και ομολογω οτι δεν καταλαβα πως λειτουργει ο χρονογραφος του
BVLGARI
- Has thanked: 44742 times
- Been thanked: 10070 times
Re: BVLGARI
πραγματι Αντωνη φερνει πολυ προς nautilus ...ομως παραμενει ομορφο ..
- Has thanked: 48 times
- Been thanked: 194 times
Re: BVLGARI
Introducing Live From Rome: The Bulgari Octo Watch
Here are the very first pictures of Bulgari's new Octo Watch. In light of Bulgari's Octo line releases so far, you might have been expecting another high complication watch with fine detailing. However, this one resembles the complete opposite - a pared down version of the Octo with only hours, minute, seconds and date functions. The new Octo sports a smaller thinner case at 41mm in size but still retains the same shape as the original. The polished black lacquer dial has a much more simplified minimal look and as you may notice, no longer carries the Genta name. In this latest release from the Octo line Bulgari shows the strongest integration between the two brand DNAs thus far.
The Octo is equipped with the BVL 193 Caliber and fitted with twin barrels, a 50 hour power reserve and sapphire caseback. It will be available in Stainless Steel ($8900CHF) and 18 carat Pink Gold ($26,000CHF). The pink gold version is quite a bit more expensive than the stainless. However after seeing the watch in person, it's obvious that the pink gold model will be in much higher demand. Delivery date is expected to be around September-October of this year.
What are your first impressions of the new Octo?
More details and a full report to follow very shortly.
http://bulgari.watchprosite.com/?show=n ... 78&fi=1051
Re: BVLGARI
πραγματι Σπυρο ειναι πολυ ομορφο αυτο το Bvlgari .. θυμιζει λιγο Cartier ειδικα στην κορωνα ...
αλλα ειναι ωραιο
αλλα ειναι ωραιο
Re: BVLGARI
και τωρα που το παρατηρησα ειναι λιγο αλμυρουστικη η τιμη του ...
Re: BVLGARI
Πρωτος inhouse μηχανισμος απο την BVLGARI!!
Λεπτομερειες εδω!
http://bulgari.watchprosite.com/?show=n ... 38&fi=1051
Λεπτομερειες εδω!
- These users thanked the author antonis_ch for the post:
- Megalos (Πέμ Σεπ 13, 2012 11:44 pm)
Re: BVLGARI
Χρηστο ηπειρωτικο προιον παιδι μου .... εχει αρχοντιαCHRISTOS έγραψε:Επαθα πλακα παιδια. Μ αρεσει παρα πολυ. Η εταιρεια εχει αρχισει να διαφοροποιειται και να αποκτα χαρακτηρα. Μου πεσε το σαγωνι με το χρυσο.
Re: BVLGARI
http://www.dete.gr/news.php?article_id=140165" onclick="window.open(this.href);return false;
- dimRHO
- Has thanked: 129 times
- Been thanked: 368 times
Re: BVLGARI
Octo Finissimo Minute Repeater με 6,85mm πάχος τον κάνει τον λεπτότερο στον κόσμο!
http://www.ablogtowatch.com/bulgari-oct ... ter-watch/" onclick="window.open(this.href);return false;
