Longines
nemesis
Re: Longines
Δημοσίευση από nemesis »
marios_ch έγραψε:Τελευταία είμαι ερωτευμένος με αυτό το κομμάτι.......... :rose :rose :good:
Και δικαίως θα πρόσθετα εγώ, αφού είναι πολύ όμορφο το άτιμο...
.....μόνο που μου κάθονται στο στομάχι αυτά τα 39mm. :no:
Been thanked: 9934 times
Re: Longines
nemesis το θεμα ειναι να κατσει στον καρπο σου ... και ας καθεται και στο στομαχι lol
Re: Longines
Με λευκο καντραν και τις κορωνες σιγουρα θα δειχνει μεγαλυτερο στο χερι..
Εξαλλου τετοια ρολογια δεν μου αρεσουν μεγαλα..
Re: Longines
The Longines Column-Wheel Chronograph: A Horological Purist's Watch For Under $3000
Want a column-wheel chronograph for under $3000? Sure you do, and that's exactly what we've got for you today. A column-wheel chronograph is a type of chronograph movement that is particuarly lauded by industry folk. All the high-end chronos you see are column-wheel jobs, including those $70,000 Pateks and Vacherons using the Lemania base, the F. Piguets inside the Royal Oaks and Overseas, and of course those Zenith El Primeros.
One unifying trait of the column-wheel chronograph, besides generally preferred by collectors, is that they are rather expensive. But, this special Longines column-wheel chronograph, the watch given to the winner of the Kentucky derby and also now available to you fine folk, isn't all that expensive.
In fact, this classically designed chronograph, available in both white and black dials and sized at a perfect 39mm retails for under $3000 in steel. The caliber inside this new Longines we developed in-house with the help of ETA, and the result is quite handsome (check out that bright blue column wheel in pic below). It features 27 jewels and is 7.9mm thick.
The new Longines Column-Wheel Chronograph is definitely targeted at the purists, with a traditional case design, dial configuration, movement, and even price. The watch is a winner, for sure.
These column-wheel chronos should hit stores later this year. The retail price for the steel case with white dial will be $2950, steel case with black dial $2750, and rose gold with white dial $8200.
http://www.hodinkee.com/blog/2011/5/31/ ... rists.html
Re: Longines
Μαριε αυτο ειναι παρα πολυ ωραιο κομματι και σε καλη τιμη!
Θα εκανε ιδανικο ζευγαρι με το speedmaster σου :rose
Re: Longines
eisenberg έγραψε:Μαριε αυτο ειναι παρα πολυ ωραιο κομματι και σε καλη τιμη!
Το ξέρω φιλαράκι....
το έχω πει και πιο πανω ότι μου αρέσει πάρα πολύ.......
σε κάποια φάση ίσως το χτυπήσω.......... ;)
Re: Longines
Πολυ ωραίο ρολοι!
Re: Longines
Πολυ ομορφο..! :good:
Re: Longines
Logines Column Wheel Chronograph Watch’s Day At The Races
http://www.ablogtoread.com/logines-colu ... the-races/
Re: Longines
Ωραιος κλασσικος χρονογραφος! :good:
