ORIENT
Re: ORIENT
Μου θυμιζει autozilla!
DragonAce
Τοποθεσία: Ηράκλειο
Has thanked: 184 times
Been thanked: 225 times
Re: ORIENT
Δημοσίευση από DragonAce »
αν ήταν μικρότερο θα ήταν πολύ καλό (όχι ότι δεν είναι αλλά δύσκολα φοριέται)
Re: ORIENT
θα συμφωνησω και εγω οτι φοριεται δυσκολα ειδικα χειμωνα...
Re: ORIENT
Καθολου ασχημο :good:
i palios
Has thanked: 2034 times
Been thanked: 1117 times
Re: ORIENT
Δημοσίευση από i palios »
Μ αυτο το πανεμορφο μωβ χρωμα, αλλα και με τ αλλα που εβαζε η Orient στα καντραν της, ηταν ενα απο τα χαρακτηριστικα της
και πρωτοστατουσε στην 10ετια του 70 και βαλε σ αυτο το στιλ. :good:
Re: ORIENT
Orient Disk Watch
Orient is a watch company with an interesting line of timepieces. Some feature more classic design, like their fan favorite Mako diver model, while others are over-designed and gaudy. Frankly, I’m not sure that I’ll ever need a watch built to resemble a motorcycle. Every so often however, they release a watch that manages to achieve unique yet simple design at a pleasantly affordable price point. Their new Disk watch is one such creation.
Movement: Orient caliber 48743 Made in Japan
Power Reserve: Approximately 40 Hours
Crystal: Sapphire Crystal
Clasp: Buckle
Water Resistance: 50m
Case Material: Stainless Steel
Case Diameter: 41.40mm
Case Thickness: 11.30mm
Dial Color: Black
Calendar: Date
Band Material: Genuine Leather
Warranty Type: 1 year International Guarantee
A few months ago, Zach reviewed the Orient Masquerade, which displays time using a series of rotating disks. This watch is bold and highly graphical yet remains well balanced and wearable. With the Disk, Orient has once again utilized a rotating disk as a means of telling time, but in a completely different manor.
One of the first thing’s you’ll notice about the Disk watch is its absence of an hour hand. Or maybe more accurately, you’ll notice the presence of a brightly colored triangle toward the center of the dial that doesn’t seem to resemble ant other component of the watch. This, of course, is the element of the Disk watch from which its name is derived. Rather than having a traditional hour hand, the Disk watch has a large black disk at its center that features a triangular shaped cutout. Under the cutout is a painted surface, resulting in a bright hour marker that appears on a separate plane from minute and second hands. Additionally, as the hour marker turns, its underlying color changes.
Aside from this unique hour marker, the Disk watch features very simple design. All of the Disk’s dial is black, including the rotating hour disk at the center. The hours are large hash mark cutouts with white coloring beneath. This matches well with the cutout styling of the hour marker. There are also smaller minute markers between the hour indices, however these are painted on. In fact, there are no numerical markings on the watch for telling the time. There is however a date window that displays a black numeral on white background. Further, the dial of the Disk features a raised bezel along the outside interior of the case. I find that this, in combination with the cutout design of the hour hand and markers, provides for a decent amount of depth to the overall appearance of the watch.
The case of the Disk is a clean and simple stainless steel, with straight lugs that transition well to the rounded case. Measuring 41.4 mm in diameter and just 11.3 mm tall, the Disk should make for a comfortable wear. The plain black leather strap appears attractive, though we can’t speak for the quality. Nevertheless, its clean and simple cut pairs well with the Disk itself.
On the rear of the disk you’ll find one last piece of flare, in the form of a green tinted display case, showing off the Orient automatic movement. This detail really isn’t for me, but I know some of you out there may really love this unique take. In fact, I’d imagine that the type of person drawn to this watch may love this hidden touch of color. So if you’re in the market for a casual watch that stands out from the rest, check out the Disk watch from Orient. Currently listed at $340 on Orient’s USA site, the watch can be purchased for a limited time with the code Spring2012 for a 30% discount.
http://wornandwound.com/2012/04/09/orie ... 26wound%29
Re: ORIENT
Orient Revs Up Their Engine
Invariably, as warmer weather is coming upon us, many will turn their thoughts to hitting the open road on two wheels. For those who just can’t (or won’t) ride, or have sold their bikes (like me), then Orient may have another way for you to get a motorcycle in your life.
How, you might ask? Simply by naming one of their models Motorcycle. And just like many motorcycle manufacturers, simply choosing a different color scheme gets you a different model name.
Colors aside, these various models are largely similar, and all share the following:
Orient Automatic movement (46S50) with 4o-hour power reserve
44mm stainless steel case (12mm thick) with screw-down crown
Mineral crystal
22mm lugs with a leather strap (deployant clasp) or stainless steel bracelet (double push-button release)
1 year international warranty
100m water resistance
This is a semi-skeletonized model, which I’ve become more of a fan of lately. Most obvious is the cutout at 6 o’clock which allows you to see the most activity that occurs in a movement. Surprisingly, there’s also a narrow cutout at 3 o’clock, which I suppose allows you to see the stem at the various engagement points.
Rounding out the dial, we’ve got the sub-seconds at 6 o’clock, and then the power reserve indicator at 12 o’clock. While I’m glad to see the PR indicator, it just looks odd to me. The cutout for it is simply too large (extending past the 40 hour mark), and isn’t exposing any more of the movement. Not sure how that decision was made, but it should be redesigned.
And as long as we’re redesigning things, I think the hands should be worked on as well. In practice, the blued, lume-filled hands work well on most watches. Here, however, they’re mostly white on a white/gray background – which I think will negatively impact readability in the long run.
Finally, we have the numerals for the watch. On one hand, I like the fact that they appear to be floating, given how they were printed (I can’t tell if that’s a layer on the dial, or if they’re on the crystal). The typeface used, however, just seems plain. You have a retro-futuristic font used for the model name on the dial – why couldn’t that be carried onto the numbers?
Suffice it to say, while there are interesting facets to this watch, there are too many design elements that I think need work for me to look at adding a model like this to my collection, or recommending it to someone else.
Add in the price ($690 to $890, depending on color scheme), even with the 30% discount code (currently, that code is SPRING2012), and that pushes it over to the “do not buy” side of the board for me. Perhaps if you ran across one secondhand on the FS boards, it might be worth taking a flier.
http://www.wristwatchreview.com/2012/04 ... ir-engine/
desmo16
Been thanked: 80 times
Re: ORIENT
Δημοσίευση από desmo16 »
CEM75001M
These users thanked the author desmo16 for the post:
Megalos (Σάβ Μάιος 12, 2012 10:37 pm)
Re: ORIENT
ωραιο και σε πορτοκαλι το μακο.... :gf: :gf:
Been thanked: 9934 times
Re: ORIENT
Αλεξανδρε παρα πολυ ωραιες φωτο αυτο του Orient που πραγματικα μου αρεσει παρα πολυ
αν το βρω σε τετοια χρωματα ισως το χτυπησω ...απο που και ποσο ξερουμε ?
