Girard Perregaux
Re: Girard Perregaux
Μαριε τα Open που ποσταρες ειναι τρελλα φιλε
ειδικα εμενα το Open two μου αρεσε τρομερα ...φανταστικο :magn:
Girard-Perregaux WW.TC Chronograph ‘Mondo Exploris’
Girard-Perregaux have issued an 8 piece limited steel edition of their rather nice WW.TC Chronograph, called the ‘Mondo Exploris’.
It’s been designed in conjunction with with luxury magazine ‘CAESAR’ (nope, me either).
A 43mm piece, the case is entirely satin-finished.
The matt black multi-level dial has also been reworked in the same style – in contrasting red and black.
The 24-hour ring has been redesigned with two arrows showing its direction of rotation while baton-style hands indicate the hours and minutes.
I wonder where the 8 models will end up?
Technical Specifications
REF: 49805-11-777SBA6A / Exclusive limited edition, 8 pieces only.
Case: Stainless steel, satin-finished
Three-body case, rounded bezel, concave lugs, screw-down crowns, sapphire crystals with anti-reflective treatment
Diameter: 43.00 mm
Height: 13.40 mm
Case-back: Steel, engraved with AE & Mondo Exploris logos and fitted with transparent sapphire crystal, secured by 6 screws.
Water resistance: 5 ATM
Dial/Hands: Matt black with luminous “12” numeral, 8 round indexes, and transferred Girard-Perregaux, Mondo Exploris and AE logos, Black and red 24-hour revolving ring, Outermost 24-city disc printed with CAESAR for GMT +2 timezone, Luminous white baton hour and minute hands
Movement
Girard-Perregaux GP033C0
Mechanical manufactured movement, self-winding
Caliber: 13”’
Frequency: 28,800 vibrations/hour (4 Hz)
Jewels: 63
Power reserve: minimum 46 hours
Functions: hour, minute, small second, world time with day/night indicator, chronograph, date
Finishing: circular graining on the main plate, Côtes de Genève on the bridges and oscillating weight, and blued steel screws
Strap/Buckle
Black alligator leather strap. Stainless steel folding buckle
Extra rubber strap
http://www.winderz.com/?p=4332&utm_sour ... winderz%29
Girard-Perregaux Sea Hawk II Watch Review
Model reference 49950-19-632-FK6A
In-house GP033R0 automatic movement. 28,800 vph, 46 hour power reserve with sub seconds and date complications.
Water resistant to 1,000m (3300ft)
Double-domed sapphire crystal with dual-sided antireflective coating
Rubber-filled 120-click unidirectional steel bezel with raised numerals
Stainless steel case, 44.8mm by 15.1mm, 55.5mm lug to lug. 160g with strap.
Fitted rubber strap with butterfly deployant, on-wrist pushbutton micro adjustments. Standard 22mm lugs.
Automatic helium escape valve at two o'clock
Signed 7.8mm crown, at four o'clock, with integrated crown guards.
List price of approximately $9,700
Let's take a close look at the dial and layout. Start with the figure-eight / infinity shape of the power reserve and sub seconds:
http://forums.watchuseek.com/f408/girar ... 21978.html
Το Seahawk ειναι πολυ καλο ρολοι,αλλα ποτε δεν καταλαβα γιατι το τιμολογει τοσο ψηλα η GP...
Και εμενα μου αρεσει πολυ το συγκεκριμενο..
stavros_ch έγραψε:Και εμενα μου αρεσει πολυ το συγκεκριμενο..
Ετσι... :good:
εμενα απο την αλλη μου αρεσει πολυ το WW της ... πολυ χρησιμο για τους
ταξιδευοντες συχνα ... αρεσει και στον φιλο GeorgeD ετσι ...
GIRARD-PERREGAUX - 1966 Small Second
The Girard-Perregaux Manufacture's classic elegance and great watchmaking tradition are reflected in the Girard-Perregaux 1966 Small second limited and numbered edition. Its hand-grained dial highlighted with painted Arabic numerals is a fine tribute to the watchmaker’s 220 years of history.
Produced in a numbered, limited edition of 100 pieces, the Girard-Perregaux 1966 Small second loudly proclaims the noble heritage of its name.
Technical specifications
Pink gold case
Diameter: 38.00 mm
Height: 8.59 mm
Sapphire crystal
Full curved engraved case-back
Water-resistance: 30 metres
Girard-Perregaux GP03300 movement
Mechanical with automatic winding
Calibre: 11 ½ ’’’
Frequency: 28,800 vibrations / hour (4 Hz)
Jewels: 28
Functions: hours, minutes, date, small seconds
Alligator strap with pink gold pin buckle
Reference: 49526-52-111-BK6A
Numbered, limited edition of 100 pieces
http://www.worldtempus.com/en/news/top- ... ll-second/
Ο ορισμος του καλου ρολογιου!
Πολυ ''ζεστο'' χρωμα το καντραν,παρ'ολο ανοιχτοχρωμο :good:
Πολυ ομορφο και μετρημενο ρολοι..!
