πολυ ομορφο κατα την γνωμη μου .. ωραιο
Girard Perregaux
- Has thanked: 44448 times
- Been thanked: 9995 times
Re: Girard Perregaux
Μαριε που το βρηκες αυτο το κελεπουρι φιλε
Ψιλοαδιαφορο μου ειναι βρε παιδια....τιποτα,Sea Hawk και ξερο ψωμι για μενα απο τη GP....
- Has thanked: 48 times
- Been thanked: 194 times
The La Chaux-de-Fonds Manufacture has unveiled a white gold version of the annual calendar and equation of time from its Girard-Perregaux 1966 collection. This model incorporates a useful annual calendar that takes account of the lengths of the months, save February. Also on board is an equation of time, indicating the difference between the true solar time and the mean time, or meridian time.
The functions are displayed on the dial in an original yet highly readable way. As an added touch of sophistication, the calendar can be corrected by turning the crown in either direction. This makes correction easier, and the absence of a corrector on the case leaves its curves intact. The transparent caseback allows a view into the architecture imagined and executed by the watchmakers in La Chaux-de-Fonds, including the Microvar variable inertia balance.
Technical specifications
Case in white gold
Diameter: 40 mm
Height: 10.72 mm
Sapphire crystal
Sapphire case-back
Water resistance: 30 metres
Girard-Perregaux GP033M0 movement
Mechanical, automatic winding
Calibre: 11 ½ ’’’
Frequency: 28,800 vibrations/hour (4 Hz)
Jewels: 44
Power reserve: minimum 46 hours
Functions: hour, minute, small second, annual calendar, equation of time
Balance: Microvar, variable inertia
Alligator strap with ardillon buckle
Girard-Perregaux Microvar variable inertia balance
The result of Girard-Perregaux’s chronometric research, the Microvar balance features six adjustable screws and two balance weights on its rim, used respectively to set the balance’s equilibrium and enable fine adjustment of the movement rate. This exclusive development ensures increased precision and more stable adjustment.
Microvar balance
Glucydur balance wheel
6 external gold screws for setting the balance’s equilibrium and general setting of the rate
2 Glucydur balance weights for fine adjustments of the rate (fine adjustment range +/- 40 seconds per day)
1 eccentric for fine adjustment of the beat
Case in white gold
Diameter: 40 mm
Height: 10.72 mm
Sapphire crystal
Sapphire case-back
Calibre: 11 ½ ’’’
Jewels: 44
Microvar balance
παιδια αυτο το κομματι ειναι πολυ ομορφο...
λιτο και απλο στην πολυπλοκοτητα του.. annual calendar με εξυπνες γραμμες και τοποθετησεις
Εμενα με χαλαει ολο το συνολοmarios_ch έγραψε:Κάτι με χαλάει στο όλο σύνολο.....
