Zenith
Been thanked: 10000 times
Re: Zenith
Θοδωρη πρεπει να βαλεις ενα Zenith στην συλλογη σου φιλε ...
Re: Zenith
Megalos έγραψε:Θοδωρη πρεπει να βαλεις ενα Zenith στην συλλογη σου φιλε ...
Κι εσύ Κωστή μου ένα Βreitling :rose
omegasnik
Been thanked: 96 times
Re: Zenith
Δημοσίευση από omegasnik »
Κώστα & Γιώργο
και οι δύο ΣΩΣΤΟΙ! χαχαχα
Νίκος
Χρόνου Φείδου!
Re: Zenith
Πρωτα εχει σειρα το Navitimer,και μετα γιατι οχι ενα Ζενιθ,ειδικα τωρα που βγαζει και μερικα κομματια της προκοπης!
Re: Zenith
ετσι ...ετσι ... που λεει και η διαφημιση ... σιγα σιγα θα ερθει και το Zenith
Re: Zenith
Re: Zenith
Baselworld 2012: Zenith El Primero Chronomaster 1969 Watch
In 2012 Zenith will broaden its popular El Primero Chronomaster line of models with 2 new models, the El Primero Chronomaster 1969 and the El Primero Chronomaster Open Grande Date Moon & Sunphase. First let’s take a closer look at the Chronomaster 1969, a watch that reflects both Zenith’s rich heritage and its return to respectable watchmaking in recent years.
As with the original 1969 El Primero model, the 30-minute and 12-hour counters (at 3 and 6 o’clock respectively) feature the same colours as the original 1969 El Primero model. This watch has a new El Primero movement in the form the Calibre 4061, beating at 36,000vph (higher frequency movement than many). You can also see — and this is a Zenith “first” — a partially cut-away of the dial through the beating heart of the movement can be seen. This open-heart construction reveals the work of Zenith movement design engineers and watchmakers who redesigned the movement’s escapement to sit at 10 o’clock. The Zenith El Primero Chronomaster 1969 Chronograph comes presented on a rubber-lined alligator strap with either pin buckle or optional triple folding clasp. A perfectly sized watch with an awesome dial — nicely done, Zenith.
42mm stainless steel case, (new) automatic mechanical manufacutre Zenith El Primero Caliber 4061, midnight blue or anthracite dial
Alligator leather strap with protective rubber lining black alligator leather
Ref.: 27.00.2118.496
Stainless steel buckles Stainless steel pin buckle
Ref.: 27.01.0018.008
Stainless steel triple folding clasp (optional)
Ref.: 27.03.0138.940
http://blog.perpetuelle.com/watches/bas ... 969-watch/
Has thanked: 330 times
Re: Zenith
Δημοσίευση από lovefist2001 »
:magn: :magn:
:crazy:
Αυτα ειναι :TND:
Σταυρος
Re: Zenith
Felix Baumgartner ready for freefall from edge of space
http://news.watchprosite.com/?show=foru ... fi=112&s=0
Re: Zenith
Στα βηματα του moon $0$$
