Piaget
Re: Piaget
The Piaget Emperador Coussin Grande Lune "Planisphère"
http://piaget.watchprosite.com/show-for ... 41558/s-0/
Re: Piaget
PIAGET - For Florence And The Machine
http://www.worldtempus.com/en/news/top- ... e-machine/
Been thanked: 9997 times
Re: Piaget
marios_ch έγραψε:The Piaget Emperador Coussin Grande Lune "Planisphère"
παιδια επειδη τωρα ειδα το ανωτερω κομματι ειναι μουρλια
νομιζω οτι η εν λογω εταιρεια αδικειται... εχει εξαιρετικα κομματια , ομορφα και με μηχανισμους
δουλεμενους τελεια .... ας μην την ξεχναμε :good: :good:
Re: Piaget
Piaget Emperador Coussin Regulator
Hi All,
I wanted to share with you my observations on the Piaget Emperador Coussin Regulator. At least that’s what I’m calling it – to Piaget it is the GOA34024. I only had a few minutes in the Piaget Boutique so I grabbed the two watches that caught my eye: the limited edition Rectangle à l’Ancienne that I showed you recently, and this anthracite / grey dialled regulator.
The grey tones of the watch, with the contrasting alligator strap and 18K white gold case really gives it a sleek, modern feel on the wrist. The contrasting round and rectangular shapes and the brushed and polished surfaces contribute to this as well. The case diameter measures 42mm, but the watch wears smaller because of the wider bezel. The watch is also available in RG with a blue dial, but this example is more subdued and versatile.
The 30 second retrograde seconds display at 12 o’clock animates the dial and the regulator, with a large central minutes hand and hours shown at 6 o’clock, add visual interest. The dial has a brushed satin finish which nicely focuses the eye on the information presented. The affixed baton markers are in WG and there is a WG folding clasp befitting the more sporty nature of the piece.
The manual wind Calibre 835P is visible through a sapphire case back. This movement has a thickness of just 3.9mm. The large single barrel powers the watch for 60 hours and it has 27 jewels and beats at 21,600vph (3Hz). It features circular Côtes de Genève with blued screws, perlage on the mainplate and hand bevelled bridges.
The WG Emperador Coussin Regulator was less attention grabbing than the RG/blue dialled Rectangle à l’Ancienne that you know I loved, but as a daily wearer it is a lovely versatile piece.
http://piaget.watchprosite.com/show-for ... 62663/s-0/
DragonAce
Τοποθεσία: Ηράκλειο
Has thanked: 184 times
Been thanked: 225 times
Re: Piaget
Δημοσίευση από DragonAce »
δε την είχα ξαναδεί αυτή τη κάσα! δε μπορώ παρα να συμφωνήσω απόλυτα με τον Κώστα!
Re: Piaget
τι φινιρισμα παιδια στο μηχανισμο ετσι ... πολυ τεχνη η Piaget .. :good:
Re: Piaget
SIHH 2012 - Piaget Altiplano Skeleton Ultra-Thin
The Piaget Altiplano Skeleton Ultra-Thin boasts a double world record: the world’s thinnest self-winding skeleton model (5.34 mm) houses the world’s thinnest self-winding skeleton movement (2.40 mm).
The Piaget 1200S ultra-thin skeletonised movement is designed, developed and produced by the Manufacture de Haute Horlogerie Piaget.
It took over three years of research and development to fine-tune the Piaget Calibre 1200S, as it comprises a number of innovations, including the micro-rotor in 950 platinum, a new balance-bridge that contributes to a symmetrical new aesthetic, and a new hour-wheel bridge that has been slimmed down (to a minimum wall thickness of just 0.11 mm) in order to ensure the extreme thinness. The movement is further enhanced by truly exceptional decoration work, including the alternation between matte surfaces – sunray brushed or sandblasted – creating a contrast with the polished angles and the varied rhodiumed or black colours. The new Piaget Calibre 1200S is housed within a 38 mm-diameter white gold case specifically designed and developed to accommodate it.
http://forums.timezone.com/index.php?t= ... sg_6006592
Re: Piaget
απιθανος μηχανισμος και κυριως λεπτοτατος :magn:
pontioz
Been thanked: 1232 times
Re: Piaget
Δημοσίευση από pontioz »
marios_ch έγραψε:PIAGET - For Florence And The Machine
Λάθος τίτλο βάλανε στη φωτό!
Ο σωστός είναι:
"Piaget: αθάνατο ρολόι! Το φοράνε και τα βαμπίρ..."
Πισγιουνίκ.
Re: Piaget
haha haha :cheer:
