HUBLOT
- Has thanked: 44234 times
- Been thanked: 9933 times
Re: HUBLOT
ενα ομορφο βιντεο ενος ομορφου κομματιου του φιλου μας Biver
[youtube][/youtube]
[youtube][/youtube]
- Has thanked: 27 times
- Been thanked: 105 times
Re: HUBLOT
Που είναι η ομορφιά του βίντεο; Στη σκηνοθεσία ή στο σενάριο;
Πάντως το Αέρο φυσάει.
Re: HUBLOT
Tο βίντεο; Κι εμένα.marios_ch έγραψε:εμένα πάλι δεν μου αρέσει τίποτα σε όλο αυτό........
Re: HUBLOT
μα ακριβως σε αυτο ..στο περιεχομενο του βιντεοBlackbird έγραψε:M' αρέσει πως τα γράφεις Κώστα.
Που είναι η ομορφιά του βίντεο; Στη σκηνοθεσία ή στο σενάριο;![]()
Re: HUBLOT
Big Bang Gold 38 mm Automatic
The first Big Bang 38 mm equipped with a mechanical movement
Hublot is unveiling for the first time an automatic Big Bang 38 mm. It has to be acknowledged that women more often choose a watch for its design, elegance or aesthetic details. But an increasing number are coming to appreciate the sophistication of a mechanical watch. To meet their most demanding wishes, Hublot is enriching its collection with a whole series of Big Bang 38 mm equipped with the automatic mechanical movement HUB 1110. Available in an 18 K red gold or steel case, with a ceramic or fully stone-set bezel, black, white or cappuccino dial, and matching rubber or alligator strap, or a matching steel or gold bracelet: practically all possible combinations are covered. And the detail that makes the difference? A discreet "Automatic" inscription on the dial, baton indexes and a practical date indicator window at 3 o'clock.
TECHNICAL DETAILS
References 365
Case “Big Bang” - Diameter 38 mm
Version fully set with 320 diamonds, with a total weight of 1.69 carats.
Bezel 18K red gold, ceramic or steel, with 6 titanium H-shaped countersunk, polished & locked screws. Version set with 126 diamonds, with total weight 0.87 carats.
Crystal Sapphire with interior/exterior anti-reflective treatment
Bezel Lug Composite resin
Lateral Inserts Composite resin
Case-back Solid. 18K red gold or steel
Сrown 18K red gold or steel, with rubber insert
Water resistance 100 m or 10 ATM
Dial White, black or cappuccino, with indexes every 5 minutes
Hands Faceted & diamond-polished rhodium, with luminescent coating
Movement HUB1110, automatic mechanical
Wristlet Rubber or alligator strap, 18K red gold or steel bracelet.
ανακοινωση της Hublot για νεο αυτοματο ρολοι της με τον δικο της μηχανισμο στα 38 mm
υποτιθεται οτι ειναι γυναικειο (εγω θα το επαιρνα ευχαριστως
TECHNICAL DETAILS
References 365
Re: HUBLOT
- Has thanked: 48 times
- Been thanked: 194 times
Re: HUBLOT
To celebrate the 40th anniversary of GreenGo the Gstaad Palace Hublot have joined together to create a Big Bang in the club's colors - on a Black Magic with two famous green and orange - published in only 40 copies (for 40 years ) only available at the Gstaad Palace.
http://www.tendancehorlogerie.com/fr/hu ... engo-bang/
Re: HUBLOT
τωρα δεν μπορω να πω οτι δεν μου αρεσει
παντως η Hublot παιζει με τα υλικα και τα χρωματα συνεχως και πετυχαινει ωραια αποτελεσματα
