Fortis
- Has thanked: 44464 times
- Been thanked: 10000 times
Re: Fortis
παραφορτωμενο καντραν ... εχει ομως μια χαρη δεν ξερω γιατι ..
- Has thanked: 48 times
- Been thanked: 194 times
Re: Fortis
Fortis B-47 Mysterious Planets
Fortis celebrate their one hundred year anniversary next year.
They’re commemorating the event with these limited edition (500 piece) ‘Mysterious Planets’ models.
Available with a blue or black dial these simple looking pieces hide a very
‘jumping hour’ movement.
Cool because, as the ‘planets’ rotate around the dial, the jumping hour jumps to appear behind each planet hour by hour (check out the picture if that doesn’t immediately make sense).
The case is stainless steel, with water resistance to 200m.
You can choose a rubber of leather strap and depending on your option you’ll have more or less change from $5500 for one of these.
http://www.winderz.com/?p=4257&utm_sour ... winderz%29
Re: Fortis
θα συμφωνησω μαζι σου Αντωνη ..
δεν λεει
δεν λεει
Re: Fortis
σαν να ψιλοερωτευτηκα το κομματι αυτο.......
Fortis Marinemaster Vintage Limited Edition
This year Fortis marks its 100th anniversary and to celebrate, the brand is issuing a limited re-edition of the Marinemaster. First distributed at the beginning of the 1940s, that model became one of the brand’s most popular watches. Over the years, the look of the watch was updated, and the 100th anniversary re-edition is inspired by the model produced during the 1970s.
The Marinemaster Vintage LE is a 40mm automatic chronograph in polished stainless steel on leather strap, available with orange or blue dial highlights. A total of 500 of each version will be produced.
http://www.watchtime.com/2012/01/fortis ... d-edition/
- Has thanked: 330 times
- Been thanked: 1027 times
Re: Fortis
http://www.winderz.com/?p=4257&utm_sour ... winderz%29[/quote]
Σαν να το εχεις πυροβολισει με αεροβολο
Re: Fortis
Μαριε οχι αδικα το ερωτευτηκες ... πολυ ομορφο κομματι αυτο Marinemaster ..
και χρωμα τουρμπο
και χρωμα τουρμπο
Re: Fortis
marios_ch έγραψε:σαν να ψιλοερωτευτηκα το κομματι αυτο.......![]()
Άμα φοράει και Val. 72 πάμε για καταναλωτικό δάνειο....
