+1000000000000000000pontioz έγραψε:ελεος...
HUBLOT
- Has thanked: 48 times
- Been thanked: 194 times
Re: HUBLOT
Hublot releases a new F1™ King Power Suzuka
Hublot F1TM King Power Zirconium Suzuka
Technical details
Reference 710.ZM.1123.NR.FJP11
Series 250 pieces numbered from 01/250 to 250/250
Case King Power - Diameter 48 mm in Zirconium
Bezel Satin-finished zirconium and black ceramic imitating a disc brake
6 black H-shaped relief titanium screws
Crystal Sapphire Ǿ 35.50x3.00mm, colourless multi-layer ART
Face with Hublot Logo transfer (white with black stripe)
Bezel lugs Black composite resin
Lateral inserts Black composite resin
Crown Zirconium Ǿ 8.40, satin-finished, with black rubber insert
Push-pieces Start with red rubber inserts and black text at 2 o'clock
Reset in black rubber with red text at 4 o'clock
Case-back Open in circular satin-finished zirconium
Water resistance 10 ATM (equivalent to approximately 100 metres)
Dial Matt white, black indices Superluminova™ black
Red and white transfer
Hands Satin-finished hour and minute hands with micro-blasted back
Black coloured Superluminova™
Movement Hublot calibre HUB4214
Mechanical skeleton chronograph with automatic winding
No. of components 252
Ruby 27
Bridges Satin-finished, bevelled and polished
Date Date window at 4.30
Screw Black PVD
Oscillating weight King Power Hublot, openworked, black
Micro-blasted engraving against black background on bevel, and grey King Power
Main plate Rhodium-plated with snailing
Barrel Reinforced spring
Escapement Glucydur hairspring
Power reserve Approximately 42 hours
Strap White Nomex™ with red stitching on black rubber
Clasp King Power titanium deployant buckle with black PVD deployant and buttons
http://news.watchprosite.com/?show=foru ... fi=112&s=0
Technical details
Ruby 27
Screw Black PVD
Re: HUBLOT
Ανησυχησα...ειχαμε κανα μηνα να δουμε limited edition Big Bang και ειπα μηπως επαθε τιποτα ο Biver....αλλα ολα ΟΚ απ'οσο βλεπω.
- pontioz
- Has thanked: 1 time
- Been thanked: 1232 times
Re: HUBLOT
Η έκπληξη θα ήταν αν ήταν κάτι διαφορετικό...stavros_ch έγραψε:Μια απ' τα ιδια...
εεε δυσκολεύουν τα πράματα...το έχει σχεδόν εξαντλήσει το θέμα, οπότε θέλει χρόνο πλέον για μια νέα έκδοση...eisenberg έγραψε:Ανησυχησα...ειχαμε κανα μηνα να δουμε limited edition Big Bang και ειπα μηπως επαθε τιποτα ο Biver....αλλα ολα ΟΚ απ'οσο βλεπω.
Ο Biver όχι...pontioz έγραψε:κουράστηκα...
- Has thanked: 44448 times
- Been thanked: 9995 times
Re: HUBLOT
αυτο παντως παιδια ειναι ομορφο και συμμαζεμενο ρολοι
νομιζω και στους υπολοιπους θα αρεσει
Μαριε ενδιαφερουσα ειδηση -εστω και καθυστερημενα απο μενα που την ειδα τωρα
Re: HUBLOT
Hublot Antikythera Calibre 2033-CH01 Watch Is A Re-Imagined Greek Masterpiece
Tech Specs from Hublot
Movement functions
Hours, minutes
Seconds via the tourbillon cage
Flying tourbillon without ball bearing
Manual winding
View of dial
Egyptian Calendar
Calendar for the Panhellenic games
Zodiac
Aperture showing moon
Lunar phases
Aperture showing sun
View of bridges
Metonic cycle
Saros cycle
Callippic cycle
Exeligmos cycle
Main characteristics
Dimensions of shaped movement
Width 30.40 mm
Length 38.00 mm
Thickness 14.14 mm (overall dimensions)
Time-setting stem (3 o'clock) Manual winding
2-position Time setting
Number of jewels 69
Number of components 495
Hairspring Flat for extremely accurate setting
Frequency 21,600 Vib/h (3 Hz)
Power reserve Approximately 120 hours (5 days)
Oscillator (made in-house) Balance with adjustment inertia-blocks
Moment of inertia: 16mg/cm2
Lift angle: 53°
Shock absorbers Shock absorption for main plate and balance bridge
Main plate and bridges Brass, bevelled with drawn rims, and circular-grained recesses
Coating: black ruthenium
Dial showing cycles and calendar Circular-graining, 5N gold coating
Gear train Circular-grained & bevelled wheels, coating: rhodium, rolled pinions
Fasteners Polished and bevelled heads, rounded and polished ends
Steel parts Satin-finished, bevelled, with drawn rims
http://www.ablogtoread.com/
Movement functions
Hours, minutes
Manual winding
View of dial
Egyptian Calendar
Zodiac
Lunar phases
View of bridges
Metonic cycle
Saros cycle
Callippic cycle
Exeligmos cycle
Width 30.40 mm
Length 38.00 mm
Number of jewels 69
Lift angle: 53°
Re: HUBLOT
πραγματι μας την εφερε ο ελβετος
ας απολαυσομε και το ωραιοτατο βιντεο και ας νοιωσουμε υπερηφανοι σαν Ελληνες
[youtube][/youtube]
[youtube][/youtube]
