Breitling
Re: Breitling
Galactic 44
The uber-sporty watch
The Galactic collection by Breitling welcomes a new large-sized model featuring a 44 mm diameter and a satin-brushed bezel with rubber-inlaid hour-markers. Exactly what it takes to reinforce its ultra-sporty, technical look.
In 130 years, Breitling has asserted itself as the specialist of chronographs and instruments for professionals. But this expertise also enables it to create watches reflecting the same performance-oriented spirit, such as the Galactic. This uber-sporty, versatile and sophisticated model is intended for all those whose activities do not necessarily require chronograph functions, but who are nonetheless looking for a watch that is at once sturdy, accurate and reliable. After a 41 mm selfwinding version and two 36 and 32 mm ladies’ models, the collection is now enriched with a new large-sized watch. In adopting a 44 mm diameter, the Galactic has strengthened its technical and masculine appeal. The unidirectional rotating bezel takes on a satin-brushed finish along with black rubber-inlaid hour-markers, while the dial features two apertures for the day and date at 12 and 3 o’clock respectively, along with a compass scale and a graduated scale with 1/100th of an hour divisions on the inner bezel. The large hands and hour-markers enhanced with a luminescent coating guarantee excellent readability, reinforced by the sapphire crystal glareproofed on both sides. The polished steel case is water-resistant to 200 m/660 ft and equipped with a screw-lock crown protected by reinforcements. It houses a selfwinding movement chronometer-certified by the COSC (Swiss Official Chronometer Testing Institute), the highest benchmark in terms of reliability and precision. The new Galactic 44 is available with a black, blue or silver dial, fitted with a choice of steel bracelet or a strap in leather, crocodile leather, rubber or military-type fabric. An uber-sporty watch for fans of performance.
- These users thanked the author Georges for the post (total 3):
- Argo982001 (Σάβ Νοέμ 01, 2014 10:39 am) • eisenberg (Σάβ Νοέμ 01, 2014 3:10 pm) • Megalos (Σάβ Νοέμ 01, 2014 3:39 pm)
- Rating: 23.08%
- Has thanked: 642 times
- Been thanked: 506 times
Re: Breitling
Πολύ καλό!!!! Σαν να έκαναν παιδί το chronomat airborne και το headwind!!
Ποιο από τα δύο??
Ποιο από τα δύο??
Re: Breitling
Δεν ξέρω πως θα δείχνει το μπλε ζωντανά. Με βάση τα ρολόγια που ήδη έχεις, το μπλε θα έπαιρνα.Argo982001 έγραψε:Πολύ καλό!!!! Σαν να έκαναν παιδί το chronomat airborne και το headwind!!
Ποιο από τα δύο??
- These users thanked the author Georges for the post:
- Argo982001 (Σάβ Νοέμ 01, 2014 10:44 am)
Re: Breitling
Βασικά Γιώργο σκέφτομαι πολύ σοβαρά το επόμενο μου ρολόι να είναι μπλε όταν με το καλό το πάρω απόφαση και αυτό με βάζει σε σοβαρές σκέψεις.Θεωρώ πως είναι ιδανική επιλογή αν είναι όπως το φαντάζομαι στο live του.
Re: Breitling
Μια βόλτα στην μπουτίκ όταν με το καλό έρθει...και μετά πετάγεσαι δίπλα στην Ω να δεις και PO Good PlanetArgo982001 έγραψε: Βασικά Γιώργο σκέφτομαι πολύ σοβαρά το επόμενο μου ρολόι να είναι μπλε όταν με το καλό το πάρω απόφαση και αυτό με βάζει σε σοβαρές σκέψεις.Θεωρώ πως είναι ιδανική επιλογή αν είναι όπως το φαντάζομαι στο live του.
Re: Breitling
το good planet είναι αρκετά πιο ακριβό αλλά λογικά δε θα το προτιμούσα και ίδια τιμή να είχε.Πανεμορφο ρολόι γενικά αλλά με χαλάνε οι αναλογίες διαμέτρου-πάχους και lugs που έχει.
Re: Breitling
Στα 43,5 mm νομίζω πως έχει τις πιο ιδανικές αναλογίες σε σχέση με τα υπόλοιπα POArgo982001 έγραψε: το good planet είναι αρκετά πιο ακριβό αλλά λογικά δε θα το προτιμούσα και ίδια τιμή να είχε.Πανεμορφο ρολόι γενικά αλλά με χαλάνε οι αναλογίες διαμέτρου-πάχους και lugs που έχει.
Re: Breitling
43.5mm με 18mm πάχος και 21mm lugs...Δεν ξέρω ..με χαλάει το πάχος του και μου φαίνονται πολύ μικρά τα lugs γι αυτό το μέγεθος.
Re: Breitling
Πανεμορφο το Galactic,πραγματικη ρολογαρα.
Βεβαια τιμες στα υψη-και χωρις καν τη δικαιολογια του in house- αλλα για οποιον εχει το $ εξαιρετικη επιλογη.
