SIHH Γενευης 2016
Re: SIHH Γενευης 2016
Georges έγραψε:μικρορότορα και power reserve βλέπω...το quartz που είναι?
γραφει η πηγη
The “inverted” construction of the movement places the main functional elements on the dial side, with the offset micro-rotor and the quartz generator forming a figure eight,
while the off-center, pointed hour and minute hands sweep over finely tapered hour indices
Caliber 700P, for which Piaget has filed more than 10 patents, is the result of two years of research and development at the brand’s manufacture in La Cote aux Fees, Switzerland. It uses a high-frequency quartz element (32,768 vph, or roughly 5.33 turns per second) to control the rotation of the generator and wheel train of the mechanical, self-winding movement. The system ensures a high degree of precision as well as resistance to magnetic fields and gravity. Treated with a distinctive black coating, the movement boasts a number of haute horlogerie finishes: among these are the guilloché motif on the micro-rotor along with the Piaget coat of arms; sunburst and chamfered bridges; circular stain-brushed wheels; and silver-toned screws. The Piaget crest also appears as an engraving on the caseback, which allows just a glimpse into the inner heart of the watch with two small viewing windows
Μάλιστα...κάτι σαν Seiko kinetic ή Spring Drive δηλαδή...
Georges έγραψε:Μάλιστα...κάτι σαν Seiko kinetic ή Spring Drive δηλαδή...
κατι τετοιο Γιωργο ... αλλα σε πολυ πιο κλασατι μορφη
IWC special watch for pilot .η στεφανη ειναι περιστρεφομενη με ειδικη ενδειξη
Πολλά και ενδιαφέροντα μοντέλα!
Has thanked: 1954 times
Been thanked: 1853 times
Re: Απ: SIHH Γενευης 2016
Megalos έγραψε:IWC special watch for pilot .η στεφανη ειναι περιστρεφομενη με ειδικη ενδειξη
Ωραίο!!!
Αντώνης
Been thanked: 12543 times
όντως πολύ ωραίο το IWC πολύ καλή επανέκδοση :rose
Κώστα αυτο δεν ειναι επανέκδοση,αυτό ειναι το original mark ix ..Επανέκδοση αυτου του μοντέλου ειχε κυκλοφορήσει με τη vintage collection ,το pilot εκείνης της σειράς αλλά αυτό στη φωτό ειναι παλιό μοντέλο και από όσο ξερω δεν αναμένεται να κυκλοφορήσει κατι σχετικό.
Argo98 έγραψε:Κώστα αυτο δεν ειναι επανέκδοση,αυτό ειναι το original mark ix ..Επανέκδοση αυτου του μοντέλου ειχε κυκλοφορήσει με τη vintage collection ,το pilot εκείνης της σειράς αλλά αυτό στη φωτό ειναι παλιό μοντέλο και από όσο ξερω δεν αναμένεται να κυκλοφορήσει κατι σχετικό.
Βασιλη μου για αυτο εισαι ειδικος στα IWC :smile:
εχεις δικαιο ..συγγνωμη για το λαθος ... αρα αυτο της φωτο ειναι ιδιο με την επανεκδοση vintage collection ?
Κώστα αυτό όπως είπα είναι ένα vintage mark 9 .Και το mare nostrum που πόσταρες ,το 603, είναι περσινό μοντέλο όπως και το 580 που δεν ειναι καινουριο.
Τελευταία επεξεργασία από το μέλος Argo98 την Δευ Ιαν 11, 2016 11:22 pm, έχει επεξεργασθεί 1 φορά συνολικά.
