Παλιες ρολογοιστοριες
Σιδ.Σταυρος
Τοποθεσία: Αθήναι
Has thanked: 627 times
Been thanked: 1019 times
Re: Παλιες ρολογοιστοριες
Δημοσίευση από Σιδ.Σταυρος »
The Bathys Cesium 133 watch is not dangerous from radioactivity because it uses a stable, non-radioactive Cesium-133 chip for timing, unlike vintage watches that used radioactive radium for luminous dials, which posed risks from inhaled radon gas and alpha/beta particles. While radium watches are a hazard if damaged (especially due to radon release), the modern Cesium 133 is a marvel of accurate, stable timing, with the "hazard" being its extreme cost and prototype status, not radiation.
Why the Bathys Cesium 133 is Safe:
Stable Isotope: It uses Cesium-133, a stable (non-radioactive) atom, in a microchip to maintain incredibly accurate time, akin to tiny atomic clocks.
No Radioactive Paint: Unlike old radium dials that glowed, this watch uses modern technology, so there's no paint to degrade or release radioactive materials.
Για αυτα με (Radium) Ραδιο:
As long as the glass on the front is intact and properly sealed, there's no risk with owning it. Radium paint is notorious for making dust and flakes, so as long as the glass is containing it all, you're good .
Also, the dose rate (the microsievers per hour reading) on the GMC 600 is way off, and it's probably more like 3 or 4 microsieverts per hour, which is not dangerous.
And, as you said with the metal backing stopping a lot of the radiation, that's also true, so your wrist will only receive what comes through the back.
All lin all, don't take it apart and there is zero harm in having it.
Υπηρχε παλαιοτερα καποιο θεμα και με Tritium (Τριτιο) σε ρολογια ακομη και σε σκοπευτικα πιστολιων τα οποια ηταν εν δυναμει επικινδυνα για την υγεια (μετα απο τριβη-θραυση).
Megalos (Πέμ Ιαν 01, 2026 4:43 pm)
Been thanked: 10071 times
Σε ευχαριστώ πολύ Σταύρο για την ενημέρωση :sh:
Σιδ.Σταυρος
Τοποθεσία: Αθήναι
Tower of Old Red Museum in Dallas
http://res.dallasnews.com/interactives/ ... index.html
Εχει και φωτογραφιες απο το εσωτερικο που δειχνει τον μηχανισμο του ρολογιου:
https://www.oldred.org/clock-tower
Εδω σε βιντεο το πως λειτουργει:
Megalos (Παρ Ιαν 02, 2026 9:59 pm) • kalvetfl67 (Σάβ Ιαν 03, 2026 12:51 am) • pugman (Παρ Φεβ 27, 2026 7:43 pm)
ευχαριστουμε και παλι Σταυρο μου για τις ενδιαφερουσες αυτες αναφορες :sh:
Σιδ.Σταυρος (Κυρ Ιαν 18, 2026 9:14 pm)
Σιδ.Σταυρος
Τοποθεσία: Αθήναι
Εχω την απορια: την ημερα του μηνα πως ''την δειχνει" ; Οταν ο μηνας ειναι ο Φεβρουαριος πως ''δειχνει'' 28 και μετα παει την επομενη ημερα στην 1η Μαρτιου;
Megalos (Δευ Ιαν 19, 2026 7:43 am)
Has thanked: 7945 times
Been thanked: 7309 times
Γυρνάς τους δείκτες δεξιόστροφα μέχρι να φτάσει η ημερομηνία που θέλεις
Σιδ.Σταυρος
Τοποθεσία: Αθήναι
Εκτος εαν αντι για δευτερολεπτα εδειχνε την ημερομηνια.
gep έγραψε: Κυρ Ιαν 18, 2026 9:42 pm Γυρνάς τους δείκτες δεξιόστροφα μέχρι να φτάσει η ημερομηνία που θέλεις
Δηλαδη εν προκειμενω ποσο του μηνος ειχε;
Ο κόκκινος δείκτης είναι μεταξύ 6 και 7 οπότε, μάλλον έχει εμπλακεί ο μηχανισμός αλλαγής της ημερομηνίας. Επίσης μην ξεχάσω, να κινείς τους δείκτες με το ρολόι σταματημένο όταν είναι εκτός λειτουργίας για αποφυγή προβλημάτων.
Σιδ.Σταυρος (Σάβ Φεβ 14, 2026 7:58 pm)
Σιδ.Σταυρος
Τοποθεσία: Αθήναι
Τηλεοπτικη σειρα ''Σεννα" στο Netflix, ο πατερας του φοραει Heuer (δεν ξερω εαν αυτο ηταν το Carrera μοντελο)
και οταν αποφασιζει να φυγει απο την Βραζιλια του δινει το ρολοι του να το εχει παντα μαζι στους αγωνες.
Ο σκηνοθετης δεν προσεξε πως παει λαθος σε σχεση με το ρολοι στον τοιχο, Α-Π-Α-Ρ-Α-Δ-Ε-Κ-Τ-Ο-Ν λεγω!
:slap:
Megalos (Σάβ Φεβ 14, 2026 8:52 pm) • pugman (Παρ Φεβ 27, 2026 7:45 pm)
αμ δεν ηξερε οτι εχουμε εδω αετησια ματια :sh:
Σιδ.Σταυρος (Σάβ Φεβ 14, 2026 8:55 pm)
