STOWA
Re: STOWA
πολυ ενδιαφερουσες πληροφοριες ...
ευχαριστουμε πολυ Θωμα .. :sh:
Re: STOWA
Basel 2012: Stowa Marine Chronograph
The current STOWA Chronograph line is expanded by a Marine Chrono.
STOWA presents this year the Marine Chrono besides the classical Chrono 1938 with the typical formed dial of former pockets watches and the diminished Flieger Chrono.
The historical STOWA pocket watch of the year 1940 which can be seen in the STOWA museum provided the basis of the design and influenced already the design of our successful model Marine Original (with handwinding movement Unitas 6498).
The matt silver dial as well as the blued hour- and minute hands may underline the significant impression of the design classic. However the remaining hands are held more subtle but should be good readable if needed and not compete with the normal time display. STOWA solved this problem by using polished and galvanized helping hands.
The case diameter is 41 mm and inside you will see under a sapphire crystal case back the reliable automatic chronograph Valjoux 7753 caliber.
Marine Chrono
http://forums.timezone.com/index.php?t= ... sg_6097675
Re: STOWA
Basel 2012: Stowa Antea KS 41
Bauhaus style in new size
In the typical Bauhaus design STOWA will present on the BASLE fair this year the expansion of the popular ANTEA line. You will note at once the new diameter of 41 mm.
The hand winding watch will be equipped with the approved Unitas 6498 movement which is working most reliable for many years in our model range Marine Original. With a larger case STOWA realizes one more time the request of the customers for a perfect readable watch.
The simple typography of the dial is only amended by a subtle STOWA Logo, the rest follows the clear design.
Thereby the printed „Made in Germany“ can now be seen on another part of the watch. While designing the watch Jörg Schauer decided to abstain completely from the certificate of origin on the dial and achieved thus an optical balance.
http://forums.timezone.com/index.php?t= ... sg_6097672
Re: STOWA
Basel 2012: Stowa Antea Day Date
As of now the Antea Day-Date range which we presented in 2011 is amended by a model with black dial.
This model in which day- and date display are nicely fitted into the dial and with its numerous varieties of straps is built in a 39 mm case. Inside our reliable ETA 2836-2 movement is ticking and of course this model - just like every STOWA watch - is equipped on both sides with sapphire crystal.
http://forums.timezone.com/index.php?t= ... sg_6097671
Re: STOWA
Πανεμορφα το Stowa!! :nurse:
Re: STOWA
ειδικα το τελευταιο day date ειναι πολυ ομορφο ...παντα ιδιαιτερα τα Stowa :good:
DragonAce
Τοποθεσία: Ηράκλειο
Has thanked: 184 times
Been thanked: 225 times
Re: STOWA
Δημοσίευση από DragonAce »
όμορφα!
CHRISTOS
Has thanked: 17 times
Been thanked: 58 times
Re: STOWA
Δημοσίευση από CHRISTOS »
Πανεμορφο. Αν το βγαζε στα 41mm θα τελειωνε το θεμα!
VCFUN
Has thanked: 24 times
Been thanked: 80 times
Re: STOWA
Δημοσίευση από VCFUN »
Εφτασε η στιγμή που είναι έτοιμο για να σταλεί σε πολύ φίλο μου το stowa marine automatic - date με silver dial -μηχανισμό αναβαθμισμένο σε chronometer quality (+160 € ) με μαύρο δερμάτινο λουράκι και extra brown camel . Η συνολική τιμή που πρέπει να καταβάλει είναι 885 € αλλά θα το ακυρώσει γιατί δεν μπορεί να το πάρει τώρα ( παρόλο που το περίμενε 3 μήνες)
Αν κάποιος είχε σκοπό να παραγγείλει το συγκεκριμένο μοντέλο και δεν θέλει να περιμένει ας στείλει πμ να τον ενημερώσω
VCFUN
Re: STOWA
Re: STOWA
από VCFUN » Παρ Απρ 27, 2012 11:35 am
VCFUN
Has thanked: 0 time
Been thanked: 0 time
Κορυφή
