Glycine
- Has thanked: 44742 times
- Been thanked: 10070 times
Re: Glycine
πολυ ομορφα και τα δυο ειδικα οπως ειπε ο Ηλιας το δευτερο πανεμορφο στην απλοτητα του
- Has thanked: 48 times
- Been thanked: 194 times
Re: Glycine
Δείτε αναλυτικά τα νέα μοντέλα........
Airman SST Chronograph
Ref. 3902
Movement
Caliber: ETA 7754 automatic
Functions: hours, minutes, seconds, Chronograph 60s, counters 30min and 12hrs, date display in window, central 24hours hand
Jewels: 25
Power Reserve: 46 hours
Hz: 4/28'800 vibrations per hour
Finish: yellow gold coated oscillating weight on ball bearing, decorated "Côtes de Genève", engraved by an airplane. Bridges rhodium coated and decorated "perlé", visible screws in blue finish.
Case, Dial & Hands
Material: stainless steel
Diameter: 43mm without crown
Height: 15.30mm
Finish: satin/polished
Waterproof: 10 atm
Back: solid steel screwed
Glass: double domed sapphire, AR
Dial: black with SL, blue dégradé with SL
Hands: nickel with SL
Crown: screw-down
Special features
inner revolving 24 hours ring 3rd timezone served by slit-headed crown at 8h
special execution for the purists of 24-hour watches with two timezones: featuring an arrow-tipped 24hour hand on the 24-hours dial only.
Leather strap
Material: calf
Colours: black, brown, grey
Width: black, brown: 22mm horns / 22mm horns
grey: 22mm horns / 20mm buckle
Buckle: belt
Ref. 3902
Movement
Jewels: 25
Case, Dial & Hands
Height: 15.30mm
Waterproof: 10 atm
Crown: screw-down
Special features
Leather strap
Material: calf
Buckle: belt
Re: Glycine
Incursore Big Date
Ref. 3885
Movement
Caliber: ETA 2896
Functions: hours, minutes and seconds
Jewels: 22
Power Reserve: 42h hours
Finish: rhodium coated oscillating weight on ball bearing, bridges rhodium coated and decorated "perlé", visible screws in blue finish.
Case, Dial & Hands
Diameter: 44mm without crown
Height: 11.60mm
Finish: satin
Waterproof: 5 atm
Back: screwed see-through mineral glass
Glass: domed sapphire AR
Dial: black with SL, blue with SL, taupe with SL
Hands: white with SL
Crown: sticker crown
Leather strap
Material: calf
Colours: blue, black, taupe
Width: 23mm horns / 22mm buckle
Buckle: belt
Re: Glycine
Σε ευρος ή σε μηκος Σταυρο?stavros_ch έγραψε:Μου φαινονται λιγο μεγαλα τα lugs....
Εμενα μια χαρα μου φαινονται!
