σωστος Θωμαcamen έγραψε:$ Με τον πΕρτικαλι ιμαντα ειναι τρελα
Maurice Lacroix
- Has thanked: 44234 times
- Been thanked: 9932 times
Re: Maurice Lacroix
- Has thanked: 48 times
- Been thanked: 194 times
Re: Maurice Lacroix
A new Masterpiece from Maurice Lacroix
Maurice Lacroix is an excellent brand which doesn’t always get the coverage and recognition it deserves.Based in Saignelégier, Switzerland, and named after an employee who happened to have a name that fitted the image the company wanted to project, the brand has been slowly but steadily nudging its way more up market in recent years. And as the Swatch Group have now drastically reduced the supply of ETA movements, they have ventured increasingly into developing their own.
The brand’s flagship, ‘the Masterpieces’ is Maurice Lacroix’s individualistic interpretation of complications, including the retrograde and moon indications.
While the Masterpieces previously developed alongside manual winding mechanisms, last year saw Maurice Lacroix adopt automatic calibres for the first time, for 2012, the collection continues to expand, revisiting its long-standing manual expertise with a new version of the Masterpiece Roue Carrée Seconde.
Meanwhile, the new Masterpiece Lune Retrograde is a new self-winding manufacture movement with a 52 hour power reserve. Cased in a 43mm stainless steel case, the Masterpiece Lune Retrograde alternates satin and polished finishes without ostentation.
The slightly raised time markers are emphasised by the satin sunburst finish of the royal blue dial. Encircled by a hand display marking the days of the week, the moon phase is 6 o’clock. It turns on a black disk in striking chiaroscuro. The calendar is housed at 10 o’clock in a wide retrograde arch, while the power reserve is dynamically displayed at 2 o’clock. The self-winding in-house ML 192 movement is revealed by the sapphire crystal case.
The new Masterpiece Lune Rétrograde comes with an optional leather strap and is available with dials in slate and silver/gold two-tone. Its particularly competitive position on the market for manufacture watches confirms the desire of Maurice Lacroix to expand its range. Well worth checking out if you are looking at if pieces from $2,000 – $6,000
Specifications
Case:
- Stainless steel, Ø 43 mm, satin and polished finishing
- Domed sapphire crystal with anti-reflective coating on both sides
- Screwed case back with wide sapphire crystal
- Water-resistant to 50m/5 atm
Dial:
- Based on a 925 solid silver plate
- Available in black gold, navy blue or silver colour, with sun brushed finishing
- Diamond-cut applied hour, small second and power reserve markers; rhodium colored on black gold and – navy blue dial, pink gold color on silver dial
Hands:
- Stamped hours and minutes hands with diamond-cut head in the pure tradition of hands making
- Retrograde indications in contrast to the dial color for optimum legibility: rhodium colored on black gold and navy blue dial, black gold color on silver dial
- Rhodium colored stick hand for power reserve and small second
- Moon phase disc : rhodied moon and stars on black sky or pink gold moon and rhodied stars on deep blue sky
Strap / Bracelet:
- Large-scale crocodile-skin strap, hand-stitched, available in black (lined with black calfskin and black over-stitching), matt brown (lined with brown calfskin and over-stitching) or navy blue (lined with black calfskin and blue over-stitching)
Buckle:
- Folding steel clasp with push buttons
- Satin and polished finish
Movement:
Automatic manufacture movement ML192
Functions:
- Hours and minutes indicated by central hand
- Date indicated by retrograde hand at 10 o’clock
- Weekday indicated by small hand at 6 o’clock
- Moon phase indicated by disc at 6 o’clock
- Power reserve hand at 2 o’clock
http://www.clicktempus.com/blog/a-new-m ... ce-lacroix
Specifications
Case:
Dial:
Hands:
Strap / Bracelet:
Buckle:
Movement:
Functions:
Re: Maurice Lacroix
πρωτοτυπο και λιτα ομορφο κομματι αυτο το νεο μοντελο
Re: Maurice Lacroix
N E W M o d e l – Maurice Lacroix Les Classiques Phases de Lune
The case, in stainless steel, measures 40mm. It has an AR-coated sapphire crystal, a sapphire display back, and is water resistant to 30 meters.
Movement is the Swiss automatic ML caliber 37 (base ETA) with 25 jewels, 28,800 vph and a power reserve of 38 hours. It features a moonphase complication.
http://forums.timezone.com/index.php?t= ... sg_6169712
Re: Maurice Lacroix
καιρο πολυ εχουμε να ασχοληθουμε με την Maurice Lacroix
εβγαλε ενα νεο μοντελο που με την χρηση silicum καταφερνει να φερνει το βαρος του μηχανισμου στο ενα τριτο και να μειωνει την χρηση λιπαντικου
εξ ου και το ονομα Gravity
- chris5
- Has thanked: 787 times
- Been thanked: 1479 times
Re: Maurice Lacroix
MAURICE LACROIX Pontos S Regatta
The super sporty Pontos S has added a regatta function to its dial powered by the self-winding ML162 calibre. This timer, ideal for the summer months when water sports are all the rage, allows you to get ready for the race 10 minutes before it starts. The timer fans out from 10 to 2 o’ clock on the silver-tone sandblasted centre with a white-tipped hand which tracks the minutes in two areas: blue (ready, steady…) and red (go!). The hour rim bears applied luminescent indices and a white minute track on the black sunburst dial surrounding a scale to measure knots. Two luminescent rhodium-plated hands glide above the time functions. The internal bezel engraved on the minute track can be rotated by pressing the pusher at 2 o’ clock on the forged carbon 45mm case. The pusher also starts and stops the regatta function. Price: 7,950 CHF
Re: Maurice Lacroix
Χρηστικο ρολόι για αυτο που προορίζεται
harolagoha
- Has thanked: 117 times
- Been thanked: 1129 times
Re: Maurice Lacroix
Ας ζωντανεψουμε λιγο το νημα με ενα ομορφο ρολογακι που προσφατα παρουσιαστηκε...Η ομοιοτητα του με ΑΡ, GP, etc προσωπικα δεν με χαλαει ενω η τιμη του, γυρω στα 2k (μαλλον usd) κρινεται ικανοποιητικη...
- These users thanked the author harolagoha for the post (total 3):
- Argo98 (Τετ Απρ 25, 2018 9:05 am) • Megalos (Τετ Απρ 25, 2018 9:08 pm) • gep (Σάβ Μάιος 04, 2019 3:01 pm)
- Rating: 23.08%
- Been thanked: 5277 times
Re: Maurice Lacroix
Όμορφο, αν και στα όρια του homage σε σχέδιο.harolagoha έγραψε:Ας ζωντανεψουμε λιγο το νημα με ενα ομορφο ρολογακι που προσφατα παρουσιαστηκε...Η ομοιοτητα του με ΑΡ, GP, etc προσωπικα δεν με χαλαει ενω η τιμη του, γυρω στα 2k (μαλλον usd) κρινεται ικανοποιητικη...
