Girard Perregaux
Re: Girard Perregaux
stavros_ch έγραψε:Δυνατο κομματι και μηχανικα και αισθητικα αν εξαιρεσεις τους δεικτες! :slap:
+1
GIRARD-PERREGAUX - Vintage 1945 Tourbillon With Three Gold Bridges
Nouvelle interprétation d’un mouvement puisant ses origines à la fin du 19ème siècle, cette édition Vintage 1945 Tourbillon sous trois Ponts d’or crée un lien entre les époques.
Press release
Haute horlogerie, elegance and technology
The heritage of Girard-Perregaux’s acclaimed Tourbillon with three gold Bridges places itself squarely in the twenty-first century. Combining noble materials and a high-tech finish, its elegance and majestic architecture underscore its singular character. A rarity limited to 50 pieces.
Fashioned in pink gold, the case and the bridges form a striking contrast with the color of the main plate. Its matte anthracite coating is the result of a particular combination of precious materials similar to platinum and draws on cutting-edge technologies. Other elements, such as the barrel, the lower gearwheel bridges and the bridge supports, adopt this finish, resulting in a stunning visual effect.
In a bold leap across time, this limited edition of the Vintage 1945 Tourbillon with three gold Bridges offers a new take on a movement whose origins date back to the end of the 19th century. Drawing on the latest technological progress, it concentrates rare technical and Manufacture expertise within its delicately curved Art Deco-inspired case.
The hand-guilloched skeletonized bridges, with their pure, contemporary geometry, are the fruit of extremely delicate design: first finely openworked, they are then carefully hand-polished. Seven days are necessary to obtain a perfect finish, since the numerous closed angles form a considerable challenge. The tourbillon system also requires special attention, as its 72 components must be meticulously assembled inside a diameter of just 12 millimeters. To cap these feats, a precious matte anthracite coating gives this timepiece its distinctive personality.
The self-winding caliber GP9600 movement has an integrated micro-rotor housed under the barrel, patented by Girard-Perregaux. The mechanism’s architecture, also visible through the sapphire back is further enhanced by the matte anthracite-coated components. The Vintage 1945 Tourbillon with three gold Bridges is a formidable demonstration of the Manufacture’s expertise. In other words, how aesthetics and technique manage to reinvent and renew the rules of the watchmaking art.
GIRARD-PERREGAUX - VINTAGE 1945 TOURBILLON WITH THREE GOLD BRIDGES
Technical specifications
Pink-gold case with domed anti-glare sapphire glass
Back: with anti-glare sapphire
Dimensions: 36.10 mm x 35.25 mm
Water resistance: 30 meters
Crown: pink gold, engraved with GP logo
Dial: matte anthracite surface treatment (NAC) on the mainplate
Hands: gold regatta, diamond polished
Movement Girard-Perregaux 9600-0019,
Mechanical self-winding
Functions: Tourbillon, hours, minutes
Dimensions: 28.60 mm x 30.30 mm
Total thickness: 3.20 mm
Jewels: 31 jewels
Power reserve: minimum 48 hours
Winding: automatic, hand-brushed platinum rotor
Frequency: 21,600 vibrations/hour (3 Hz)
Components
Number: 257
Balance wheel: variable inertia with gold regulating screws (diameter 8.35 mm)
Balance-spring: Breguet, Philips terminal curve
Mainplate: anthracite (NAC) surface treatment, vertical guilloché on top,
pearling and guilloché below, hand-polished angles
Lower gear train bridge: vertical guilloché, hand-polished angles
Barrel: engraved cover with hand-applied circular guilloché and brushing
Rhodium-plated barrel, central and tourbillon bridges: in gold, hand-polished angles
brushed top and edges
Tourbillon:
- 72 components weighing a total of 0.3 grams
- one rotation per minute
- upper and lower carriages beveled and polished by hand
- escapement and pallet bridges beveled and polished by hand
Alligator strap
Folding clasp in pink gold
Limited edition of 50
Reference
99880-52-001-BA6A
http://www.worldtempus.com/en/news/top- ... d-bridges/
οπτικα δεν με κερδιζει αλλα μηχανικα ειναι σουπερ .... :photogr:
Review: Girard-Perregaux 1999 Chronograph, Ref. 4946
http://gp.watchprosite.com/show-forumpo ... 90333/s-0/
These users thanked the author marios_ch for the post:
Megalos (Πέμ Μάιος 10, 2012 11:38 pm)
:ha: :ha: :ha:
ΑΠΙΘΑΝΟ ... Πολυ ομορφος χρονογραφος παιδια .... :nyah :nyah
Πραγματικα,παρα πολυ ωραιο...''
Πανεμορφο κομματι και με μηχαναρα!!
DragonAce
Τοποθεσία: Ηράκλειο
Has thanked: 184 times
Been thanked: 225 times
Δημοσίευση από DragonAce »
πανέμορφο!
Girard-Perregaux SeaHawk 1000 “Big Blue”
On Tuesday, June 5th, Susan and David Rockefeller, Jr. will celebrate World Oceans Day (officially June in partnership with Swiss luxury brand Girard-Perregaux at the Museum of Modern Art in New York City. In honor of the evening and of Susan and David’s efforts to promote conservation and ocean preservation, Girard-Perregaux will launch a limited edition timepiece, the SeaHawk 1000 “Big Blue”. The watch features a steel case in the classic SeaHawk design, with a nicely toned blue rubber strap with blue dial. The dial has a map of the world outlined on the power reserve subdial to symbolize the theme of World Oceans Day. The back of the watch has the very cool looking trident motif, a signature of all SeaHawk pieces. Look for it on display next week at the event.
Limited edition 15 pieces
44mm stainless steel case, 1000 meter water resistance, unidirectional bezel, helium valve, automatic mechanical GP manufacture caliber, blue rubber strap
http://blog.perpetuelle.com/dive-watche ... -big-blue/
Ωραιο κομματι!
