Patek Philippe
Re: Patek Philippe
Το γλυπτο μαλλον ειναι μια σπειρα απο ελατηριο...
Has thanked: 44679 times
Re: Patek Philippe
ναι . η λεγομενη ''τριχα'' δεν ειναι Κωστη ?
VIWOW
Re: Patek Philippe
Δημοσίευση από VIWOW »
Στην είσοδο της Patek Philippe δεσπόζει ένα γλυπτό που απεικονίζει αυτό που στα Γαλλικά λέμε
"SPIRAL BREGUET"!!!
GeorgeD
Been thanked: 10 times
Re: Patek Philippe
Δημοσίευση από GeorgeD »
μη μιλατε ρε παιδια για breguet... x:
Re: Patek Philippe
καποιος μεγαλος μιλαει για Lange καπου αλλου :ha:
Re: Patek Philippe
και ενα ιστορικο κομματι της ΡΡ το 5100 $0$$
Re: Patek Philippe
Patek με γωνιες δεν ειναι Patek :ha:
Re: Patek Philippe
Patek Philippe, Genève, ""10 Jours"", Ref. 5100 J. Produced in a limited edition to celebrate the year 2000.Very fine, rectangular lozenge, water-resistant, 18K yellow gold gentleman's wristwatch with 10 days power reserve, and an 18K yellow gold Patek Philippe buckle.
eis ΡΡ δεκαημερο ειναι φιλε ...επετειακο .. για δες το καλυτερα ..
Re: Patek Philippe
Patek Philippe & Cie, Gen ve, Ref. 5100J Model: 5100J - "10 Day" Case: Water resistant to 25 meters. A sapphire crystal back revels the superb finish of a movement hallmarked with the Geneva Seal, the highest official attestation of classical watchmaking. Dial: Arabic even numbers, applied in gold, alternate with markers shaped to match the gold dauphine hands.Two sub dials sunk into the white coloured dial have the function of showing the seconds at 6 o'clock and the power reserve indicator at 12 o'clock. Description: EXTREMELY FINE AND RARE PATEK PHILIPPE 10 DAYS 'MANTA RAY' IN YELLOW GOLD. WRISTWATCH CHRONOMETER WITH 10-DAY POWER RESERVE WITHIN THIS WINGED CASE BEATS THE FIRST WRISTWATCH MOVEMENT CAPABLE OF RUNNING FOR MORE THAN 10 DAYS WHEN FULLY WOUND. The case which takes 188 operations to bring to life is in yellow gold and in the shape of a 'manta-ray'. The movement consists of dual barrels to store enough energy to keep the movement going for 10 days. A differential gear connects the drum of the first barrel to the arbor of the second to indicate the power reserve of the movement. DIMENSIONS: 28 x 20MM. HEIGHTS AT BRIDGES: 5.05MM. NO. OF PARTS: 175. NO. OF JEWELS: 29. POWER RESERVE: 240 HOURS. BALANCE: FREE SPRUNG GYROMAX. FREQUENCY: 21600 VIBRATIONS PER HOUR. BALANCE SPRING: FLAT. SHOCK PROTECTION: TWO ON THE BALANCE. HALLMARK: THE GENEVA SEAL. ADJUSTMENTS: 5 POSITIONS,HEAT AND COLD. RATING CERTIFICATE: GENEVA SEAL/COSC. CALIBRE: 28-20/220PS IRM. The manta ray were made to mark the third millennium and this case design will never be produced again and all the tools and dyes used in the manufacture have been destroyed to ensure it is never reproduced. 1500 IN YELLOW GOLD. 750 IN ROSE GOLD. 450 IN WHITE GOLD. 300 IN PLATINUM. THE WATCH IS ACCOMPANIED BY A SPECIAL BOX, CERTIFICATE. MEDAL, ATTESTATION AND COSC RATING CERTIFICATE
ΔΕΚΑΗΜΕΡΟ ΡΡ eis.. επαναλαμβανω.. με δυο βαρελακια..
τα καλουπια του κατεστραφηκαν ωστε να μην ξανακατασκευαστει παρομοιο ..μεχρι και τα εργαλεια που
χρειαστηκαν κατασταφηκαν ...
Re: Patek Philippe
Κωστα πλακα κανω οτι δεν ειναι Patek,αναφερομαι στο τετραγωνο σχημα του βεβαια...
Προσωπικα δε μ αρεσει αλλα οι προδιαγραφες του ειναι :good:
