MINERVA vintage chronograph
Re: MINERVA vintage chronograph
Μινέρβα 13-20 πρέπει να είναι Κώστα.
- Has thanked: 44733 times
- Been thanked: 10067 times
Κάποιο λινκ Γιωργο για τον μηχανισμο ?
Κι αφού ξέρεις Γαλλικά, διάβασε το παρακάτω
http://forum.chronomania.net/mix_entry. ... r92Z1SLTIU" onclick="window.open(this.href);return false;
Πιθανότατα φίλε Γιωργο
Στις φωτο του μηχανισμού φαίνεται να έχει καποια εξαρτήματα φτιαγμένα καινούργια
και μάλιστα λιγο ¨ακομψα¨ αν με καταλαβαίνεις
http://www.watch-wiki.net/index.php?title=Minerva_13-20" onclick="window.open(this.href);return false;
Δώσε βάση στα bold
Calibre 13-20
Introduced in 1923 in Minerva-brand chronographs, Calibre 13-20 was designed as a mono pusher but was available after 1940 in bi-pusher configurations with 30- or 45-minute counters. It was one of the few chronograph calibres on the market on its introduction and was developed in collaboration with Dubois-Depraz. It was remarkably well-developed for the era and continued in production for decades.
Watch enthusiasts are able to recognize Minerva's Calibre 13 by the unusual positions of the pushers: Rather than being located between the crown and lugs at 30°, they are moved toward the lugs at 37° from the crown. Calibre 13 is a column-wheel chronograph, 6.4 mm thick, with a Breguet balance spring and 17 jewels.
Even after the introduction of the updated 13-21 derivative, Minerva continued occasionally to produce (or re-manufacture) Calibre 13-20 movements. For example, Panerai used a re-finished Calibre 13-20 in their Panerai Ferrari 00024 chronograph, branding it "Panerai OP XXVIII". Panerai also used this as their OP XXV in the 2011 PAM300 Mare Nostrum, though perhaps this was the later 13-22 instead.
Calibre 13-20
Γιωργο ευχαριστω παρα πολυ για τις ενδιαφέρουσες πληροφορίες
Δυστυχώς το ρολόι μετα τέσσερα χρόνια δεν φτιαχθηκε
Άστοχη αναφορά. Ειδικά όταν ο άμεσα ενδιαφερόμενος δεν μπορεί να την δει και να απαντήσει.Megalos έγραψε: Δυστυχώς το ρολόι μετα τέσσερα χρόνια δεν φτιαχθηκε
Βρείτε τα μεταξύ σας.
Γιωργο αναφέρθηκα γενικά και όχι στο άτομο που αναφερεσαι .
Απο την απόκτηση περάσουν τόσα χρόνια και ακόμα δεν έχει φτιαχτει το ρολόι
και αυτο ειναι απογοητευτικό
Κώστα σε πόσους τεχνίτες το έχεις πάει?Megalos έγραψε:Γιωργο αναφέρθηκα γενικά και όχι στο άτομο που αναφερεσαι .
