Ulysse Nardin
Re: Ulysse Nardin
ULYSSE NARDIN - Blue Toro
A powerful Timepiece for everyday use – available in Ulysse Nardin Boutiques, exclusively.
Press release
This high tech perpetual calendar with a dual time function and the legendary in-house developed and manufactured self-winding movement is the most consumer friendly perpetual calendar ever produced and has passed the tests of time.
The striking aesthetic of Blue Toro combines modern materials with a timeless dial design that inspired its name.
The bezel and pushers are made in ceramic. The squeletted hands permit easy reading of all calendar functions and the sapphire caseback allows to observe the mechanics of time.
Limited to 99 pieces, „Blue Toro“ Limited Edition is available in Ulysse Nardin Boutiques, exclusively.
• The only perpetual calendar that adjusts forward and backward in seconds over the quick corrector position of a single crown, even in the year 2100.
• The hour hand is adjusted instantly to a new local time with pushers (+) or (-) without taking the watch off the wrist or interfering with its time keeping.
• The arrow keeps track of one’s home or reference time.
• The oversized date, the day, the month and the year change instantly forward or backward when the hour hand is moved to a new local time across the dateline with pushers (+) or (-).
• The 22 ct gold rotor ensures that the watch is automatically wound with a power reserve of 45 hours.
Chronometer Certificate C.O.S.C.
The Perpetual GMT± undergoes the rigorous tests of the Swiss Official Chronometer Control, certifying to the reliability and accuracy of this exceptional timepiece.
imited to 99 pieces, „Blue Toro“ Limited Edition is available in Ulysse Nardin Boutiques, exclusively. © Ulysse Nardin
Technical data
Ref. 326-01LE
Limited Edition to 99 pieces
Movement: Caliber UN-32, 34 jewels
Power-Reserve approx. 45 h
Winding: Self-winding with COSC certificate.
Functions: Perpetual Calendar adjustable over single crown. 2nd Time zone on main dial with a patented quick setting mechanism. Permanent home time indicated by 3rd hand. Big date in double window.
Case available in 18 ct rose gold with a blue ceramic bezel
Dimensions: 43 mm
Water-resistance: 100 m Dial blue
Crystal: Anti reflective sapphire crystal
Case-back sapphire crystal
Crown screw-down
Band rubber strap with titanium/ceramic deployant clasp or leather strap with folding buckle.
http://www.worldtempus.com/en/news/top- ... blue-toro/
militaire/vintage specialist
Has thanked: 27 times
Been thanked: 105 times
Re: Ulysse Nardin
Δημοσίευση από Blackbird »
Το αγαπημένο μου UN.
Σημασία στη λεπτομέρεια.
Εικόνα Εικόνα
i palios
Has thanked: 1960 times
Been thanked: 1092 times
Re: Ulysse Nardin
Δημοσίευση από i palios »
Χμ.. ετσι κι ετσι.. .Το βρισκω πολυ μοντερνο, πολυ σπορ, παντως εντυπωσιακο!! :magn:
Has thanked: 43519 times
Been thanked: 9713 times
Re: Ulysse Nardin
i palios έγραψε:Χμ.. ετσι κι ετσι.. .Το βρισκω πολυ μοντερνο, πολυ σπορ, παντως εντυπωσιακο!! :magn:
ετσι και εγω Γιαννη ... μαλλον δεν ειναι για την ηλικια μας lol
Re: Ulysse Nardin
Προτιμω κατι πιο απλο απο την εταιρεια αναγνωριζοντας ομως τη φοβερη δουλεια που εχει γινει
DragonAce
Τοποθεσία: Ηράκλειο
Has thanked: 184 times
Been thanked: 225 times
Re: Ulysse Nardin
Δημοσίευση από DragonAce »
καρακίτς
χρυσό με λάστιχο! χώρια το καντράν που δε ξέρει τί θέλει κ πώς να το δέιξει! αναρχία!
Re: Ulysse Nardin
Όλα αρμονικά και σοφά τοποθετημένα.
Το "λάστιχο" με το χρυσό χρησιμοποιείται εδώ και 30 χρόνια στην Υ.Ω. από πάρα πολλές πια εταιρείες.
Ξέρετε ποια μάρκα πρώτη τα πάντρεψε ως υλικά και πως εμπλέκεται εμμέσως η Ελλάδα σ' αυτό;
Εικόνα Εικόνα
Re: Ulysse Nardin
Η Bulgari Δημητρη?
DragonAce
Τοποθεσία: Ηράκλειο
Re: Ulysse Nardin
DragonAce έγραψε:
Blackbird έγραψε:Όλα αρμονικά και σοφά τοποθετημένα.
ωωωχού buns! έχουμε κ μεις μάτια κ βλέπουμε ότι το κάνουν
τη γνώμη μας μπορούμε να τη πούμε; :box:
Re: Ulysse Nardin
Αμέ.
antonis_ch έγραψε:Η Bulgari Δημητρη?
Η Hublot ήταν πρώτη που πάντρεψε καουτσούκ λουράκι με χρυσή κάσα. Αυτή τη μίξη υλικών χρησιμοποίησε ως κεντρική ιδέα του fusion, όταν την εξαγόρασε ο Μπιβέρ.
Τώρα που εμπλέκεται η Ελλάδα; Όταν πρωτοβγήκε στις αρχές του 80 το καουτσούκ δε χρησιμοποιούνταν παρά μόνο για καταδυτικά και σπορ ρολόγια κι όχι σε ρολόγια πολυτελείας. Όμως πρόσεξε τη διαφήμηση ο τέως και σε λίγο ήταν και στο χέρι του Ισπανού βασιλιά, του Σουηδού και του πρίγκηπα του Μονακό. Έτσι έγινε το ρολόι του τζετ-σετ.
Εικόνα Εικόνα
