Patek Philippe
tazio
Been thanked: 5 times
Re: Patek Philippe
Δημοσίευση από tazio »
marios_ch έγραψε:Patek Philippe Aquanaut Travel Time
Συμπαθητικό ρολόι.
Μη ταΐζεται τα TROLL !!!
Re: Patek Philippe
Αναλυτικότατο review γι αυτο το κομμάτι......... :book: :photogr:
http://patek.watchprosite.com/show-foru ... 99578/s-0/
Re: Patek Philippe
τρομερο κομματι ...
χρονογραφος monopousoir :cheer:
Re: Patek Philippe
Megalos έγραψε: ...
Χρονογραφος monopousoir με minute repeater και perpetual calendar και moonphase ;)
Re: Patek Philippe
Patek Philippe’s perpetual calendar chronographs are among the most collectible of all timepieces. References such as 1518, 2499 and 5970 are spoken of reverently, and the phrase “holy grail” often slips into the conversation. So when a new reference comes on the scene, the event commands attention. When it has a new manufacture movement, the occasion is doubly important.
Patek Philippe Manufacture Caliber CH 29-535 PS.
The clutch and chronograph wheels engage.
The new reference 5270 in white gold is priced at $155,700.
TECHNICAL INFORMATION
Patek Philippe Reference 5270 in 18K White Gold
Perpetual Calendar Chronograph
Movement: Caliber CH 29-535 PS Q
Manually wound mechanical movement, column-wheel chronograph, chronograph hand, instantaneously jumping 30-minute counter, and subsidiary seconds. Perpetual calendar with day, month, leap-year cycle and day/night indication in apertures, analog date. Moon phases.
Diameter: 32 mm
Height: 7 mm (of which 1.65 mm for the perpetual calendar)
Number of parts: 456 (of which 182 for the perpetual calendar)
Number of jewels: 33
Power reserve: 65 hours
Balance: Gyromax
Frequency: 28,800 semi-oscillations/hour (4 Hz)
Balance spring: Breguet
Functions: Two-position crown
– Pushed in: To wind the watch
– Pulled out: To set the time and stop the seconds hand
Displays: Center hour and minute hands
Chronograph hand (trotteuse) from the center
Subsidiary dials:
– 30-minute counter between 3 and 4 o’clock
– Subsidiary seconds between 8 and 9 o’clock
– Date at 6 o’clock
Apertures:
– Day and month on an axis beneath 12 o’clock
– Moon phase at 6 o’clock
– Day/night indication between 7 and 8 o’clock
– Leap year cycle between 4 and 5 o’clock
Corrector push pieces:
– Day corrector between 1 and 2 o’clock
– Month corrector between 12 and 1 o’clock
– Moon-phase corrector between 6 and 7 o’clock
– Date corrector between 11 and 12 o’clock
Delivered with correction stylus in ebony and 18K white gold
Chronograph pushers:
– Start and stop at 2 o’clock
– Reset at 4 o’clock
Hallmark: Patek Philippe Seal
Features:
Case: 18K white gold, sapphire crystal, screwed display back with sapphire crystal
window
Water-resistant to 30 meters
Case dimensions: Diameter: 41 mm
Height: 12.40 mm
Width between lugs: 21 mm
Dial: Silvery opalescent
Twelve applied hour markers in black-oxidized gold
Leaf-shaped hour and minute hands in black-oxidized gold
Counter-balanced chronograph hand from the center
Subsidiary dials, off-center, circular guilloché pattern
– Subsidiary seconds between 8 and 9 o’clock. Leaf-shaped hands in black-oxidized gold
– 30-minute counter between 3 and 4 o’clock: Leaf-shaped hands in black-oxidized gold
Strap: Alligator leather with square scales, hand-stitched, matte black, foldover
clasp in 18K white gold
Re: Patek Philippe
Απιστευτος μηχανισμος! :magn:
Μονο 155.700$ $0$$
Re: Patek Philippe
Θοδωρη αμα θες σου παιρνω ενα και μου τα δινεις μετα δεν υπαρχει προβλημα! :ha:
Re: Patek Philippe
αχ ρε Μαριε τι μας κάνεις ....
Θοδωρε λες να το χτυπησω ?
μου λειπουν 150.000 $ μονον... τα αλλα τα εχω lol
Re: Patek Philippe
PATEK PHILIPPE - New Perpetual Calendar Ref. 5550P «Advanced Research»
Caliber 240 Q Si: Two letters boost the power reserve from 48 to 70 hours
Balancier GyromaxSi. © Patek Philippe
Pulsomax. © Patek Philippe
Spiral breveté Spiromax. © Patek Philippe
Technical data
Patek Philippe Advanced Research Perpetual Calendar Ref. 5550P
Movement: Caliber 240 Q Si
Ultra-thin self-winding mechanical movement. Perpetual calendar with
analog displays for the day of the week, date, month, and leap-year
cycle. Moon phases and 24-hour display.
Diameter: 27.50 mm
Height: 3.88 mm
Number of parts: 281
Number of jewels: 25
Power reserve: Max. 70 hours
Winding rotor: Minirotor in 22K gold, unidirectional winding
Frequency: 21,600 semi-oscillations per hour (3 Hz)
Oscillomax®: Balance: GyromaxSi® (in Silinvar® and 24K gold)
Balance spring: Spiromax® (in Silinvar®)
Escapement: Pulsomax® (lever and escape wheel in Silinvar®)
Displays: Hours and minutes from the center
Day of week and 24-hour dial at 9 o'clock
Month and leap-year cycle at 3 o'clock
Analog date and moon-phase aperture at 6 o'clock
Functions: Two-position crown:
Corrector push pieces: Day at 9 o'clock
Date between 11 and 12 o'clock
Month between 12 and 1 o’clock
Moon phase at 6 o'clock
Setting stylus in ebony and 18K white gold delivered with the watch
Features
Case: 950 platinum
Snap-on sapphire-crystal back with integrated loupe; diamond of approx.
0.02 ct. between the lugs at 12 o'clock
Water resistant to 30 m (3 bar)
Case dimensions: Diameter: 37.20 mm
Height: 8.80 mm
Overall height incl. loupe: 10.10 mm
Width between lugs: 19 mm
Dial: Silvery gray, vertical satin finish, “Advanced Research” inscription 12 obus hour markers in 18K rose gold with luminous coating
Hour and minute hands: Leaf-shaped, in 18K rose gold, with luminous coating
Hands for 24-hour display, leap-year cycle, date, day of week, and month:
Strap: Hand-stitched alligator leather with large square scales, shiny chocolate brown, platinum foldover clasp
http://www.worldtempus.com/en/news/top- ... -research/
Re: Patek Philippe
εδω οπως λεει και ο φιλος μου ο Μιχαλης ο Βαρδανης η Patek δειχνει οτι εκτος απο
αξιες κανει και τεχνολογικα επιτευγματα στην ωρολογοποια σημαντικα
αχ Μαριε μας βαζεις τρελλους πειρασμους .. απο τιμη δεν μας ειπες τιποτα :TND:
