CASIO & G-SHOCK
Re: CASIO & G-SHOCK
ωραιοτατα τα απλα και οπως αναφερονται κλασικα Casio ... μου αρεσαν πολυ οταν ειχαν πρωτοβγει
Re: CASIO & G-SHOCK
pugman έγραψε:In the lead up to G-Shock’s 35th anniversary in 2018, the brand have invited their international offices to each put together a short film celebrating 35 years of toughness. There are plenty of great concepts and amusing moments to be found among the 15 sub-one minute videos, but the one that really sets our dials to smile is the animated G-Torr Origins clip. Our protagonist is a small tortoise with a big ambition: he dreams of winning a strong-man contest on the ocean floor. And when his shell cracks he finds help in none other than the ultra-strong G-Shock 5600. But enough spoilers, check it out for yourself.
http://www.youtube.com/watch?v=STYXbJkHJRg
http://www.g-street.com.au/2017/08/we-c ... 4ce4e022e1" onclick="window.open(this.href);return false;
Ωραία και ενδιαφέρον, ευχαριστώ!
Re: CASIO & G-SHOCK
pugman έγραψε:Εικόνα
It looks like the retro style is here to stay. Once again, it's among the hottest trends this season in a whole host of areas, from interior design to fashion and wristwatches. Whether plain silver, dominant black, elegant gold or dreamy rose: The beautiful, retro-inspired CASIO Collection models LTP-E140R-9AEF, LTP-E140B-1AEF, LTP-E140GB-1AEF, LTP-E140-7AEF or LTP-E140G-9AEF with their thin Milanese wristbands will make sure you look stylish when checking the time. Featuring a clean, minimalist design, the analogue watches emphasize your personal style and are the perfect match for any look.
Technical Specifications
Solid stainless steel case
Stainless steel band
Tough, durable and elegant: The stainless steel wrist strap gives your watch that classic feel.
Adjustable fastening
The clasp can be individually adjusted extremely easily for maximum comfort.
3 Years - 1 Battery
The battery supplies the watch with sufficient energy for approx. three years.
Water resistance classification (WR) to ISO 22810
This model is water resistant to DIN 8310 / ISO 22810, and thus is resistant to minor splashing. Any greater water contact should be avoided.
Dimensions (H x W x D)
46,0mm x 38,0mm x 7,4mm
Weight
approx. 60,0 g
Availability of models and/or lineups may differ depending on the country or region.
Technical amendments and errors excepted. The sizes in figures do not correspond to the original sizes.
The colours may differ slightly from the original.
Πολύ ωραία! Λίγο μεγάλα βέβαια, κρίμα.... Κάποια στιγμή θα βάλουν μυαλό και στην casio... Τσάμπα το αγοράζουν το υλικό και το βάζουν μπόλικο???
Ενδιαφέρον ότι οι προδιαγραφές για την υδατοστεγανότητα δεν αναφέρουν μέτρα, αλλά το ISO, σύμφωνα με τις νέες οδηγίες: https://www.iso.org/news/2010/11/Ref1367.html" onclick="window.open(this.href);return false;
Megalos (Κυρ Σεπ 03, 2017 8:00 pm)
Re: CASIO & G-SHOCK
ωπα ... δεν το ειχα προσεξει Μαρκο ... οντως ειναι μεγαλα ..46αρια !!
Has thanked: 1954 times
Been thanked: 1853 times
Re: CASIO & G-SHOCK
Αυτό για το iso το είδα αλλά δεν γνωριζα οτι άλλαξαν οι οδηγίες. Ευχαριστούμε Μάρκο.
Re: CASIO & G-SHOCK
pugman έγραψε:Αυτό για το iso το είδα αλλά δεν γνωριζα οτι άλλαξαν οι οδηγίες. Ευχαριστούμε Μάρκο.
παιδια που μπορουμε ομως να δουμε τις νεες προδιαγραφες σε μετρα κλπ ??
Re: CASIO & G-SHOCK
Παρακαλώ, να είσαι καλά φίλε Αντώνη
Re: CASIO & G-SHOCK
Τελικά το χτύπησα:
Τεράστιο, αλλά, όπως πάντα με έχει εντυπωσιάσει με τις λειτουργίες και την τεχνολογία του. Μπράβο στην Casio. Πρέπει να έχω ένα G στη συλλογή.
Megalos (Τετ Σεπ 13, 2017 9:17 pm) • ppana (Πέμ Σεπ 14, 2017 7:57 pm)
Re: CASIO & G-SHOCK
καλοριζικο το νεο αποκτημα Μαρκο μου .... και να μας πεις εντυπωσεις :book:
Re: CASIO & G-SHOCK
Megalos έγραψε:καλοριζικο το νεο αποκτημα Μαρκο μου .... και να μας πεις εντυπωσεις :book:
Ευχαριστώ πολύ φίλε Κώστα. Δεν ξέρω αν θα συνηθίσω το μέγεθος, αλλά λόγω χαμηλού βάρους δεν το αισθάνεσαι στο χέρι. Τα ψηφιακά υποκαντράν είναι σχετικά μικρά και λόγω reverse display όχι πολύ ευκολοδιάβαστα, αλλά δε με πειράζει αυτό, γιατί η αισθητική τους και η λεπτομέρεια είναι απίστευτη κατά τη γνώμη μου. Το reverse display μου αρέσει πάρα πολύ και το σχέδιο που κάνει μέσα στο καντράν με μπλε λεπτομέρεια, το οποίο είναι ανάγλυφο. Μου αρέσει πολύ που κάνει τα δόντια του γραναζιού στους δείκτες στην πίσω πλευρά και στο δείκτη του υποκαντράν.
Επίσης, έχει μια λειτουργία που δεν την είχα ξαναδεί, γιατί ποτέ δεν είχα g με δείκτες. Αν χτυπηθεί έντονα ή σε έντονα πεδία, οι δείκτες μπορεί να κουνήσουν από τη σωστή τους θέση και έχει λειτουργία για να τους ξανακαλιμπράρεις. Πολύ εντυπωσιάστικα με αυτό. Κατά τα άλλα έχει τα γνωστά των g, ξυπνητήρι, χρονόμετρο (1/1000 sec!), παγκόσμια ώρα κλπ. Οι δείκτες αυτόματα συγχρονίζουν με την ψηφιακή ώρα με μια ομαλή κίνηση που είναι εντυπωσιακή για ρολόι αυτού του κόστους. Μόλις έβαλα τη σωστή πόλη έφτιαξε η ώρα και δε χρειάστηκε να διορθώσω τίποτα.
Μόνη ένσταση λοιπόν είναι το μέγεθος και ο όγκος, το οποίο το ήξερα όμως. Κατά τα άλλα πολύ τεχνολογία, αισθητική που μου αρέσει και ένα ρολόι που δε θα σε προβληματίσει και δε θα ασχοληθείς πότε με αυτό. Το φοράς και κάνει τη δουλειά του και δε σε νοιάζει αν χτυπηθεί, κλπ.
