Patek Philippe
Re: Patek Philippe
εδω ολα τα στοιχεια του παραπανω κομματιου
Watch:
Patek Philippe Grandmaster Chime
Bright silvery luster dials
Time side with hand guilloched center and applied gold Roman numerals
18K solid gold dial plates
Alligator strap with square scales, hand-stitched, dark brown, hand-patinated
Solid gold fold-over clasp, fully hand-engraved
Reversible case, fully hand-engraved with a decoration of laurel leaves
Case is humidity and dust protected only (not water resistant)
Rose gold
Diameter: 47.4 mm
Height: 16.1 mm
Commemorative limited edition of 7 timepieces
Six will be sold and one will be part of the Patek Philippe Museum Collection
Caliber:
Mechanical manually wound movement
Caliber 300 GS AL 36-750 QIS FUS IRM
Grande Sonnerie, Petite Sonnerie, minute repeater
Strikework mode display (Silence/ Grande Sonnerie/Petite Sonnerie)
Alarm with time strike
Date repeater
Movement power-reserve indicator
Strikework power-reserve indicator
Strikework isolator indicator
Second time zone
Second time zone day/night indicator
Instantaneous perpetual calendar
Display of day and month
Date display (on both dials)
Leap year cycle
Four-digit year display
Moon phases
24-hour and minute subdial
Crown position indicator (winding [R], alarm setting [A], timesetting [H])
Case diameter: 37 mm
Height: 10.7 mm
Number of parts: 1,366
Movement power-reserve: 72 hours
Strikework power-reserve: 30 hours
Balance: Gyromax®
Frequency: 25,200 semi-oscillations/ hour (3.5 Hz)
Balance spring: Spiromax®
Hallmark: Patek Philippe Seal
Re: Patek Philippe
αλλο ενα επετειακο ειναι το Chiming jump hour 5275P
θα παραχθουν 175 κομματια οσα τα ετη της Patek Philippe
Re: Patek Philippe
εδω τα στοιχεια του παραπανω
5275P-001> Men 175th Collection
Watch:
Patek Philippe Chiming Jump Hour
Silvery opaline dial with embossed decor, circular-grained minute scale, printed black
Alligator strap with square scales, hand-stitched, shiny black
Fold-over clasp engraved with “PATEK PHILIPPE 1839 – 2014” and engraved Calatrava Cross in the center
Solid case back engraved with “PATEK PHILIPPE GENEVE 175e Anniversaire 1839 – 2014”
Case with engraved flanks
Platinum
Case dimensions: 39.8 x 47.4 mm
Height: 11.3 mm
Commemorative limited edition of 175 timepieces
Caliber:
Caliber 32-650 HGS PS
Automatic hour strike
Jumping hours in aperture
Jumping minute hand
Jumping subsidiary seconds hand
Diameter: 32.6 mm
Height: 6.5 mm
Number of parts: 438
Power-reserve: min. 48 hours – max. 53 hours
Balance: Gyromax®
Frequency: 28,800 semi-oscillations/hour (4 Hz)
Re: Patek Philippe
επομενο επετειακο κομματι ειναι το World time moon 5575G-001 που θα παραχθει σε 1300 κομματια
Re: Patek Philippe
5575G-001> Men 175th Collection
Watch:
World Time Moon
Water resistant to 30 m
White gold
Diameter: 39.8 mm
Height: 9.5 mm
Commemorative limited edition of 1'300 timepieces
Caliber:
Mechanical self-winding movement
Caliber 240 HU LU
Moon phases
Display of 24 time zones, day/night and 24-hour indications
Diameter: 27.5 mm
Height: 5.2 mm
Number of parts: 270
Power-reserve: min. 38 hours, max. 48 hours
Balance: Gyromax®
Frequency: 21,600 semi-oscillations/hour (3 Hz)
Re: Patek Philippe
αλλο ενα επετειακο ειναι το Multisxale chronograph 5975J-001παραγωγη 400 κομματια κιτρινος χρυσος
Re: Patek Philippe
τα στοιχεια παλι του παραπανω
5975J-001> Men 175th Collection
Watch:
Multi-scale Chronograph
Dial: silvery opaline
Strap: alligator with square scales, hand-stitched, shiny chocolate brown
Yellow gold
Diameter: 40 mm
Height: 10.25 mm
Commemorative limited edition of 400 timepieces
Caliber:
Caliber CH 28-520
Multi-scale chronograph: tachymeter, telemeter and pulsimeter
Sweep chronograph hand
Diameter: 30 mm
Height: 5.2 mm
Parts: 239
Power-reserve: Min. 50 hours – max. 55 hours
Balance: Gyromax®
Re: Patek Philippe
τα 5975 θα κυκλοφορησουν σε διαφορα υλικα ..πλατινα ..κιτρινος χρυσος ..λευκος χρυσος ..
Re: Patek Philippe
Ωραια κομματια ολα.
Μου κανει εντυπωση η Patek που ανεκαθεν χρησιμοποιει στα κομπλικε της ρολογια πολυ συχνα low beat καλιμπρες.
Re: Patek Philippe
Πράγματι Θοδωρη ..πιθανόν για μεγαλύτερη αντοχή στην διάρκεια του χρόνου ?
Λιγότερες βλάβες ? τι λέει ο Αρης για αυτο ? Κωνσταντινε ? ΒΒ ?
