Frederique Constant
Has thanked: 44234 times
Been thanked: 9932 times
Frederique Constant
Μολις παρατηρησα οτι δεν εχουμε νημα για αυτην την εταιρεια
και επειδη εβγαλε καποια ομορφα κομματια ας το ανοιξουμε
εδω ενα πανεμορφο tourbillon
Individually numbered, only 188 of each Slimline Tourbillon Manufacture model will be available to the public. Each will be presented in a beautiful wooden gift box, and features a technologically advanced manufacture movement that is unique to Frederique Constant, the silicium escapement wheel and lever.
The silicium movement has added greater durability, unrivalled accuracy of timekeeping, and reduced service requirements to models that were already among the most technologically advanced in the world. With a fast 28,800 beats per hour, each watch in the Slimline Tourbillon Manufacture range will not only keep time better than ever thought possible in a mechanical watch, it will also provide a 48-hour power reserve.
Clean lines give the slim stainless steel case an even more sophisticated, 50’s-style appearance.
Two models in the Slimline Tourbillon Manufacture range are offered; one with a polished all-stainless steel case and the other with a shining stainless steel main body accentuated with a stunning 18-karat solid rose gold bezel. The back of the case is covered with see-through sapphire crystal, allowing owners the opportunity to see firsthand the finely decorated calibre with it’s rose gold plated rotor.
The rich silver, curved dial features beautiful, rose gold-plated indices, all hand applied in-house by Frederique Constant’s skilled craftsmen and women.
The dial also boasts a day-night indicator, and finally, there’s a fine view of the tourbillon cage at the 6 o’clock position.
The new Slimline Tourbillon Manufacture models starting at just €26,500 for the stainless steel version, and €28,500 for the 18-karat rose gold bezel version.
Re: Frederique Constant
και το πισω μερος με τον μηχανισμο που δειχνει και το tourbillon
αλλα και αλλο ενα πανεμορφο κομματι της ..το Classic manufacture
This year, Frederique Constant is proud and excited to introduce the new Classics Manufacture, with a retail price starting at €1’750 in stainless steel. Designed and produced with utmost care, the sophisticated dial shows a remarkable refinement. Decoration of the movement is to the highest standards, with Cotes de Geneve and Collimacon patterns, brightly shining due to the rhodium finishing. The new Classics Manufacture is based on the second generation of the Maxime movement, cal. FC-710 and features an added center seconds hand. Apart from stainless steel, the Classics Manufacture is also available with a case finished in rosegold plating, at €1’950. A duo of stunningly beautiful timepieces!
και το πισω μερος με τον μηχανισμο σε κοινη θεα :good:
Habemus, habemus... :smile:
http://watchfunclub.com/forum/viewtopic ... e+constant
Eίπαμε, "ανεβαίνει" η Φρειδερίκη.... :gf:
σωστος Ηλια μου ....πρεσβυωπια γαρ :smile:
εγινε και η μετακινηση στο δικο του νημα :good:
billaras
Been thanked: 6 times
Δημοσίευση από billaras »
Αγαπητοι μου καλή σας ημερα..νεο μελος του φόρουμ. .Μόλις εκανα μια αγορά και γω και ήθελα να ακουσω την αποψη σας, μια που δεν εχω τις γνώσεις σας. .πήρα ενα frederique constant fc310nm4p5. Η πρωτη ακριβη μου αγορά. .την άποψή σας παρακαλώ; ; ευχαριστώ εκ των προτέρων:-)
Αλεξανδρος Σιαχος
Been thanked: 345 times
Καλώς ήρθες στο forum καλοφόρετο και καλορίζικο το ρολόι είναι αξιόπιστη εταιρία
καλωσορησες φιλε και απο μενα
νομιζω οτι ειναι ενα ομοφρο κομματι απο μια αξιολογη εταιρεια .. να το χαρεις οσο παει :sh:
και εως οτου μαθεις να μας ποσταρεις και φωτο βαζω μια για σενα :smile:
καλος ήρθες... καλορίζικο το νέο σου ρολόι... είναι πολύ ωραίο πάντα καλές ώρες να δείχνει...
