IWC ΤΩΡΑ !
GeorgeD
Been thanked: 10 times
Re: IWC ΤΩΡΑ !
Δημοσίευση από GeorgeD »
Megalos έγραψε:A flyback mechanism that works independently of the chronograph. This additional split-minute function is the only one of its kind in the world. It can be switched on and off at any time under water and enables the user to time another action – apart from overall dive time – such as an ascent or the length of a decompression stop. A rugged little rocker switch on the left-hand side of the case makes the mechanism easy to activate. The inside too is packed with top-quality features that include a mechanical, self-winding chronograph with aggregate timing up to twelve hours and the characteristic rotating inner bezel. This is adjusted using the chronograph reset button, which also functions as a crown. The impressive flagship of the Aquatimer fleet, with its imposing 44 mm diameter case, is available exclusively in titanium.
Mechanical chronograph movement
- Small seconds with stop function
- Date display
- Second minute hand for minute memory function
- Screw-in crown
- Mechanical rotating inner bezel
- Luminescent elements on hands, dial and rotating inner bezel
- Sapphire glass, antireflective on both sides
- Water-resistant to 120 m
- IWC metal bracelet system
Glass: sapphire, convex, antirefelctive
- Crown: screwed
- Water-resistant: 12 bar (120 m)
- Case diameter: 44 mm
- Case height: 16.3 mm
- Weight:
Aquatimer Split Minute Chronograph in titanium with titanium bracelet: 153 g
Aquatimer Split Minute Chronograph in titanium with rubber strap: 121 g
Caliber: 79470
- Vibrations: 28 800/h / 4 Hz
- Jewels: 30
- Power reserve: 44 h
- Winding: Automatic
τι λετε για αυτο το Aquatimer Split minute :cheer:
I like!!
Re: IWC ΤΩΡΑ !
Το '' παλαιό '' μπορεί να δείχνει πιο PRO. αλλά το νέο είναι πιο πολιτισμένο εργαλείο !!! :good:
Μην ξεχνάμε ότι το Deep Tow έχει μηχανικό βυθόμετρο
με ''απομνημόνευση'' του μέγιστου βάθους και μηδένιση αυτού !!! cool
Wostep
Been thanked: 1 time
Re: IWC ΤΩΡΑ !
Δημοσίευση από Wostep »
GeorgeD έγραψε:
- Date display
- Screw-in crown
- Crown: screwed
- Weight:
Caliber: 79470
- Jewels: 30
I like!!
Γιατί κάτι μου λέει ότι φοράει 7750 ?
Και αν δεν κάνω λάθος υπάρχει άνθρωπος που θα διαθέσει τα ωραία του χιλιάρικα για να πάρει IWC και μάλιστα με μηχανισμό που τον έχει φορέσει και η κουτσή μαρία????? (για την αξιοπιστία του να μην τα ξαναλέμε)
militaire/vintage specialist
Has thanked: 27 times
Been thanked: 105 times
Re: IWC ΤΩΡΑ !
Δημοσίευση από Blackbird »
7750 φοράει με τροποποίηση για ρατραπάν.
Και ναι πίστεψέ το. Υπάρχουν άνθρωποι που δώσαν τα ωραία χιλιάρικά τους. Προφανώς δε γνωρίζουν τι εστί 7750 και κουτσή Μαρία.
Εικόνα Εικόνα
Re: IWC ΤΩΡΑ !
Wostep έγραψε: Γιατί κάτι μου λέει ότι φοράει 7750 ?
Σωστα,ο μηχανισμος εχει βαση την 7750.Εκτενως τροποποιημενος μεν,αλλα 7750 δε.
Has thanked: 44251 times
Re: IWC ΤΩΡΑ !
ωραιο το IWC galapagos αφιερωμα :cheer:
Re: IWC ΤΩΡΑ !
εδω με το μπρασελε του
Re: IWC ΤΩΡΑ !
αλλα ρε παιδια το Deep two ειναι παρα πολυ cool
Re: IWC ΤΩΡΑ !
και το παντα κλασικο Ingenieur cool
Re: IWC ΤΩΡΑ !
και το φανταστικο Minute repeater IWC
