"Ελληνικές" Ωρολογοποιΐες
Has thanked: 44679 times
Re: "Ελληνικές" Ωρολογοποιΐες
Ηλια φιλε τρελλλα συγχαρητηρια για το ωραιοτατο τοπικ που ανοιξες
μπραβο παιδια για τις λεξεις που βρηκατε.. συνεχιστε
α και κατι .. μην πεσουμε σε εθνικιστικες διενεξεις φιλοι μου :m:
ACIDBLACK
Been thanked: 6 times
Δημοσίευση από ACIDBLACK »
Kyrie, it is Zeus’ anathema on our epoch for the dynamism of our economies and the heresy of our economic method and policies, that we should agonize the Skylla nomismatic plethora, and the Charibdis of economic anaemia. It is not my idiosyncrasy to be ironic or sarcastic, but my diagnosis would be that politicians are rather cryptoplethorists. Although they emphatically stigmatise nomismatic plethora, they energize it through their tactics and practices.
Our policies should be based more on economic and less on political criteria. Our gnomon has to be a metron between economic, strategic and phil-anthropic scopes. Political magic has always been anti-economic.
In an epoch characterized by monopolies, oligopolies, monopolistic antago-nism, and polymorphous inelasticities, our policies have to be more ortho-logical, but this should be not metamorphosed into plethorophobia, which is endemic among academic economists. Nomismatic symmetry should not antagonize economic acme. A greater harmonization between the practices of the economic and nomismatic archons is basic.
Parallel to this, we have to synchronize and harmonize more and more our economic and nomismatic policies panethnically. These scopes are more practicable now, when the prognostics of the political and economic baro-meter are halcyonic.
The history of our didimus organization on this sphere has been didactic and their gnostic practices will always be a tonic to the polyonymous and idio-morphus ethnical economies. The genesis of the programmed organization will dynamize these policies.
Therefore, I sympathize, although not without criticism, one or two themes with the apostles and the hierarchy of our organs in their zeal to program orthodox economic and nomismatic policies, although I have some logo-machy with them.
I apologize for having tyrannised you with my hellenic phraseology. In my epilogue, I emphasize my eulogy to the philoxenous autochthons of this cosmopolitan metropolis and my encomium to you, kyrie steganographers.
Ξενοφών Ζολώτας
International Bank Conference (1959)
Washington, USA
το κειμενο γνωστο ....ο νωον νοητο......
-Montesqueieu
-Friedrich Nietzhe
Aricos
Τοποθεσία: Atnens
Been thanked: 1 time
Δημοσίευση από Aricos »
Ilias-G έγραψε:
Blackbird έγραψε:Μην μπερδεύετε την καταγωγή του Ηπειρώτη Βούλγαρη (που μπορεί και να είχε και βουλγάρικη καταγωγή, εξού και το όνομα) με τη ρίζα (καταγωγή) της λέξης Βούλγαρης. Η λέξη Βούλγαρης έχει βουλγάρικη ρίζα που εξελληνίστηκε.
Το κρίσιμο ερώτημα είναι αυτός που χρησιμοποίησε τη λέξη "Bulgari" για τα ρολόγια του, ήταν Έλληνας και χρησιμοποίησε το επώνυμό του ή όχι? Αν ναι τότε μπαίνει δικαιωματικά στη λίστα.
Η ονομασία Bulgari προέρχεται απο το αργυροχόο Σωτήριο Βούλγαρη που γεννήθηκε στους Καλαρύτες της Ηπείρου στις 18-3-1857 πέρασε τα νεανικά του χρόνια στην Παραμυθιά και ηταν ο ιδρυτής της ομονυμης εταιρείας.
Collector and Investror
militaire/vintage specialist
Has thanked: 27 times
Been thanked: 105 times
Δημοσίευση από Blackbird »
Σωστά όσα λέτε για τον Βούλγαρη Aricos και Eisenberg. Όμως η ετυμολογία της λέξης δεν είναι ελληνική. Όπως οι λέξεις αζιμούθιο και προτζέκτορας, που ενώ έχουν ενσωματωθεί στη γλώσσα μας (έχουν κατάληξη και κλείνονται), δεν είναι ελληνικές. Αν δηλ. εμφανισθεί μάρκα Projectoras θα πούμε πως είναι ελληνικής καταγωγής το όνομα;
Εικόνα Εικόνα
Aricos
Τοποθεσία: Atnens
Blackbird έγραψε:Σωστά όσα λέτε για τον Βούλγαρη Aricos και Eisenberg. Όμως η ετυμολογία της λέξης δεν είναι ελληνική. Όπως οι λέξεις αζιμούθιο και προτζέκτορας, που ενώ έχουν ενσωματωθεί στη γλώσσα μας (έχουν κατάληξη και κλείνονται), δεν είναι ελληνικές. Αν δηλ. εμφανισθεί μάρκα Projectoras θα πούμε πως είναι ελληνικής καταγωγής το όνομα;
Σίγουρα η ετυμολογία δεν είναι ελληνική αλλά με αυτή την άποψη όσον αφορά τα "επίθετα" των ονομάτων θα πρέπει πολλοί Έλληνες να αμφησβιτηθούν για την καταγωγή τους. πχ. ΓΕΡΜΑΝΟΣ. 0100
VIWOW
Δημοσίευση από VIWOW »
Νομίζω οτι το ζήτημα είναι απλό:
Όταν ο Σωτήριος έφτιαξε το μαγαζί του στην Ρώμη, τι λέτε εσείς ότι σκέφτηκε να βάλει στην ταμπέλα; Το έλληνικό όνομά του, ή το όνομα της χώρας που συνορεύει η πατρίδα του προς τον Βορρά; Το κατάστημα "Γερμανός" θα λέγαμε ότι έχει "γερμανικό" όνομα; ή το επίθετο του ιδιοκτήτη του; Τα βιβλία του Φρέντυ Γερμανού αποτελούν έργα της γερμανικής λογοτεχνίας;
Κανείς δεν είπε οτι το ίδιο ισχύει για το Praktiker, παρόλη την ελληνική ρίζα της λέξης. Τα ρολόγια Praktiker, όταν με το καλό βγουν θα έχουν κατά 100% γερμανικό όνομα.
Aricos και Κωστή πολύ πολύ σωστά!! )|(
Αυτό ακριβώς ανέφερα κι εγώ 2-3 ποστ παραπάνω.
Το ίδιο ακριβώς ισχύει με την Hermes, όπως μας επεσήμανε ο Κωστής. Εγώ νόμιζα ότι αναφερόταν στον Ερμή, αλλά ήταν απλώς το επώνυμο του (Γάλλου?) ιδρυτή της. Άρα παρόλο το καθ'όλα ελληνικό όνομα, η εταιρία δεν έχει "συνείδηση" ελληνική!!
VIWOW
....Έχει όμως ελληνικό αίμα, αφού η σύζυγος του ιδιοκτήτη και πρώην Προέδεου, απόγονου της οικογένειας Hermès, Jean Louis Dumas κυρία Rena Dumas, αρχιτέκτων, υπήρξε δημιουργός πολλών αντικειμένων της εταιρείας και Ελληνίδα!!
VIWOW έγραψε:....Έχει όμως ελληνικό αίμα, αφού η σύζυγος του ιδιοκτήτη και πρώην Προέδεου, απόγονου της οικογένειας Hermès, Jean Louis Dumas κυρία Rena Dumas, αρχιτέκτων, υπήρξε δημιουργός πολλών αντικειμένων της εταιρείας και Ελληνίδα!!
Άρα νομίζω δικαιούται να θεωρηθεί "ελληνική" τιμής ένεκεν!! 3600
Stardrive
Τοποθεσία: Lagrange point
Δημοσίευση από Stardrive »
Ενδιαφέρον νήμα και ενδιαφέρουσες τοποθετήσεις.
Η γλώσσα μας είναι σχεδόν ανεξάντλητη, οπότε φυσικό!
