Baume & Mercier
billaras
- Been thanked: 6 times
Re: Baume & Mercier
Θεωρω πολυ κακη επιλογη το classima για 2500..μονο το brand πουλαει και ακριβα μαλιστα..το tag caliber 5 προσφερει ακριβως την ιδια μηχανη 1000 ευρω κατω..η oris το ιδιο..η frederique constant το ιδιο..
- chris5
- Has thanked: 787 times
- Been thanked: 1479 times
Re: Baume & Mercier
- chris5
Re: Baume & Mercier
- Has thanked: 44739 times
- Been thanked: 10068 times
Re: Baume & Mercier
ομορφο και ιδιαιτερο καντραν Χρηστο ...
- pugman
- Τοποθεσία: Αθήνα
- Has thanked: 1954 times
- Been thanked: 1853 times
Re: Baume & Mercier
The New Baumatic By Baume & Mercier: Performance Based On Customer Insights
In January 2018, Baume & Mercier unveiled a surprising new caliber in a new timepiece at a very attractive price-point: the Baumatic BM12-1975A caliber will be exclusively available in the new Clifton Baumatic watch from September 2018 on, with prices starting at $2,750.
What makes this release so remarkable is the fact that Baume & Mercier addresses several real-life problems of mechanical watches, namely
– Sensitivity to magnetic fields (the watch is resistant to magnetic field of 1500 gauss)
– Increased autonomy (120 hours or 5 days)
– Chronometer precision (-4s/+6s per day over the entire 120 hour power reserve)
– Durability (less frequent service intervals)
A New Caliber:
The BM12-1975A caliber is a proprietary movement: The team behind it spent more than four years working on the new automatic movement that also features the first Richemont silicon balance spring, anchor and escapement wheel called “Powerscape escapement” (the Clifton Manual 1830 from 2017 was already fitted with a new silicon balance spring, but not with a silicon escape wheel and lever).
The construction aims to compensate for temperature variations and helps improve accuracy, which is measured at an impressive -4/+6 seconds per day throughout the entire power reserve of 120 hours. Additionally, thanks to the use of silicon and non-ferromagnetic materials, the BM12-1975A is resistant to magnetic fields of up to 1500 gauss (which is 25 times more than the required 4,800 A/m to meet the ISO 764 standard specifying the minimum requirements and test methods for magnetic resistant watches) and does not require a closed caseback or additional soft iron inner cage. Which means that, thankfully, the new caliber is still visible through the sapphire crystal on the caseback of the Clifton Baumatic. Also, the date is slightly bigger than usual which is a big plus for legibility.
5 New Watches
Baume & Mercier’s team decided to equipp the Clifton Baumatic with a classic, 40 mm round case (with brushed sides and a polished top), curved lugs, a domed sapphire crystal and to offer a choice of five dials with a porcelain-like finish (one with crosshair in the center of the dial). The case is water resistant to 50 meters, the caseback is held in position with 4 screws and offers a second sapphire crystal. Last but not least, the watch comes with a two-year warranty and the version with the cross-hair on the dial with a COSC certification.
Three different alligator straps (black, brown and blue) and a stainless steel bracelet are available, all of them equipped with a quick-change strap-system that allows to conveniently change straps without having to use a special tool (or visit a watchmaker) each time.
Baume & Mercier is launching the Baumatic in five different versions:
– Baumatic Ref. 10436 with porcelain-like white dial with cross hair and black alligator strap ($2,990)
– Baumatic Ref. 10401 with two-tone case and brown alligator strap ($3,500)
– Baumatic Ref. 10400 with white dial and stainless steel bracelet ($2,950)
– Baumatic Ref. 10399 with black dial and matching alligator strap ($2,750)
– Baumatic Ref. 10398 with white dial and blue alligator strap ($2,750)
Πηγή: https://watch-insider.com/watch-of-the- ... af13b12d8d" onclick="window.open(this.href);return false;
A New Caliber:
5 New Watches
Re: Baume & Mercier
Αντωνη ευχαριστουμε πολυ για το ενδιαφερον αυτο νεο ...
ωραιοτατος κυριως ο μηχανισμος και εξαιρετικα στοιχεια ... αντιμαγνητικο ισχυρα ...μεγαλη αυτονομια ... διαρκεια σερβις αυξημενη ... ακριβεια
- Has thanked: 7238 times
- Been thanked: 12543 times
Re: Baume & Mercier
Introducing The Baume & Mercier Riviera Chronograph 41mm Series
https://monochrome-watches.com/baume-an ... ecs-price/
- Has thanked: 4023 times
- Been thanked: 2473 times
Re: Baume & Mercier
Δεν τρελαινομαι
- nick10 (Πέμ Απρ 03, 2025 5:51 pm)
Re: Baume & Mercier
το αριστσερο παντως μου αρεσει
TheWatchBuddies
- Been thanked: 752 times
Re: Baume & Mercier
Baume & Mercier’s New Cliftons are a Welcome Exercise in Restraint
Movement: Automatic, self-winding BM13-1975A
Dial: Off-white
Case: Satin-finished rose gold
Diameter: 39 mm
Thickness: 11.22 mm
Crystal: Scratch-resistant sapphire crystal
Strap: Brown alligator leather strap
Power Reserve: 120 hours
Water Resistance: 5 ATM (approximately 50 m)
Price: TBA
Thanks to its colourway, this is the most ‘50s-looking member of this trio. The combination of that brown alligator leather strap, the rose gold of the case, and the slightly vintage look of that off-white dial in particular give the distinct feeling that this watch arrived at Watches and Wonders 2025 via some kind of time machine.
Of course, with the Baumatic movement beating at its core and the immaculate finishing and materials throughout, this is a modern watch through and through. It’s just that Baume & Mercier has done such an outstanding job of recreating that old-school aesthetic that when you hold it in your hand you feel like you’re encountering a perfectly preserved piece of horology from decades ago.
It’s not yet up on the Baume & Mercier website, but I’m sure it will be there sooner rather than later.
Dial: Off-white
Diameter: 39 mm
Thickness: 11.22 mm
Price: TBA
