Cartier
- Has thanked: 3865 times
- Been thanked: 2412 times
- Has thanked: 44448 times
- Been thanked: 9995 times
Re: Cartier
ενα νεο κομματι απο την Cartier πλατινενιο
Tank-Louis-Cartier-Limited-Edition-Blue-laser-Dial-Art-Deco
TheWatchBuddies
- Been thanked: 752 times
Re: Cartier
The Return of the Cartier Tortue Monopoussoir Chronograph
One of Cartier's most desirable watches, better known for its 2000s CPCP version, is back with new mechanics and a refreshed design.
The 2024 Cartier Privé Tortue Monopoussoir Chronograph will be produced in 200 platinum and 200 yellow gold pieces. Each is delivered with two interchangeable straps. Prices will be EUR 46,000 or CHF 49,100 in gold and EUR 53,000 or CHF 57,000 in platinum. It is far from accessible, but in the meantime, the CPCP models have also gone up drastically.
TECHNICAL SPECIFICATIONS – CARTIER PRIVÉ TORTUE MONOPOUSSOIR CHRONOGRAPH
Case: 34.8mm width x 43.7mm length x 10.2mm thickness - 950 platinum or 18k yellow gold case, polished - crown set with a ruby or a sapphire cabochon - sapphire crystal - caseback secured by 8 screws with sapphire crystal - 30m water-resistant
Dial: silvered opaline dial and snailed counters (platinum version) or grained gold-finish dial and snailed counters (gold version) - blued-steel apple-shaped hands - applique Roman numerals for the platinum model, transferred Roman numerals on the gold model
Movement: calibre 1928 MC - proprietary movement manufactured by an external partner (undisclosed) - hand-wound - classic column-wheel and horizontal clutch architecture, monopusher chronograph - 44h power reserve - 28,800 vibrations/hour - 4.3mm thickness - hours, minutes, small seconds, chronograph with central seconds and 30-minute counter
Strap: semi-matte burgundy red and shiny grey alligator leather interchangeable straps, platinum ardillon buckle - semi-matte blue and dark blue alligator leather interchangeable straps, yellow gold ardillon buckle
References: platinum - CRWHTO0008
yellow gold - CRWHTO0007
Availability: limited to 200 pieces per version
Price: EUR 46,000 or CHF 49,100 in gold
- These users thanked the author TheWatchBuddies for the post:
- Megalos (Τρί Απρ 09, 2024 10:02 pm)
Re: Cartier
πανεμορφος χρονογραφος .... ιδιαιτερος .... και τιμες θα ελεγα λογικες για αυτο που προσφερουν
ευχαριστουμε Αλεξανδρε για την ενημερωση
TheWatchBuddies
Re: Cartier
The New Santos de Cartier Dual Time
It makes perfect sense for the world’s first custom-made pilot’s wristwatch to be equipped with a dual-time function. Fair enough, Brazilian aviator Alberto Santos-Dumont probably didn’t cross too many time zones in his early flying machines, but combining the iconic Santos watch designed for him by Louis Cartier with dual time indications is a match made in heaven. Not to be confused with the Santos-Dumont lineup of slimmer, flatter and more elegant models inspired by the historic 1904 original, this Santos de Cartier novelty belongs to the revamped 2018 family. The latest Cartier Santos Dual Time, often described as Cartier’s vision of a luxury sports watch, is the first member of the contemporary Santos family to receive a dual time complication.
Displaying iconic Cartier Roman numerals, a railway minutes track and sword-shaped hour and minute hands, the dial has an elegant anthracite colour with a silky sunray-brushed finish. To stand out against the grey dial, the Roman numerals are silver, matching the handset. The date window has been repositioned at 3 o’clock to incorporate the dual time complication and blends into the scenery with its grey background.
Offering two different time zones at a glance, the dual time function is displayed in a light grey sub-dial with snailing and black numerals at 12, 3, 6 and 9 o’clock. To accommodate the complication, the sub-dial creates an arch-shaped indentation in the square minutes track. A small depression at the top of the sub-dial reveals the day/night indicator in grey and white.
The Cartier Santos Dual Time comes in a large (for Cartier) 100m water-resistant stainless steel case with a 40.2mm diameter, a length of 47.5mm and a thickness of 10.1mm. In line with the 2018 overhaul, the iconic square case features soft, rounded corners with crown guards and the 7-sided crown set with its signature sapphire cabochon. The polished bezel with its eight exposed screws rests on top of the vertically brushed case middle with polished bevels. With its curved caseback and short lugs, the watch sits flush on the wrist. The classic bracelet with its two screws at either end of the links is brushed and can be easily exchanged for the grey alligator strap provided with the watch thanks to Cartier’s QuickSwitch interchangeable system.
The automatic movement is not in-house; Cartier has chosen not to reveal the name of its partner (supplier) in the equation. What we do know is that it beats at a frequency of 4Hz, has a 40h power reserve and the independent time zone and day/night functions are adjusted at the crown.
The Cartier Santos Dual Time retails for CHF 8,800. For more information, please consult cartier.com.
- Megalos (Σάβ Απρ 13, 2024 10:15 pm)
Re: Cartier
Όμορφο και ιδιαίτερο gmt !
Re: Cartier
- kalvetfl67 (Δευ Απρ 22, 2024 11:56 pm)
- Been thanked: 5282 times
Re: Cartier
παιδια πολυ ομορφα και τα δυο ... γενικα η Cartier εχει πολυ περαση στο εξωτερικο
