open(this.href);return false;
Megalos (Τρί Οκτ 10, 2017 9:28 am)
Re: Audemars Piguet
ενδιαφέρον, χαμός γίνεται με τα υλικά!
Re: Audemars Piguet
Ίσως το πιο ωραίο royal oak!
ΕικόναΕικόναΕικόναΕικόνα
Στάλθηκε από το SM-J710F μου χρησιμοποιώντας Tapatalk
Megalos (Δευ Νοέμ 20, 2017 10:25 pm)
diomidis
Has thanked: 3 times
Been thanked: 211 times
Re: Audemars Piguet
Δημοσίευση από diomidis »
Argo98 έγραψε:Ίσως το πιο ωραίο royal oak!
Με το μαυρο tapisserie νομιζω ειναι πιο ομορφο κ πιο classy
Στάλθηκε από το SM-N950F μου χρησιμοποιώντας Tapatalk
Re: Audemars Piguet
Αναφέρεσαι στο 15400..Αυτό είναι το qeii cup 2017..βγαίνει μόνο με αυτό το dial,κάσα από τιτάνιο και κεντρικά λινκ του μπρασελέ και μπέζελ από πλατίνα!!Στη φωτό μπορείς να το ξεχωρίσεις από το μπέζελ που είναι γυαλισμένο και όχι βουρτσισμένο.Απίθανο κομμάτι!!
Υγ:Στο 15400 ακόμα δεν έχω αποφασίσει ποιο dial προτιμώ..μπορεί και το γκρι ..
Re: Audemars Piguet
Καταπληκτικό! Και ιδιαίτερο!
Νομίζω και εμένα οι εκδόσεις με μαύρο καντράν μου αρέσουν καλύτερα, αλλά αυτό είναι πιο ιδιαίτερο!
Re: Audemars Piguet
ωραιοτατο Βασιλη μου .... ομολογω οτι και εγω οπως ο Κωστας θα το μπερδευα με το 15400 ..
πολυ σημαντικες οι επισημανσεις σου ... ευχαριστω φιλε :cheer:
