Vacheron Constantin
Been thanked: 10001 times
Re: Vacheron Constantin
ενα καινουργιο μοντελο , αυτοματο, της Vacheron Constantin . Patrimony traditionnell
This new timepiece matches the new Hallmark of Geneva requirements that are no longer confined exclusively to the movement, but also take the entire finished watch into account.
The gold case frames an opaline silver-toned dial on which time undertakes its perpetually renewed journey. The space is punctuated by 18-carat pink gold applied hour-markers, punctuated by a black minute circle.
At the heart of its case ticks the ultra-thin self-winding Calibre 1120 which has earned an excellent reputation. Developed and crafted in harmony with Geneva’s most rigorous Fine Watchmaking traditions, it beats at a frequency of 2.75 Hz (19,800 vibrations/hour) and is endowed with an approximately 40-hour power reserve. Both its finishing and its construction testify to a wealth of fine workmanship.
Not only are the smooth surfaces of the movement adorned with a meticulously executed “Côtes de Genève” motif, but all their sharp angles are chamfered and then hand-polished. Such is also the case with the screw heads. In order to accommodate this shining example of mechanical genius in the style it deserves, Vacheron Constantin has designed the broad 18-carat pink gold case of its new Patrimony Traditionnelle Self Winding model in accordance with two rarely associated criteria. While the elegant slenderness of its profile proudly proclaims its lineage within the classic tradition, its 41 mm diameter lends it an undeniably contemporary dimension.
The sapphire crystal case back enables one to admire the ultra-thin Caliber 1120.
και το πανεμορφο πισω μερος του με τον μηχανισμο να φαινεται :good:
Κωστα παει καηκαμε με τετοια αριστουργηματα που ανεβαζεις.
Ταχυκαρδια με επιασε :-)
Vacheron Constantin
Αν και τέτοιες εταιρείες περνάνε μακρυά μου, αυτός ο Σταυρός με τρελαίνει, απλότητα και ποιότητα , θέλει πολυ δουλειά και σναζητηση για να εκτιμήσεις αυτό τον συνδυασμό , όσο για το back...
Παρολου που φοβηθηκα οτι θα ηταν αβολο τελικα καθεται πολυ ωραια στο χερι.
Το καντραν ειναι ακομα ποιο ωραιο απο κοντα
Ενω η πισω θεα σου κοβη την ανασα
Και δυο καρπισιες για να δειτε και πως καθετε στο χερι
Πανεμορφο :rose
Και ειναι αρκετα προσεγμενο. Μεχρι και το λουρακι του ειναι το μαμα ακομα.
aris911 έγραψε:Και ειναι αρκετα προσεγμενο. Μεχρι και το λουρακι του ειναι το μαμα ακομα.
Αρκετα προσεγμενο?
Αν ηταν δικο μου θα ηταν καλυτερο απο οταν βγηκε απο τη VC :cigar:
Άρη είναι χάρμα οφθαλμών...και από τις δύο πλευρές. Η πίσω βέβαια μπαίνει επάξια στο παρακάτω θέμα
http://watchfunclub.com/forum/viewtopic.php?f=57&t=2545" onclick="window.open(this.href);return false;
Αλεξανδρος Σιαχος
Been thanked: 345 times
Είναι πραγματικά πολύ ωραίο ρολόι
